No text on I2C lcd serial blue 2004 from dx.com
Regarding product sku.138616 , i cant get this display to work using an arduino uno.
the display i received has an other i2c driver on the back text says GY-LCD-V1 on the back.
The spec write it uses i2c address 0x27, but when i run an i2c scan it shows up at 0x20.
After changing to this address my backlight turns on and i see a blinking cursor but no text can be put on the display using de LiquidCruistal_i2c library.
wiring is correct , anybody got this display working ?
sample code used:
#include
#include
LiquidCrystal_I2C lcd(0x20,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
lcd.init(); // initialize the lcd
lcd.init();
// Print a message to the LCD.
lcd.backlight();
lcd.setCursor(3,0);
lcd.print("Hello, world!");
lcd.setCursor(2,1);
lcd.print("Ywrobot Arduino!");
lcd.setCursor(0,2);
lcd.print("Arduino LCM IIC 2004");
lcd.setCursor(2,3);
lcd.print("Power By Ec-yuan!");
I believe that that board uses a serial backpack for its I2C interface and it is that board with which you are attempting to communicate.
See if this thread helps, make sure you read it all the way through: → http://arduino.cc/forum/index.php/topic,106655.0.html
Don
[EDIT]: Here’s another one → http://arduino.cc/forum/index.php/topic,128635.0.html
Hi , thanks for the info.
Managed to get it working with arduino 0.22 std i2c library.
Arduino 1.01 no luck ..
I also did try those links but no luck using arduino 1.01
Sorry you where right
At the end , this was the solution many thanks !
sirion:
Arduino Forum
I'm guessing you are referring to my post in that thread? I just modified it to include a mention of "GY-LCD-V1" as thats exactly the same board I have..... and I knew I wouldnt be the only one spending hours getting the thing to work! glad it helped you out.
See if this thread helps, make sure you read it all the way through: --> Arduino Forum
In my case, yes. That is what I was referring to when I said "make sure you read it all the way through:".
Don
