I'm an arduino beginner and I have a problem with lighting up a led.
I connected the led with the + side to Pin 13 and the - side to ground of the arduino.
If I connect the 3,3 v to the led instead of the Pin 13, the led working.
#define LEDPIN 13
pinMode(LEDPIN, OUTPUT);
digitalWrite(LEDPIN, HIGH);
So whats wrong?
Thanks.
Also tried the example
int ledPin = 12; // LED connected to digital pin 13
pinMode(ledPin, OUTPUT); // sets the digital pin as output
digitalWrite(ledPin, HIGH); // sets the LED on
delay(1000); // waits for a second
digitalWrite(ledPin, LOW); // sets the LED off
same result, no voltage
It's working now. Maybe a cable was broken.
mranguish:
You should never run a LED without a current limiting resistor directly from the Arduino pins.
You will damage the LED and the Arduino.
