NO WORKING MOTOR
Hi everyone, I have an Arduino Uno and I'm trying to move a motor. When I connected the motor to the 6 pin it did not work (and there is not sound), but when I connected to a led it worked so the problem is not on the code. And when I connect the 5v or 3.3v pin to the motor, it works :astonished: !!!! Can someone help me?
Well, the motor is probably OK, which more than you can say for pin 6. Never, ever connect a motor directly to an Arduino I/O pin.
AWOL: Never, ever connect a motor directly to an Arduino I/O pin.
Have a look at this
Max safe output current from an Arduino pin about 0.04A Current needed by a motor probably 0.2 to 2A (depending on size).
Motors are about power, logic signals are not.
Its a bit like trying to move a lorry using just pedal power!
MarkT: Its a bit like trying to move a lorry using just pedal power!
and getting your foot squashed by the back wheel
...R
