i have to steer a modellcar with a Nod ring for a project in my college. Therefore i have to transfer the Euler angels from this Visual Studio 2015 programm to the Arduino IDE.
Welcome to the Forum. Please read Nick Gammon's two posts at the top of the Forum for guidelines on using and posting code on the Forum, especially the use of code tags for code listings. You'll get better/more responses if you do.
The very first line of your program includes a file which includes a file which tries to include SDKDKver.h. That looks like it might be a standard part of visual studio, to run on a PC.
You need to remove that #include from targetver.h and then work out which functions it was using from that library. If you are lucky, it is a function that you don't need and you can delete it.
If it is a function necessary for what you are trying to do then you need to rewrite it for the Arduino.
Delta_G:
Well you obviously either don't have that library or have it in the wrong place.
Thank you. I added all the libraries. Now this error appears
Compiling 'NodRingArduino2' for 'Arduino Uno'
minwindef.h:In file included from
windef.h:from
windows.h:from
NodRingArduino2.ino:from
winnt.h:147:2: error: #error "No Target Architecture"
:#error "No Target Architecture"
windef.h:from
windows.h:from
winnt.h:938:2: error: #error Must define a target architecture
:#error Must define a target architecture
winscard.h:In file included from
windows.h:from
wtypes.h:742:26: error: pasting "" and "" does not give a valid preprocessing token
:#define _VARIANT_BOOL ##
oaidl.h:in expansion of macro '_VARIANT_BOOL
:_VARIANT_BOOL bool
:_VARIANT_BOOL *pbool
vcruntime.h:In file included from
stdint.h:from
inttypes.h:from
stdio.h:from
stdafx.h:from
vadefs.h:137:49: error: template argument 1 is invalid
:struct __vcrt_va_list_is_reference<_Ty&&>
stdint.h:In file included from
inttypes.h:from
stdio.h:from
stdafx.h:from
vcruntime.h:81:1: error: expected constructor, destructor, or type conversion before '(' token
:_CRT_BEGIN_C_HEADER
winnt.h:In file included from
minwindef.h:from
windef.h:from
windows.h:from
pshpack4.h:31:16: error: expected declaration before end of line
:#pragma pack(4)
Error compiling project sources
Is there another way to use the values from Visual Studio with Arduino.
Visual Studio is an application development environment. Your question makes no sense. Visual Studio does not connect to a serial port and send or receive data from the port.
You can use Visual Studio, and a number of languages. to build an application that CAN connect to a serial port and send or receive data from the port.
So, YOUR application, about which we know nothing, might be able to communicate with the Arduino. Stop asking questions about what Visual Studio can do. As far as the Arduino is concerned, it as useful as Paint.
Alex56:
windef.h:from
windows.h:from
windef.h:from
windows.h:from
windows.h:from
:_VARIANT_BOOL bool
stdint.h:from
inttypes.h:from
stdio.h:from
stdafx.h:from
inttypes.h:from
stdio.h:from
stdafx.h:from
minwindef.h:from
windef.h:from
windows.h:from
:#pragma pack(4)
It looks like you're trying to compile a Windows program. That obviously won't work on an Arduino.
You need to extract the useful part of the program and put that into an Arduino program. At this point we don't know what's useful because we don't know much about your project.
Start small. Can you get your bluetooth shield to pair with the Nod ring? Can you see any data coming from it?
I'm pretty sure that one of the MPU6050 libraries incorporates Euler's formula and outputs Euler angles, if that helps. (Might take a bit of searching.)
Alex56:
Right that is my question how can i change it one. Why does this error appears?
SDKDDKVer.h: No such file or directory
Dude, this is like a pilot asking why a car doesn't have a "extend flaps" lever for take-off. Car is not a plane, even though they do similar things.
The code will not work. What you will have to do is write some new code that does the same thing as the old, perhaps using the old as a general guide in spots where it makes sense.
Hi, what is your electronics, programming, arduino, hardware experience?
Is this a school/college/university project, where are your tutors and lecturers.
