Arduino: 1.8.18 (Windows 10), Board: "NodeMCU-32S, 80MHz, 115200, None, Disabled"
Sketch uses 283057 bytes (21%) of program storage space. Maximum is 1310720 bytes.
Global variables use 20240 bytes (6%) of dynamic memory, leaving 307440 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.6
Serial port COM8
Connecting....Traceback (most recent call last):
File "esptool.py", line 37, in
Chip is ESP32-D0WDQ6-V3 (revision v3.0)
File "esptool_init_.py", line 1064, in _main
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
File "esptool_init_.py", line 859, in main
Crystal is 40MHz
File "esptool\cmds.py", line 466, in write_flash
MAC: c8:c9:a3:fc:f9:28
File "esptool\util.py", line 37, in flash_size_bytes
Uploading stub...
TypeError: argument of type 'NoneType' is not iterable
Running stub...
[1076] Failed to execute script 'esptool' due to unhandled exception!
Stub running...
WARNING: Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.
Configuring flash size...
the selected serial port Configuring flash size...
does not exist or your board is not connected
option enabled in File -> Preferences.
