Node esp32s v1.1
COULD NOT UPLOAD MY PROGRAM
THISH THE ERROR
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Silicognition wESP32, 80MHz, 921600, None"
Sketch uses 198838 bytes (15%) of program storage space. Maximum is 1310720 bytes.
Global variables use 13248 bytes (4%) of dynamic memory, leaving 314432 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.0-dev
Serial port COM7
Connecting......................................_____
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
option enabled in File -> Preferences.
Things to check...
  • you have the correct board selected.
  • you have the correct port connected.
  • some of the ESP boards (no idea about yours) require GPIO2 to be LOW on boot, for uploading. If you have the serial monitor connected you should see a message waiting for upload (baud 115200) if in the correct state.
My board is ESP 32S NODEMCU V1.1
@satpor3, your ESP32 is not an Uno WiFi Rev2 and hence your toic has been moved to a more suitable location on the forum
try while uploadimg pressing the BOOT button
try setting the board to ESP32>ESP32 Dev Module
not working bro
The bro presses the button at the right bro time or the bro gets the error message.
after the bro has selected upload and the bro is able to see the dots and dashes appear, then the bro, press the button. Don't, bro, press the button before the bro sees the dots and dashes or, bro, after the failure message but, bro, as quickly as possible after the dots/dashes appear, bro, then the bro presses the button to upload the bro's code. ok bro?
I have deleted your other cross-post @satpor3.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please take some time to pick the forum category that best suits the subject of your question and then only post once to that forum category. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
