Node.Js to Arduino
Want to receive data(internet Time and date ) from Node.js server to Arduino.
Please help.
Thank you.
I don't know anything about Node.js.
Can it connect to a serial port and hence to the Arduino over a USB cable?
Can it connect to the Arduino using bluetooth and a bluetooth module on the Arduino?
In either case the examples in Serial Input Basics should be useful.
If the Arduino needs to connect over Ethernet or Wifi you will need a suitable add-on for the Arduino (or use a Yun which already has them). The ESP8266 is an inexpensive WiFi module.
...R
Yes it is able to send the data to Server through ESP8266-01 wifi module.Now i am trying to receive data from Server to Arduino via ESP8266-01 wifi module.
Thank you.
Fetching data from node.js is the same as any other web page from the client side.
Suggest you search "arduino esp8266 http get"
A couple of likely-looking links below to get you started.
Basically you get the entire web page as a chunk of text which you have to search through to extract the information you want.
Ok.Thank you very much.
Hi rw950431,
I wanted to fetch the JSON data from Server to arduino+Esp8266(Wifi module) and store it into some variable and display in Arduino’s Serial monitor. After implementing the code from the link http://stackoverflow.com/questions/34078497/esp8266-wificlient-simple-http-get, the result i
got is attached in image format below.
I am not able to fetch the JSON data from Server.
Please have a look a at the image attached.
Thank you.
I want to fetch the JSON data(time and date) from Node.Js Server to ESP8266-01 using http GET method.
I have used Software serial definition as
#include<SoftwareSerial.h>
SoftwareSerial ser(A8,A9); // Connect TX and RX of ESP8266 (A8 for TX A9 for RX) of ATMEGA2560.
In the code i have written
ser.print(String("GET ") + “/details HTTP/1.1/\r\n” +
“192.168.1.11”+ “\r\n” +
“Connection: close\r\n\r\n”);
// Read all the lines of the reply from server and print them to Serial
Serial.println(“Respond:”);
while(ser.available()){
String line = ser.readStringUntil(’\r’);
Serial.print(line);
Serial.println(“closing connection”);
where ser is defined function for ESP8266-01
192.168.1.11 is Local server IP address from where i have to fetch the JSON data(data and time in my case).
But i am not able to fetch date and time data.
Perhaps try the code from http://shawnhymel.com/695/quick-tip-http-get-with-the-esp8266-thing/
Yours seems to omit the space between GET and /details and also the "host:" before the IP address.
ok. I have initialized for ESP8266 for ATMEGA 2560 as below shown code and used ser.println function,hope using “ser” is correct?
#include <SoftwareSerial.h>
Then in the esp8266 function as
void esp_8266()
String cmd = “AT+CIPSTART=“TCP”,”"; // AT cammand for TCP/IP connection
cmd += “192.168.1.11”; // api.thingspeak.com IP adress
cmd += “”,5000"; // HTTP port no.
ser.println(cmd); // Sending AT cammand
p=1;
if(p == 1)
if(ser.find(“Linked”)) // Serching for responce from ESP8266
Serial.println(“Connection Made for Receiving data”);
z=0;
p=0;
int deviceid = serialNumber;
String getStr = “GET /log/345/12/status/”;
getStr += DHT.temperature;
getStr += “/”;
getStr += DHT.humidity;
getStr += “\r\n\r\n”;
cmd = “AT+CIPSEND=”; // AT command to send Data at TCP server
cmd += String(getStr.length()); // send data length
ser.println(cmd); // Wrighting the AT command to ESP8622
if(ser.find(">")) // Serching for responce to send data from ESP8266
ser.print(getStr); // Printing the string with sensor data to send on ESP8266 module
delay (100);
ser.println(“GET /details HTTP/1.1”);
ser.print("Host: ");
ser.println(“192.168.1.11”);
ser.println(“Connection: close”);
ser.println();
Serial.println(line);
Hi rw950431,
The stackoverflow link which you provided is not working . can you just have a look one more time.
rw950431 adviced you to try this example, which isn't on stackoverflow. IWhen you ignore someone's advice then s/he will ignore your future requests for advice.
ok.
I tried the example what you mentioned in the link which uses #include<WiFiClient.h>, but i got an error which i attached in the image.
