I am trying to interface the DS1307 with node MCU unit. Is there any library function available
Below code is working fine . But it wont allow user to add and change set_date&time . Can i use Wire library of arduino Uno Directly?? Is there any web based timing control
/* for normal hardware wire use below */
#include <Wire.h> // must be included here so that Arduino library object file references work
#include <RtcDS1307.h>
RtcDS1307<TwoWire> Rtc(Wire);
/* for normal hardware wire use above */
void setup ()
Serial.print("compiled: ");
Serial.print(__DATE__);
Serial.println(__TIME__);
//--------RTC SETUP ------------
// if you are using ESP-01 then uncomment the line below to reset the pins to
// the available pins for SDA, SCL
// Wire.begin(0, 2); // due to limited pins, use pin 0 and 2 for SDA, SCL
Rtc.Begin();
RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
printDateTime(compiled);
if (!Rtc.IsDateTimeValid())
// Common Cuases:
// 1) first time you ran and the device wasn't running yet
// 2) the battery on the device is low or even missing
Serial.println("RTC lost confidence in the DateTime!");
// following line sets the RTC to the date & time this sketch was compiled
// it will also reset the valid flag internally unless the Rtc device is
// having an issue
Rtc.SetDateTime(compiled);
if (!Rtc.GetIsRunning())
Serial.println("RTC was not actively running, starting now");
Rtc.SetIsRunning(true);
RtcDateTime now = Rtc.GetDateTime();
if (now < compiled)
Serial.println("RTC is older than compile time! (Updating DateTime)");
else if (now > compiled)
Serial.println("RTC is newer than compile time. (this is expected)");
else if (now == compiled)
Serial.println("RTC is the same as compile time! (not expected but all is fine)");
// never assume the Rtc was last configured by you, so
// just clear them to your needed state
Rtc.SetSquareWavePin(DS1307SquareWaveOut_Low);
void loop ()
// Common Cuases:
// 1) the battery on the device is low or even missing and the power line was disconnected
printDateTime(now);
delay(1000); // ten seconds
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt)
char datestring[20];
snprintf_P(datestring,
countof(datestring),
PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
dt.Month(),
dt.Day(),
dt.Year(),
dt.Hour(),
dt.Minute(),
dt.Second() );
Serial.print(datestring);
I expect the Arduino library to work fine for this chip. Wire works well on NodeMCU.
Do note that it's a pretty old one, so it's rated for >4.5V, and your NodeMCU operates at 3.3V. You may consider getting a more up to date RTC such as the DS3231 or an MCP7940, both of which are designed to operate at lower voltages.
By the way, a more accurate and even simpler way to get your time is NTP. Make use of that WiFi connection!
I will try with Ds3211 .
Yes Using NTP protocol we can get date & time . But i am thinking how about achieving Timezone.
Which is correct arduino compatible library for ds1307
Here is my code i used normal one. I would like to refresh page. In my code it wont do autorefresh so led remain last refresh stage. so how can make autorefresh page.other wise code working fine.
#include <ESP8266WiFi.h>
#include "DHT.h"
static int Act_date,Act_month,Act_Year,Act_Hour,Act_Min,Act_Sec;
static int Set_date=17;
static int Set_month=07;
static int Set_Year=2018;
static int Set_Hour=12;
static int Set_Min=35;
static int Set_Sec=50;
static int Set_Min2=15;
int value = LOW;
const RtcDateTime Real_date;
static float Set_Temp=30.0;
DHT dht;
const char* ssid = "esp8266";
const char* password = "Test123456";
int ledPin = 13; // GPIO13
WiFiServer server(80);
delay(10);
Rtc.Begin();
if (now < compiled)
//Serial.println("RTC is older than compile time! (Updating DateTime)");
// Serial.println("RTC is newer than compile time. (this is expected)");
// Serial.println("RTC is the same as compile time! (not expected but all is fine)");
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
dht.setup(D3); /* D1 is used for data communication */
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
// Check if a client has connected
WiFiClient client = server.available();
if (!client) {
return;
// Wait until the client sends some data
Serial.println("new client");
while(!client.available()){
delay(1);
printDateTime(now);
delay(dht.getMinimumSamplingPeriod()); /* Delay of amount equal to sampling period */
float humidity = dht.getHumidity(); /* Get humidity value */
float temperature = dht.getTemperature(); /* Get temperature value */
// Serial.print(dht.getStatusString()); /* Print status of communication */
// Read the first line of the request
String request = client.readStringUntil('\r');
Serial.println(request);
client.flush();
// Match the request
// int value = LOW;
if (request.indexOf("/LED=ON") != -1) {
digitalWrite(ledPin, HIGH);
value = HIGH;
if (request.indexOf("/LED=OFF") != -1) {
value = LOW;
// Set ledPin according to the request
//digitalWrite(ledPin, value);
// Return the response
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("
client.println("EAPL TIME SWITCH APPLICATION");
client.println("
client.println("Led pin is now: ");
if((Act_Hour==Set_Hour)&&(Act_Min<Set_Min))
value = HIGH;
}else
value = LOW;
if(value == HIGH) {
client.print("On");
client.print("Off");
/* client.println("
client.println("<a href=\"/LED=ON\"\"><button>Turn On </button></a>");
client.println("<a href=\"/LED=OFF\"\"><button>Turn Off </button></a>
client.println("</html>");
client.println("
client.println("DHT11_HumidityReading: ");
client.println(humidity,1);
client.println("
client.println("DHT11_Temprature Reading: ");
client.println(temperature,1);
client.println("
client.println("Set_Temp: ");
client.println(Set_Temp);
client.println("
client.println("Real Time Clock: ");
client.print(Act_date);client.print("/");client.print(Act_month);client.print("/");client.print(Act_Year);client.print(" ");
client.print(Act_Hour);client.print(":");client.print(Act_Min);client.print(":");client.print(Act_Sec);
client.println("
client.println("Time Switch Clock: ");
client.print(Set_date);client.print("/");client.print(Set_month);client.print("/");client.print(Set_Year);client.print(" ");
client.print(Set_Hour);client.print(":");client.print(Set_Min);client.print(":");client.print(Set_Sec);
client.println("
delay(1);
Serial.println("Client disonnected");
Serial.println("");
dt.Month(),
dt.Day(),
dt.Year(),
dt.Hour(),
dt.Minute(),
dt.Second() );
Act_month=dt.Month();
Act_date=dt.Day();
Act_Year= dt.Year();
Act_Hour=dt.Hour();
Act_Min= dt.Minute();
Act_Sec= dt.Second();
Is any one has example to get client data from texbox and save it in value.
I have gone through many web forum arduino. I could able to generate the text box and submit button. But i couldn't able to save data into parameter
Like wise I am looking for change value in above topic. If it fixed value it can be easily displayed & works well . But How to update the parametric value.
Like HTTP uses get and post . if i tried those example it work out in HTML/HTTP. Is there any way to change or set client data.
Witsie74:
Not quite, you need to adjust for local time going over 2400.
Just use UNIX timestamps (seconds since epoch). No problem. Just add/subtract the time as per timezone (in seconds) and done.
It's anyway a good idea to use UNIX timestamps for anything but where you need it human readable, as it's compact (just four bytes - unsigned long type) and easy to do calculations with (you can simply do additions and subtractions without bothering with leap years, different lengths of the months, etc).
