I have used Nodemcu from AMICA. I am facing different issue while blink. These any days code is working well without any issue. i have updated my IDE now i could not able to blink normal LED
I have simple code to blink LED . I forget about using SSID and all.
I have tested code with arduino Uno its working well, When i tested with nodemcu its now working
when i measure voltage potential it stays at 1.3v and wont change over I have different Nodemcu unit its doing same thing
If i use serial statement in between its working well. why my led is not changing state
I have used 560E resistor in Series with portpin and connected to LED to Gnd. Normal Resistor Network.
I am powering nodemcu using DC 3.3V supply.
I have also tested with USB power to blink LED. Output across Port pin and gnd remain at 1.7v
#define LED 0
pinMode(LED, OUTPUT);
digitalWrite(LED, HIGH);
digitalWrite(LED, LOW);
working
pinMode(LED_BUILTIN, OUTPUT); // Initialize the LED_BUILTIN pin as an output
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is active low on the ESP-01)
delay(1000); // Wait for a second
digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
delay(2000); // Wait for two seconds (to demonstrate the active low LED)
