Node32-W5500-MQTT Problem
Hi everyone, I have a problem with my prototype. I'd like to implement MQTT over LAN using an ESP32 and a standard W5500 Nano.
The prototype successfully acquires an IP address via DHCP, but MQTT doesn't work.
The code is very simple and minimal.
I tested the same Ethernet cable with my laptop and I can send MQTT messages without issues.
Any ideas?
#include <SPI.h>
#include <Ethernet.h>
#include <MQTT.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xAA};
EthernetClient net;
MQTTClient client;
unsigned long lastMillis = 0;
void connect() {
  Serial.print("connecting...");
  while (!client.connect("TestEsp")) {
    Serial.print(".");
  Serial.println("connected!");
  client.subscribe("/Test");
void messageReceived(String &topic, String &payload) {
  Serial.println("incoming: " + topic + " - " + payload);
  Ethernet.init(5); //CS pin
  Ethernet.begin(mac);
  Serial.print("Local IP : ");
  Serial.println(Ethernet.localIP());
  client.begin("192.168.1.66", net);
  client.onMessage(messageReceived);
  connect();
  client.loop();
  if (!client.connected()) {
    connect();
  if (millis() - lastMillis > 5000) {
    lastMillis = millis();
    client.publish("Node32s", "Test");
Off the top of my head, there are a few steps missing in the init of the ethernet and MQTT. Perhaps look at one of the samples first.
Thanks for the reply. Yes, this code is taken from an example
