hi guys, at the moment i'm working with a nodemcu 0.9 to upload data to a server and from another nodemcu fetch it, I have no problem uploading it, but i got some issues fetching it, can someone help me like giving me some comands from the library that would allow me to fetch the data i dont care how if is string, char or byte, I can do the conversion necesary
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
const char* ssid = "........";
const char* password = "........";
const char* host = "api.github.com";
const int httpsPort = 443;
// Use web browser to view and copy
// SHA1 fingerprint of the certificate
const char* fingerprint = "CF 05 98 89 CA FF 8E D8 5E 5C E0 C2 E4 F7 E6 C3 C7 50 DD 5C";
Serial.print("connecting to ");
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
// Use WiFiClientSecure class to create TLS connection
WiFiClientSecure client;
Serial.println(host);
if (!client.connect(host, httpsPort)) {
Serial.println("connection failed");
return;
if (client.verify(fingerprint, host)) {
Serial.println("certificate matches");
Serial.println("certificate doesn't match");
String url = "/repos/esp8266/Arduino/commits/master/status";
Serial.print("requesting URL: ");
Serial.println(url);
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"User-Agent: BuildFailureDetectorESP8266\r\n" +
"Connection: close\r\n\r\n");
Serial.println("request sent");
while (client.connected()) {
String line = client.readStringUntil('\n');
if (line == "\r") {
Serial.println("headers received");
if (line.startsWith("{\"state\":\"success\"")) {
Serial.println("esp8266/Arduino CI successfull!");
Serial.println("esp8266/Arduino CI has failed");
Serial.println("reply was:");
Serial.println("==========");
Serial.println(line);
Serial.println("closing connection");
HTTP:
const char* ssid = "your-ssid";
const char* password = "your-password";
const char* host = "data.sparkfun.com";
const char* streamId = "....................";
const char* privateKey = "....................";
delay(10);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
/* Explicitly set the ESP8266 to be a WiFi-client, otherwise, it by default,
would try to act as both a client and an access-point and could cause
network-issues with your other WiFi-devices on your WiFi-network. */
Serial.print(".");
Serial.println("");
int value = 0;
delay(5000);
++value;
// Use WiFiClient class to create TCP connections
WiFiClient client;
const int httpPort = 80;
if (!client.connect(host, httpPort)) {
return;
// We now create a URI for the request
String url = "/input/";
url += streamId;
url += "?private_key=";
url += privateKey;
url += "&value=";
url += value;
Serial.print("Requesting URL: ");
// This will send the request to the server
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
// Read all the lines of the reply from server and print them to Serial
while(client.available()){
String line = client.readStringUntil('\r');
Serial.print(line);
