HI,
Sorry but i'm a noob what programming concerns.
Short explanation what I'm trying to achieve:
I connected a LDR sensor to A0 on my NodeMCU
Now I want the data to be sent with MQTT to Hass.io.
I have to code which work separately, but I cant get them combined.
whatever I tried I cant get it to work.
This first part reads the voltage of the LDR
Serial.begin(9600); // initialize serial communication at 9600 BPS
int sensorValue = analogRead(A0); // read the input on analog pin 0
float voltage = sensorValue * (5.0 / 1023.0); // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V)
Serial.println(voltage); // print out the value you read
And This next code is the working MQTT code.
Basic ESP8266 MQTT example
This sketch demonstrates the capabilities of the pubsub library in combination
with the ESP8266 board/library.
It connects to an MQTT server then:
- publishes "hello world" to the topic "outTopicjerxjac" every two seconds
- subscribes to the topic "inTopic", printing out any messages
it receives. NB - it assumes the received payloads are strings not binary
- If the first character of the topic "inTopic" is an 1, switch ON the ESP Led,
else switch it off
It will reconnect to the server if the connection is lost using a blocking
reconnect function. See the 'mqtt_reconnect_nonblocking' example for how to
achieve the same result without blocking the main loop.
To install the ESP8266 board, (using Arduino 1.6.4+):
- Add the following 3rd party board manager under "File -> Preferences -> Additional Boards Manager URLs":
http://arduino.esp8266.com/stable/package_esp8266com_index.json
- Open the "Tools -> Board -> Board Manager" and click install for the ESP8266"
- Select your ESP8266 in "Tools -> Board"
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
const char* ssid = "XXXX";
const char* password = "XXXX";
const char* mqtt_server = "test.mosquitto.org";
WiFiClient espClient;
PubSubClient client(espClient);
unsigned long lastMsg = 0;
#define MSG_BUFFER_SIZE (50)
char msg[MSG_BUFFER_SIZE];
int value = 0;
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print(".");
randomSeed(micros());
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
// Switch on the LED if an 1 was received as first character
if ((char)payload[0] == '1') {
digitalWrite(BUILTIN_LED, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is active low on the ESP-01)
digitalWrite(BUILTIN_LED, HIGH); // Turn the LED off by making the voltage HIGH
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Create a random client ID
String clientId = "ESP8266Client-";
clientId += String(random(0xffff), HEX);
// Attempt to connect
if (client.connect(clientId.c_str())) {
Serial.println("connected");
// Once connected, publish an announcement...
client.publish("outTopicJX", "hello world");
// ... and resubscribe
client.subscribe("inTopic");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
pinMode(BUILTIN_LED, OUTPUT); // Initialize the BUILTIN_LED pin as an output
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
if (!client.connected()) {
reconnect();
client.loop();
unsigned long now = millis();
if (now - lastMsg > 2000) {
lastMsg = now;
++value;
snprintf (msg, MSG_BUFFER_SIZE, "hello world #%ld", value);
Serial.print("Publish message: ");
Serial.println(msg);
client.publish("outTopicJX", msg);
Can someone help to combine these two codes so the Voltage is published by the MQTT?
I tried to add part of the code to the last void loop()
I added in the begin
and added to the end,
client.publish("outTopicjerxjac", voltage);
But that gives a error when uploading [redefinition of 'void loop()']
reconnect();
client.loop();
lastMsg = now;
++value;
snprintf (msg, MSG_BUFFER_SIZE, "hello world_2 #%ld", value);
client.publish("outTopicjerxjac", msg);
I don't care what worked individually, post what you tried - not small snips of the code. Post ALL of it.
" I cant get it to work." is equally useless. What errors are you getting? If you post ALL of your code, some of us may try to compile it also.
For me it was important to know that the two individually codes worked, that was my starting point.
Here the complete code:
Hope for someone willing to help.
- publishes "hello world" to the topic "outTopicJX" every two seconds
else switch it off
const char* password = "XXXXXX";
int value = 0;
void setup_wifi() {
delay(10);
Serial.print(".");
Serial.println("");
Serial.print("] ");
void reconnect() {
delay(5000);
setup_wifi();
reconnect();
client.loop();
lastMsg = now;
++value;
client.publish("outTopicJX", voltage);
Does this part of the combined code work ?
It is publishing a string
This part, however, is publishing a float
How are you reading what you publish ?
I assume this is what reads what is to be published.
The code gives an error on the float,
I just need the data from Voltage, the msg value I don't have to keep in the code.....
This is like pulling teeth
Please post the full error message
Here are the function prototypes for the publish() function
boolean publish(const char* topic, const char* payload);
boolean publish(const char* topic, const char* payload, boolean retained);
boolean publish(const char* topic, const uint8_t * payload, unsigned int plength);
boolean publish(const char* topic, const uint8_t * payload, unsigned int plength, boolean retained);
boolean publish_P(const char* topic, const char* payload, boolean retained);
boolean publish_P(const char* topic, const uint8_t * payload, unsigned int plength, boolean retained);
None of them take a float as a parameter
Convert your float using dtostrf() to and I suspect that you will be able to send it
When I asked how you were reading what you publish I had in mind how you know what has been published rather than where you read the value from
This is what I have now,
I tried the suggested Convert float using dtostrf()
No errors when compiling, but doesn't keep the connection to MQTT
else switch it off
const char* ssid = "XXXXX";
const char* password = "XXXXXXXXXX";
int value = 0;
void setup_wifi() {
delay(10);
Serial.print(".");
Serial.println("");
Serial.print("] ");
void reconnect() {
delay(5000);
setup_wifi();
reconnect();
client.loop();
static char outstr[15];
dtostrf(voltage,5,1,outstr);
lastMsg = now;
++value;
// snprintf (msg, MSG_BUFFER_SIZE, "hello world #%ld", value);
// Serial.println(msg);
// client.publish("outTopicJX", msg);
client.publish("outTopicJX", outstr);
Serial monitor:
Attempting MQTT connection...failed, rc=-2 try again in 5 seconds
Attempting MQTT connection...connected
Publish message: 3.59
Publish message: 3.58
I don't see anything obviously wrong. Can you try another broker? Preferably one on your local network.
I don't see anything at the mosquitto page that gives any limits, but it might be worth trying with less frequent publishing.
Hi wildbill,
On my own local broker, (mosquito) I have the same problem.
(Attempting MQTT connection...failed, rc=-2 try again in 5 seconds)
When I comment out these lines, It stays connected,.. but a result is published every half second or so.
// if (now - lastMsg > 2000) {
// lastMsg = now;
// ++value;
I am not sure whether this will affect anything, but
will be turned into
char msg[(50)];
and
snprintf (msg, (50), "hello world #%ld", value);
by the pre-processor
You certainly don't need the brackets around the 50
