NodeMCU arduino IDE blink example doesn't work
Hi
I have a nodeMCU module and I run the code below but it doesn't work.
I connect my LED to D4 pin and GND.
#define LED_Pin 4
  pinMode(LED_Pin, OUTPUT);
  digitalWrite(LED_Pin, LOW);
  digitalWrite(LED_Pin, HIGH);
  delay(2000);
You need a resistor in seriese with the LED, you might have damaged the output pin by not fitting one. Try using a 220R resistor and another pin.
Oh
Ok thanks
I will check it withh 220R resistor
