I bought a few of these boards.
I got one out and it is working. I won't jinx myself by trying to program it now.
But it has been used/flashed recently. All works.
The other day I got another new one out of its bag and tried to upload a program and it failed.
I noticed I had another one "opened" near by so I tried it. Same thing.
This is what I have set for the board type:
NodeMCU 1.0 (ESP-12E)
80MhZ 4M 1M SPIFFS
115200 dev.tty/USB0
I have that "magic line" in the preferences:
http://arduino.esp8266.com/stable/package_esp8266com_index.json
It used to work.
When I try to upload a sketch - BLINK even - it gives this error:
Arduino: 1.8.9 (Linux), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Sketch uses 257672 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 26572 bytes (32%) of dynamic memory, leaving 55348 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.6
2.6
esptool.py v2.6
Serial port /dev/ttyUSB0
Connecting....
Traceback (most recent call last):
Chip is ESP8266EX
Features: WiFi
MAC: 5c:cf:7f:6f:f0:9f
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
File "/home/me/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/upload.py", line 25, in <module>
esptool.main(fakeargs)
File "/home/me/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool/esptool.py", line 2694, in main
detect_flash_size(esp, args)
File "/home/me/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool/esptool.py", line 2073, in detect_flash_size
flash_id = esp.flash_id()
File "/home/me/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool/esptool.py", line 567, in flash_id
return self.run_spiflash_command(SPIFLASH_RDID, b"", 24)
File "/home/me/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool/esptool.py", line 812, in run_spiflash_command
old_spi_usr = self.read_reg(SPI_USR_REG)
File "/home/me/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool/esptool.py", line 475, in read_reg
val, data = self.command(self.ESP_READ_REG, struct.pack('<I', addr))
File "/home/me/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool/esptool.py", line 332, in command
p = self.read()
File "/home/me/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool/esptool.py", line 277, in read
return next(self._slip_reader)
File "/home/me/.arduino15/packages/esp8266/hardware/esp8266/2.5.2/tools/esptool/esptool.py", line 1877, in slip_reader
raise FatalError("Timed out waiting for packet %s" % waiting_for)
esptool.FatalError: Timed out waiting for packet header
option enabled in File -> Preferences.
I am not going to try the working board, as it is working.
But I have tried TWO boards. One "used" (I may have flashed it with a sketch for testing or something) and one "brand new out of the box" where I opened the anti-static bag.
