Nodemcu coingecko lookup + Wifi Manager Merged Code not working
I am using a Nodemcu (8266) to lookup a crypto price via coingecko's api while maintaining a connection with Wifi Manager.
I have the below coded working for Wifi Manager and I also have the below code working for coingecko lookups.
My problem is when I merge them together I get error "Error compiling for Generic ESP8266 Module." which does not happen individually...
Can anyone help as my programing skills are lacking to identify the cause of the problem...
Thanks
Working Wifi Manager Code
  Rui Santos
  Complete project details at http://randomnerdtutorials.com
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>         // https://github.com/tzapu/WiFiManager
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the current output state
String output5State = "off";
String output4State = "off";
// Assign output variables to GPIO pins
const int output5 = 5;
const int output4 = 4;
  // Initialize the output variables as outputs
  pinMode(output5, OUTPUT);
  pinMode(output4, OUTPUT);
  // Set outputs to LOW
  digitalWrite(output5, LOW);
  digitalWrite(output4, LOW);
  // WiFiManager
  // Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  // Uncomment and run it once, if you want to erase all the stored information
  //wifiManager.resetSettings();
  // set custom ip for portal
  //wifiManager.setAPConfig(IPAddress(10,0,1,1), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
  // fetches ssid and pass from eeprom and tries to connect
  // if it does not connect it starts an access point with the specified name
  // here  "AutoConnectAP"
  // and goes into a blocking loop awaiting configuration
  wifiManager.autoConnect("Bazooka");
  // wifiManager.autoConnect("AutoConnectAP");
  // or use this for auto generated name ESP + ChipID
  //wifiManager.autoConnect();
  // if you get here you have connected to the WiFi
  Serial.println("Connected.");
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    Serial.println("New Client.");          // print a message out in the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        header += c;
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println("Connection: close");
            client.println();
            // turns the GPIOs on and off
            if (header.indexOf("GET /5/on") >= 0) {
              Serial.println("GPIO 5 on");
              output5State = "on";
              digitalWrite(output5, HIGH);
            } else if (header.indexOf("GET /5/off") >= 0) {
              Serial.println("GPIO 5 off");
            } else if (header.indexOf("GET /4/on") >= 0) {
              Serial.println("GPIO 4 on");
              output4State = "on";
              digitalWrite(output4, HIGH);
            } else if (header.indexOf("GET /4/off") >= 0) {
              Serial.println("GPIO 4 off");
            // Display the HTML web page
            client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            // CSS to style the on/off buttons
            // Feel free to change the background-color and font-size attributes to fit your preferences
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            client.println(".button2 {background-color: #77878A;}</style></head>");
            // Web Page Heading
            client.println("<body><h1>ESP8266 Web Server</h1>");
            // Display current state, and ON/OFF buttons for GPIO 5
            client.println("<p>GPIO 5 - State " + output5State + "</p>");
            // If the output5State is off, it displays the ON button
            if (output5State=="off") {
              client.println("<p><a href=\"/5/on\"><button class=\"button\">ON</button></a></p>");
              client.println("<p><a href=\"/5/off\"><button class=\"button button2\">OFF</button></a></p>");
            // Display current state, and ON/OFF buttons for GPIO 4
            client.println("<p>GPIO 4 - State " + output4State + "</p>");
            // If the output4State is off, it displays the ON button
            if (output4State=="off") {
              client.println("<p><a href=\"/4/on\"><button class=\"button\">ON</button></a></p>");
              client.println("<p><a href=\"/4/off\"><button class=\"button button2\">OFF</button></a></p>");
            client.println("</body></html>");
            // The HTTP response ends with another blank line
            client.println();
            // Break out of the while loop
          } else { // if you got a newline, then clear currentLine
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("Client disconnected.");
    Serial.println("");
Working Coingecko Lookup Code (Works by itself)
#include <ESP8266HTTPClient.h>
const char* ssid = "......";
const char* password = ".....";
void setup () {
  WiFi.begin(ssid, password);
    Serial.print("Connecting..");
  if (WiFi.status() == WL_CONNECTED) { //Check WiFi connection status
    HTTPClient http;  //Declare an object of class HTTPClient
    http.begin("https://api.coingecko.com/api/v3/simple/price?ids=star-atlas&vs_currencies=usd");  //Specify request destination
    int httpCode = http.GET();     //Send the request
    if (httpCode > 0) { //Check the returning code
      String payload = http.getString();   //Get the request response payload
      Serial.println(payload);                     //Print the response payload
    http.end();   //Close connection
  delay(30000);    //Send a request every 30 seconds
Merged Code (Not working)
  Rui Santos
String header;
  // WiFiManager
  server.begin();
void loop(){
        header += c;
            client.println();
            // Web Page Heading
            client.println();
            currentLine = "";
    header = "";
    client.stop();
    Serial.println("");
You get a lot more than
Why not copy and share the entire error output. On the IDE, there is even a handy little button near the bottom right "Copy error message"
Yes, I should have included that, see below...
`Arduino: 1.8.8 (Windows 7), Board: "Generic ESP8266 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Build options changed, rebuilding all
In file included from C:\Users\Owner\Documents\Arduino\libraries\WiFi101\src/common/include/nm_common.h:45:0,
                 from C:\Users\Owner\Documents\Arduino\libraries\WiFi101\src/socket/include/socket.h:60,
                 from C:\Users\Owner\Documents\Arduino\libraries\WiFi101\src/socket/include/socket_buffer.h:45,
                 from C:\Users\Owner\Documents\Arduino\libraries\WiFi101\src/WiFiClient.h:26,
                 from C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:36,
                 from C:\Users\Owner\Documents\Arduino\crypto-ticker-v1\crypto-ticker-v1.ino:6:
C:\Users\Owner\Documents\Arduino\libraries\WiFi101\src/bsp/include/nm_bsp.h:110:23: error: conflicting declaration 'typedef long unsigned int uint32'
 typedef unsigned long uint32;
In file included from C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\cores\esp8266/esp8266_peri.h:24:0,
                 from C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\cores\esp8266/Arduino.h:38,
                 from sketch\crypto-ticker-v1.ino.cpp:1:
C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2/tools/sdk/include/c_types.h:49:29: error: 'uint32' has a previous declaration as 'typedef unsigned int uint32'
 typedef unsigned int        uint32;
C:\Users\Owner\Documents\Arduino\libraries\WiFi101\src/bsp/include/nm_bsp.h:133:22: error: conflicting declaration 'typedef long int sint32'
 typedef signed long  sint32;
C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2/tools/sdk/include/c_types.h:52:29: error: 'sint32' has a previous declaration as 'typedef int sint32'
 typedef signed int          sint32;
In file included from C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
                 from C:\Users\Owner\Documents\Arduino\crypto-ticker-v1\crypto-ticker-v1.ino:7:
C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClient.h:45:7: error: redefinition of 'class WiFiClient'
 class WiFiClient : public Client, public SList<WiFiClient> {
In file included from C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:36:0,
C:\Users\Owner\Documents\Arduino\libraries\WiFi101\src/WiFiClient.h:28:7: error: previous definition of 'class WiFiClient'
 class WiFiClient : public Client {
In file included from C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClientSecure.h:41:0,
                 from C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiServerSecure.h:20,
                 from C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/ESP8266WiFi.h:41,
C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:38:5: error: 'BearSSL::WiFiClientSecure::~WiFiClientSecure()' marked override, but does not override
     ~WiFiClientSecure() override;
C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:43:9: error: 'int BearSSL::WiFiClientSecure::connect(const String&, uint16_t)' marked override, but does not override
     int connect(const String& host, uint16_t port) override;
C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:48:12: error: 'size_t BearSSL::WiFiClientSecure::write_P(const char*, size_t)' marked override, but does not override
     size_t write_P(PGM_P buf, size_t size) override;
C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:60:12: error: 'size_t BearSSL::WiFiClientSecure::peekBytes(uint8_t*, size_t)' marked override, but does not override
     size_t peekBytes(uint8_t *buffer, size_t length) override;
Multiple libraries were found for "WiFiClient.h"
 Used: C:\Users\Owner\Documents\Arduino\libraries\WiFi101
 Not used: C:\Users\Owner\Documents\Arduino\libraries\WiFi
 Not used: C:\Users\Owner\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi
 Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
exit status 1
Error compiling for board Generic ESP8266 Module.
option enabled in File -> Preferences.
I can not reproduce that error. What board are you compiling for? I chose NodeMCU 1.0
Do you have other files in your sketch folder? It looks like multiple things are being included which leads to the multiple def errors.
I tried compiling on another pc and yes it compiles and uploads so must be something else clashing, thanks for your help.
One last question...
It now uploads and connects fine to my wifi but it doesnt display the payload on the serial monitor, do I have that bit of code in the wrong place?
Investigating a bit further I find its returning -1 as the HttpCode from the Get which means no connection however Wifi manager is connected...
Sorry, I don't know. That URL works just fine in my browser. Have you tried other sites like google.com just to see if you can reach them?
Yes, doesnt bring in any data.
Thats ok, thanks for your help, I think its more a case of getting wifi manager into the right mode, I will make a new post more specific to this problem.
