NodeMCU crashes while Json Parsing
Hello,
I'm trying to run a sketch for a LED Matrix Display on my NodeMCU.
Most parts - also the Wifi connections - are working fine; but the following function "void displayWeatherData()" causes a loop and crashes the ESP.
void displayWeatherData() {
  if (ow_APIKEY == "")
    return;
  static bool ow_current = true;
  String url;
  String result;
  WiFiClient client;
  if (!client.connect(ow_servername, ow_port))
    return;
  String cityID = ow_cityIDs[ow_cityIDLoop];
  if (ow_current)                               // get current weather check weather properties at https://openweathermap.org/current
    url = "/data/2.5/weather?id=";
  else                                          // get forecast check properties forecasts at https://openweathermap.org/forecast5
    url = "/data/2.5/forecast?id=";
  url = url + cityID + "&units=metric&cnt=1&lang=" + ow_language + "&APPID=" + ow_APIKEY;
  client.print(String("GET ") + url + " HTTP/1.1\r\n" + "Host: " + ow_servername + "\r\n" + "Connection: close\r\n\r\n");
#ifdef DEBUG
  Serial.println(url);
#endif
  unsigned long timeout = millis();
  while (client.available() == 0) {
    if (millis() - timeout > 1000) {
      client.stop();
      return;
  result = "";
  while (client.available())
    result = client.readStringUntil('\r');
  client.stop();
  if (!ow_current) {
    result.replace('[', ' ');
    result.replace(']', ' ');
#ifdef DEBUG
  Serial.println(result);
#endif
  delay(50);
  char jsonArray [result.length() + 1];
  result.toCharArray(jsonArray, sizeof(jsonArray));
  jsonArray[result.length() + 1] = '\0';
  StaticJsonBuffer<1024> json_buf;
  JsonObject &root = json_buf.parseObject(jsonArray);
  if (!root.success())
    strcpy(pd_message2, msgOpenweatherFailed);
  else {
    if (ow_current) {
      String wcit = root["name"];
      String wdes = root["weather"][0]["description"];
      float  wtem = root["main"]["temp"];
      float  whum = root["main"]["humidity"];
      float  wclo = root["clouds"]["all"];
      float  wrai = root["rain"]["3h"];
      float  wwsp = root["wind"]["speed"];
      int    wwde = root["wind"]["deg"];
      snprintf(pd_message2, sizeof(pd_message2), "%s %s : %s, %s %2.1f %c  %s %3.0f%%  %s %3.0f%%  %s %3.1f mm  %s %2.0f m/s %s",
        msgCurrentWeather, wcit.c_str(), wdes.c_str(), msgTemp, wtem, degCascii, msgHumidity, whum, msgClouds, wclo, msgRain, wrai, msgWind, wwsp, getWindDirection(wwde).c_str());
      String wcit = root["city"]["name"];
      String wdes = root["list"]["weather"]["description"];
      float  wtmi = root["list"]["main"]["temp_min"];
      float  wtma = root["list"]["main"]["temp_max"];
      float  whum = root["list"]["main"]["humidity"];
      float  wclo = root["list"]["clouds"]["all"];
      float  wrai = root["list"]["rain"]["3h"];
      float  wwsp = root["list"]["wind"]["speed"];
      int    wwde = root["list"]["wind"]["deg"];
      snprintf(pd_message2, sizeof(pd_message2), "%s %s : %s, %s %2.1f %c - %2.1f %c  %s %3.0f%%  %s %3.0f%%  %s %3.1f mm  %s %2.0f m/s %s",
        msgForecast, wcit.c_str(), wdes.c_str(), msgTemp, wtmi, degCascii, wtma, degCascii, msgHumidity, whum, msgClouds, wclo, msgRain, wrai, msgWind, wwsp, getWindDirection(wwde).c_str());
#ifdef DEBUG
  Serial.println(pd_message2);
#endif
  ow_cityIDLoop = (++ow_cityIDLoop) % FN_ARRAY_SIZE(ow_cityIDs);
  if (ow_cityIDLoop == 0)                       // after a loop of all cities, toggle between current weather/forecasts
    ow_current = !ow_current;
I think i figured out the problem occurs when parsing data with Json starts.
The connection to the host is established, I get a response, but this process of connecting and responding repeats until the device crashes and restarts.
Exception message is (28). Using the ESP-Detection decoder, I get the follwing result:
Exception 28: LoadProhibited: A load referenced a page mapped with an attribute that does not permit loads
Decoding 46 results
0x4021f996: ets_vsnprintf at ?? line ?
0x401073a8: snprintf at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/libc_replacements.c line 342
0x40203b4d: displayWeatherData() at C:\Users\Isabel\Documents\Arduino\Test und Beispielprogramme\Parola Displays\Test_ES-Mix/Test_ES-Mix.ino line 601
0x40101e3a: pp_post at ?? line ?
0x40105117: lmacRxDone at ?? line ?
0x40102b4d: trc_NeedRTS at ?? line ?
0x40102cdc: trc_NeedRTS at ?? line ?
0x4010311a: wDev_ProcessFiq at ?? line ?
0x40102eb4: wDev_ProcessFiq at ?? line ?
0x402139b7: ieee80211_send_nulldata at ?? line ?
0x4021319b: ieee80211_output_pbuf at ?? line ?
0x4020c18e: pp_attach at ?? line ?
0x4020c29a: pp_attach at ?? line ?
0x4020b5df: ppTxPkt at ?? line ?
0x4021334c: ieee80211_output_pbuf at ?? line ?
0x4020c13b: pp_attach at ?? line ?
0x4022ae4a: etharp_query at /Users/igrokhotkov/espressif/arduino/tools/sdk/lwip/src/netif/etharp.c line 1139
0x4022aa5c: etharp_send_ip at /Users/igrokhotkov/espressif/arduino/tools/sdk/lwip/src/netif/etharp.c line 435
0x4022afbd: etharp_output at /Users/igrokhotkov/espressif/arduino/tools/sdk/lwip/src/netif/etharp.c line 999
0x402153e2: scan_pm_channel_op_cb at ?? line ?
0x40215349: scan_start at ?? line ?
0x4022ad41: etharp_output_to_arp_index at /Users/igrokhotkov/espressif/arduino/tools/sdk/lwip/src/netif/etharp.c line 890
0x4021587c: scan_clear_channles at ?? line ?
0x4010053d: _umm_realloc at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc/umm_malloc.c line 1491
:  (inlined by) realloc at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc/umm_malloc.c line 1709
0x4022bef0: ip_output_if_opt at /Users/igrokhotkov/espressif/arduino/tools/sdk/lwip/src/core/ipv4/ip.c line 780
0x40208fab: String::reserve(unsigned int) at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.cpp line 623
0x40208f5c: String::changeBuffer(unsigned int) at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.cpp line 623
0x4010020c: _umm_free at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc/umm_malloc.c line 1287
0x4010068c: free at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc/umm_malloc.c line 1733
0x4021fa06: ets_vsprintf at ?? line ?
0x40208efc: String::~String() at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.cpp line 623
0x40202344: displayDateShort() at C:\Users\Isabel\Documents\Arduino\Test und Beispielprogramme\Parola Displays\Test_ES-Mix/Test_ES-Mix.ino line 505
0x40203e04: loop at C:\Users\Isabel\Documents\Arduino\Test und Beispielprogramme\Parola Displays\Test_ES-Mix/Test_ES-Mix.ino line 685
0x402093fc: loop_wrapper at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/core_esp8266_main.cpp line 56
0x40100718: cont_norm at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/cont.S line 109
I'm far from being an expert and so I don't know how to understand the exception messages correctly. And I have no idea what could cause the loop in this function.
I have spent many many hours on this issue - without success; so any help would be much appreciated!
Through initial google searches, this exception is caused either by referencing invalid memory location or failing to allocate the requested memory.
Try to print out "ow_cityIDLoop" to verify valid value.
Maybe the size of your json buffer is too small :
If (as I guess) you use the arduinojson library, then you should try the assistant which will give you the best parameter set
This writes past the end of the array, which will crash an ESP.
I think that third line should be just:
jsonArray[result.length()] = '\0';
Thank you!
"ow_ cityIDLoop" works fine. I think the error occurs later.
Yes, I use the Json Lib. I' ll try it with the assistant an will report.
The strange thing is: This code should be ok, it's taken from a well running Esp32 project I found in the web.
I see no reason, why it shouldn't work on my Esp8266. As said before, all other WiFi functions run fine.
GypsumFantastic:
Thank you.
I tried your code, but the device crashes anyway.
The really strange thing is: I get another Error Message (No.3), even if I retry it with my code version.
Exception Decoder shows:
Exception 3: LoadStoreError: Processor internal physical address or data error during load or store
Decoding 37 results
0x4021f9bf: ets_vsnprintf at ?? line ?
0x4021f9a6: ets_vsnprintf at ?? line ?
0x40203b5d: displayWeatherData() at C:\Users\Isabel\Documents\Arduino\Test und Beispielprogramme\Parola Displays\Test_ES-Mix/Test_ES-Mix.ino line 601
0x4020c19e: pp_attach at ?? line ?
0x4020c2aa: pp_attach at ?? line ?
0x4020b5ef: ppTxPkt at ?? line ?
0x4021335c: ieee80211_output_pbuf at ?? line ?
0x4022ae5a: etharp_query at /Users/igrokhotkov/espressif/arduino/tools/sdk/lwip/src/netif/etharp.c line 1139
0x4022aa6c: etharp_send_ip at /Users/igrokhotkov/espressif/arduino/tools/sdk/lwip/src/netif/etharp.c line 435
0x4022afcd: etharp_output at /Users/igrokhotkov/espressif/arduino/tools/sdk/lwip/src/netif/etharp.c line 999
0x402153f2: scan_pm_channel_op_cb at ?? line ?
0x40215359: scan_start at ?? line ?
0x4022ad51: etharp_output_to_arp_index at /Users/igrokhotkov/espressif/arduino/tools/sdk/lwip/src/netif/etharp.c line 890
0x4021588c: scan_clear_channles at ?? line ?
0x4022bf00: ip_output_if_opt at /Users/igrokhotkov/espressif/arduino/tools/sdk/lwip/src/core/ipv4/ip.c line 780
0x40208fbb: String::reserve(unsigned int) at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.cpp line 623
0x40208f6c: String::changeBuffer(unsigned int) at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.cpp line 623
0x4021fa16: ets_vsprintf at ?? line ?
0x40208f0c: String::~String() at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.cpp line 623
0x40203e14: loop at C:\Users\Isabel\Documents\Arduino\Test und Beispielprogramme\Parola Displays\Test_ES-Mix/Test_ES-Mix.ino line 685
0x4020940c: loop_wrapper at C:\Users\Isabel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/core_esp8266_main.cpp line 56
The last thing the serial monitor shows before crashing is:
{"coord":{"lon":8.33,"lat":48.8},"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04d"}],"base":"stations","main":{"temp":10.88,"pressure":1021,"humidity":76,"temp_min":8.33,"temp_max":13},"visibility":10000,"wind":{"speed":3.1,"deg":230},"clouds":{"all":75},"dt":1570096836,"sys":{"type":1,"id":1314,"message":0.0071,"country":"DE","sunrise":1570080496,"sunset":1570122193},"timezone":7200,"id":2923362,"name":"Gaggenau","cod":200}
You are making it hard to spot the error since the code is partial and some declarations are missing. Your issue may be that your are accessing a JSON object / field which does not exist.
1: float  wtma = root["list"]["main"]["temp_max"]
2: snprintf(pd_message2, ..);
  1. If "root.list.main.temp_max" does not exist, you will cause an error.
  2. Where is "pd_message2" declared and is it large enough to hold the result?
You should also mind the answer in #3 since the answer fixes a bug for you.
const char BUFLEN = 10;
char buf[BUFLEN + 1]; //Size = 11, valid indicies = 0..10
buf[BUFLEN + 1] = 0; //Access element 11 = out of bounds!
Finally I got it running.
I had made a mistake outside of this function and - obviously - wasn't able any more to recognize this after having spent hours and hours in front of my laptop. I paused my project for some days - and found the wrong code after that...
Thanks to all for their friendly help!
