NodeMCU DFplayer bootloop
When I try to launch the DFplayer demo Script on my NodeMCU, I get a Bootloop with the following log.
I worked before so I can’t really understand why it doesn’t work now. There is nothing attached to the NodeMCUs pins exept for USB and 5V power supply.
DFPlayer - A Mini MP3 Player For Arduino
 <https://www.dfrobot.com/index.php?route=product/product&product_id=1121>
 This example shows the basic function of library for DFPlayer.
 Created 2016-12-07
 By [Angelo qiao](Angelo.qiao@dfrobot.com)
 GNU Lesser General Public License.
 See <http://www.gnu.org/licenses/> for details.
 All above must be included in any redistribution
/***********Notice and Trouble shooting***************
 1.Connection and Diagram can be found here
 <https://www.dfrobot.com/wiki/index.php/DFPlayer_Mini_SKU:DFR0299#Connection_Diagram>
 2.This code is tested on Arduino Uno, Leonardo, Mega boards.
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
  mySoftwareSerial.begin(9600);
  Serial.println(F("DFRobot DFPlayer Mini Demo"));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
  if (!myDFPlayer.begin(mySoftwareSerial)) {  //Use softwareSerial to communicate with mp3.
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    while(true);
  Serial.println(F("DFPlayer Mini online."));
  myDFPlayer.volume(10);  //Set volume value. From 0 to 30
  myDFPlayer.play(1);  //Play the first mp3
  static unsigned long timer = millis();
  if (millis() - timer > 3000) {
    timer = millis();
    myDFPlayer.next();  //Play next mp3 every 3 second.
  if (myDFPlayer.available()) {
    printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
void printDetail(uint8_t type, int value){
  switch (type) {
    case TimeOut:
      Serial.println(F("Time Out!"));
    case WrongStack:
      Serial.println(F("Stack Wrong!"));
    case DFPlayerCardInserted:
      Serial.println(F("Card Inserted!"));
    case DFPlayerCardRemoved:
      Serial.println(F("Card Removed!"));
    case DFPlayerCardOnline:
      Serial.println(F("Card Online!"));
    case DFPlayerPlayFinished:
      Serial.print(F("Number:"));
      Serial.print(value);
      Serial.println(F(" Play Finished!"));
    case DFPlayerError:
      Serial.print(F("DFPlayerError:"));
      switch (value) {
        case Busy:
          Serial.println(F("Card not found"));
        case Sleeping:
          Serial.println(F("Sleeping"));
        case SerialWrongStack:
          Serial.println(F("Get Wrong Stack"));
        case CheckSumNotMatch:
          Serial.println(F("Check Sum Not Match"));
        case FileIndexOut:
          Serial.println(F("File Index Out of Bound"));
        case FileMismatch:
          Serial.println(F("Cannot Find File"));
        case Advertise:
          Serial.println(F("In Advertise"));
        default:
    default:
The output in Serial Monitor at 115200 Baud:
Soft WDT reset
ctx: cont
sp: 3ffef520 end: 3ffef750 offset: 01b0
>>>stack>>>
3ffef6d0:  00000bb8 00000001 3ffee4f0 4020235a
3ffef6e0:  3ffee518 00000030 3ffee4f0 402022e8
3ffef6f0:  3ffe8688 00000000 3ffee4f0 3ffee71c
3ffef700:  00000bb8 00000001 3ffee4f0 402023dc
3ffef710:  3ffee518 00000000 3ffee4f0 40202481
3ffef720:  3ffee518 3ffee4f0 3ffee668 40201c55
3ffef730:  3fffdad0 00000000 3ffee714 40202b5c
3ffef740:  feefeffe feefeffe 3ffee730 40100718
<<<stack<<<
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v09f0c112
~ld
Anyone got an Idea how to fix this?
LG Chris
The library for the DF Player has some issues with Nodemcu. The Nodemcu watch dog timer doesn't like blocking loops. I got through the same issue you show by altering the library (library/DFRobotDFPlayerMini/DFRobotDFPlayerMini.cpp) and adding "yield();" immediately after the while loop in the DFRobotDFPlayerMini::available() function. I am still having another unrelated issue, though.
