nodemcu digital pins are 3.3v or 5v
Hi all
This nodemcu have 3.3 or 5v input/output digital pins?
Many thanks in advance
They're 3.3 V. The analog input on the ESP8266 can only measure 0-1.0 V but some ESP8266 boards have a voltage divider on that pin to allow it to measure 0-3.3 V. I don't remember whether the NodeMcu board does that or not, so you will want to check that if you are using the A0 pin.
What are you doing? I already answered you the first time you asked:
@tao13, do not cross-post. Threads merged.
tao13:
No, you don't have a choice. It's 3.3V. Connecting 5V will destroy those pins, and possibly the whole board with it.
pert:
NodeMCU does have a voltage divider on the analog input - this means not only does it measure 0-3.3V, it has a severely reduced input impedance (the value of those resistors, instead of the input impedance of the analog input itself) which may affect readings.
