NodeMCU doesn't publish to MQTT
Trying to get NodeMCU to publish MQTT to the broker. Any suggestions would be appreciated. Here is my code:
//#include <ArduinoOTA.h>
// This sketch is for a NodeMCU 8266 board with a DHT22 sensor
// The sensor values are read and then sent using MQTT
// The original code sent the data to a server
// on a Raspberry Pi running OpenHAB
// This code permits OTA (over the air) reflashing of the 8266
// Originally uploaded February 21, 2019
// This code is for the indoor sensor 192.168.50.49
// This code doesn't compile so I removed the ArduinoOTA by commenting it out
// This is set up to try the new MQTT server at .168 rather than the OpenHAB server
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WifiUdp.h>
#include <DHT.h>
#include <PubSubClient.h>
// #include <ArduinoOTA.h>
/******WiFi and MQTT Information (change as needed)**********/
#define wifi_ssid "gaspc1"
#define wifi_password "1020304050"
#define mqtt_server "192.168.50.168"          // This is the IP address of the MQTT Server or Broker
#define mqtt_user "chippewa"
#define mqtt_password "8952"
#define mqtt_port 1883
/******Set the MQTT Packet size to one large enough to work***********/
#define MQTT_MAX_Packet_Size 512
//#define indoor_temp_topic "IndoorTemp"
//#define indoor_humidity_topic "IndoorHumidity"
/******Define sensor type and dati pin************/
DHT dht(D7,DHT22);
/******Needed for WiFi and MQTT************/
WiFiClient espClient;
PubSubClient client(espClient);
/******Declare Variables***************/
float PoolIndoorTemp;
float PoolIndoorHumidity;
int IndoorTempAdjustment = 0;   //used to calibrate sensor
int IndoorHumidityAdjustment = 0;
int PoolIndoorTempSetPoint = 70;
int PoolIndoorTempBuffer = 2;
int PoolIndoorHumiditySetPoint = 5;
int PoolIndoorHumidityBuffer = 2;     // to separate on and off by the nubmer of degrees
                                      // to prevent short cycling
char message_buff[100];
unsigned long interval=2000;  //The wait time
unsigned long previousMillis=0;  //millis() returns and unsigned long
/******The beginning of the actual code ***********/
/******OTA Update****************/
  setup_wifi();
  client.setServer(mqtt_server,mqtt_port);
  client.setCallback(callback);
void callback(char* topic, byte* payload, unsigned int length)
  Serial.print("Message arrived [");
  Serial.print(topic);
  int i=0;
  for (i=0;i<length;i++)
    Serial.print((char)payload[i]);
    message_buff[i] = payload[i];
  message_buff[i] = '\0';
  String msgString = String(message_buff);
 // if (msgString.equals("OFF"))
 //   client.publish("openhab/himitsu/command","acknowledging OFF");
 // else if(msgString.equals("ON"))
 //   client.publish("openhab/himitsu/command","acknowledging ON");
/******WiFi Setup ***************/
void setup_wifi()
  delay(10);
  Serial.print("connecting to wifi");
  Serial.println(wifi_ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(wifi_ssid, wifi_password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print("connecting to wifir");
  Serial.println("");
  Serial.println("WiFi Connected");
  Serial.println("IP Address: ");
/******OTA setup Stuff************/
// ArduinoOTA.onStart([]()
//  String type;
//  if(ArduinoOTA.getCommand()==U_FLASH)
//  type = "sketch";
//  else                //U_SPIFFS
//  type = "filesystem";
                      // If updating SPIFFS this is hte place to umount SPIFFS using SPIFFS.end()
//  Serial.println("Start updating " +type);
// ArduinoOTA.onEnd([]()
//  Serial.println("\nEnd");
// ArduinoOTA.onProgress([](unsigned int progress, unsigned int total){
//  Serial.printf("Progress: %u%%\r",(progress / (total / 100)));
// ArduinoOTA.onError([](ota_error_t error){
//  Serial.printf("Error[%u]: ",error);
//  if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
//  else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
//  else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
//  else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
//  else if (error == OTA_END_ERROR) Serial.println("End Failed");
//ArduinoOTA.begin();
//Serial.println("Ready");
//Serial.print("IP Address: ");
//Serial.println(WiFi.localIP());
/******Actual Program begins here ****************/
/******First step is to check for OTA updates**********/
//ArduinoOTA.handle();
/******Timer to slow things down******/
if((unsigned long)(currentMillis - previousMillis)>= interval)
  previousMillis = millis();  //save current time
                              // the closing brace is at the end of all code
/******check for sensor reading errors and pring them******/
/******Read sensor and adjst for accuracy*****/
dht.begin();
PoolIndoorTemp = (dht.readTemperature(true) + IndoorTempAdjustment);  //"true" will return in F; w/o true in C
PoolIndoorHumidity = (dht.readHumidity() + IndoorHumidityAdjustment);
Serial.println(PoolIndoorTemp,0);
Serial.println(PoolIndoorHumidity,0);
/******Print readings for display*****/
Serial.print("Indoor - Temperature: ");       //prints the labels
Serial.print(PoolIndoorTemp,0);
Serial.print("\xC2\xB0");                   // This adds the degree symbol
Serial.println("F");                        // Adds F after degree symbol
Serial.print("Indoor - Relative Humidity: ");
Serial.print(PoolIndoorHumidity,0);
Serial.println("%");                        //Adds the % symbol
/******Publish data over MQTT*****/
char IndoorTemp [6];                      //Defines IndoorTemp as character type
dtostrf(PoolIndoorTemp,3,0,IndoorTemp);    //converts digital to string
char IndoorHumidity [6];
dtostrf(PoolIndoorHumidity,3,0,IndoorHumidity);
client.publish("indoor_temp_topic",IndoorTemp);
client.publish("indoor_humidity_topic",IndoorHumidity);
Serial.println(IndoorTemp);
Serial.println(IndoorHumidity);
take a look at this example
you have to call   client.connect("some_random_id",mqtt_user,mqtt_password) somewhere in your code
Perfect. Now I am up and running. Thanks so very much.
A post was split to a new topic: Help with my ESP32-CAM face recognition uni project
