I have 2 Nano's and 2 ESP's sending small UDP packets to a Due using IP 192.168.1.180 and port 8881, it receives all UDP packets from all 4 senders.
I then changed the Due to a Nodemcu using the WIFI libraries, with the same IP 192.168.1.180 and port 8881.
Problem is that the Nodemcu only receives the packets from the 2 ESP senders and nothing comes in from the Nano's.
Senders:
Nano1 IP 192.168.1.178 local port 8889
Nano2 IP 192.168.1.177 local port 8888
ESP1 IP 192.168.1.200 local port 8886
ESP2 IP 192.168.1.201 local port 8887
Code for the Nodemcu, receive only no acknowledgments send:
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <NTPClient.h>
#include <TimeLib.h>
#include "TFT_eSPI.h"
#include "Free_Fonts.h" // Include the Adafruit fonts from the header file attached to this sketch
//#define UDP_TX_PACKET_MAX_SIZE 80
/*Put your SSID & Password*/
const char* ssid = ""; // Enter SSID here
const char* password = ""; //Enter Password here
IPAddress ipNTP(5,45,111,220);
unsigned int localPort2 = 8885;
WiFiUDP Udp2;
NTPClient timeClient(Udp2, ipNTP, 3600, 60000); //3600 = timeoffset, 60000 = get it every minute
WiFiUDP Udp;
unsigned int localUdpPort = 8881; // local port for UDP to listen on, Must be the same for all receiving units?
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
//char ReplyBuffer[40] = "Testing 1 2 3"; // not used
// Connect to Wi-Fi network with SSID and password
Serial.println(" ");
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
IPAddress ip(192,168,1,180); // Set fixed ip
IPAddress gateway(192,168,1,1);
IPAddress subnet(255,255,255,0);
WiFi.config(ip, gateway, subnet);
Serial.print(".");
// Print local IP address
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
Udp.begin(localUdpPort);
displayIPaddress(ip, localUdpPort);
// displayMACaddress(mac);
Serial.println("Listening for UDP");
Udp2.begin(localPort2); // for timeserver
timeClient.begin();
void loop(){
// if there's UDP data available, read a packet
int packetSize = Udp.parsePacket();
if (packetSize) {
Serial.println("");
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remote = Udp.remoteIP();
for (int i=0; i < 4; i++) { // print ip address
Serial.print(remote[i], DEC);
if (i < 3) {
Serial.print(".");
Serial.println(", port ");
Serial.println(Udp.remotePort());
Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE); // read the packet into packetBufffer
Serial.println("Contents:");
Serial.println(packetBuffer);
// print IPAdress and port
void displayIPaddress(const IPAddress address, unsigned int port) {
Serial.print(" IP ");
for (int i = 0; i < 4; i++) {
Serial.print(address[i], DEC);
if (i < 3) Serial.print(".");
Serial.print(" port ");
Serial.println(port);
void displayMACaddress(byte address[]) {
Serial.print("MAC address ");
for (int i = 0; i < 6; i++) {
Serial.print("0x");
Serial.print(address[i], HEX);
if (i < 5) Serial.print(".");
Code for Nano:
#include <EthernetENC.h>
#include <EthernetUdp.h>
#include <NTPClient.h> // Required to convert leap years and other exceptions
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xE1
IPAddress ip(192, 168, 1, 177);
unsigned int localPort = 8888; // local port for UDP
IPAddress remoteIP(192, 168, 1, 180);
unsigned int remotePort(8880);
char ReplyBuffer[] = "UDP test"; // a string to send back
EthernetUDP Udp; // An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp2;
NTPClient timeClient(Udp2, "europe.pool.ntp.org", 3600, 60000); //3600 = timeoffset, 60000 = get it every minute
Ethernet.init(10); // default pin for nano
mac[5] = ip[3]; // change default MAC address
Ethernet.begin(mac, ip); // start the Ethernet
if (Ethernet.hardwareStatus() == EthernetNoHardware) { // Check for Ethernet hardware present
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
Serial.println("Ethernet shield detected");
// start UDP
Udp.begin(localPort);
Serial.println("Send UDP packet from:");
displayIPaddress(ip, localPort);
timeClient.begin();
Serial.print("Send UDP packet to:");
displayIPaddress(remoteIP, remotePort);
Udp.beginPacket(remoteIP, remotePort);
Udp.write(ReplyBuffer);
Udp.endPacket();
timeClient.update();
Serial.println(timeClient.getFormattedTime());
Serial.print("0x");
Output from Due:
08:55:19.983 -> Received packet of size 5
08:55:20.017 -> From 192.168.1.178, port
08:55:20.017 -> 8889
08:55:20.594 ->
08:55:20.594 -> Received packet of size 8
08:55:20.628 -> From 192.168.1.177, port
08:55:20.662 -> 8882
08:55:20.662 -> Contents:
08:55:20.696 -> UDP test
08:54:59.458 -> Received packet of size 32
08:54:59.458 -> From 192.168.1.200, port
08:54:59.492 -> 8886
08:54:59.492 -> Sensor1 22.06 19.56 22.81 5.05
08:54:39.524 -> Received packet of size 24
08:54:39.558 -> From 192.168.1.201, port
08:54:39.558 -> 8887
08:54:39.592 -> Sensor2 20.38 17.13 32.00 5.06
Output from Nodemcu:
14:30:25.339 -> Received packet of size 24
14:30:25.339 -> From 192.168.1.201, port
14:30:25.385 -> 8887
14:30:25.385 -> Contents:
14:30:25.385 -> 22.75 17.13 32.00 5.06
14:31:02.040 ->
14:31:02.040 -> Received packet of size 32
14:31:02.040 -> From 192.168.1.200, port
14:31:02.040 -> 8886
14:31:02.040 -> Contents:
14:31:02.087 -> 21.75 19.56 23.13 5.06
14:31:25.874 ->
14:31:25.874 -> Received packet of size 24
14:31:25.874 -> From 192.168.1.201, port
14:31:25.920 -> 8887
14:31:25.920 -> Contents:
14:31:25.967 -> 22.88 17.13 32.00 5.06
14:32:02.525 ->
14:32:02.525 -> Received packet of size 32
14:32:02.525 -> From 192.168.1.200, port
14:32:02.572 -> 8886
14:32:02.572 -> Contents:
14:32:02.619 -> 21.88 19.56 23.13 5.07
Thanks,
Luc.
