NodeMCU ESP8266-12E and Arduino
Hello,
I'm trying to create an authentication system using an RFID reader, a keyboard and a server over the web which will do all the processing. The issue is that I got myself an NodeMCU ESP8266-12E and I can't seem to find a way to connect it to the Arduino. I would like to use the NodeMCU as a simple wifi adapter for the arduino. I know that I can program the esp itself, but I'd rather do everything from the Arduino. Is that doable? Can anyone share some insights?
Thank you.
silviub:
I'm not at all surprised. Connecting the two introduces quite a number of unnecessary problems, inducing level conversions, committed pins, serial buffering and having an efficient communications protocol. It is something far better avoided.
silviub:
I would like to use the NodeMCU as a simple WiFi adapter for the Arduino.
That is a bit like using a Semitrailer to deliver Uber Eats. :astonished:
If you have a NodeMCU, there is clearly no need for an Arduino.
If the RFID reader is a MFRC522 then it is a 3.3. V device as is the ESP8266 so you avoid the interface problems you would encounter if you want to connect it to an Arduino.
Suggest you sit back and take a sensible approach to this and "lose" the Arduino. :roll_eyes:
https://www.arduino.cc/reference/en/libraries/mfrc522/
"This library is compatible with the avr, megaavr, STM32F1, teensy, esp8266, esp32, samd architectures. . ."
The issue is that the NodeMCU doesn't have enough pins. I'm having a keyboard which uses 7 pins, an LCD display (it will use i2c in the future), the rfid reader and 3 buttons. This is why I want to use the Mega to gather all the data (keypass, rfid tag ID and data, button states) and to show a message on the display + light up some LEDs.
So, how are people connecting Arduino Mega to the internet? :smiley:
I started writing some code on the ESP and communicate with the mega over serial, but it's something I'd avoid if possible.
silviub:
Are you using a 4x3 keypad? Save some pins, wire the buttons as a 4th column of the keypad, wiring the buttons between the 4th column pin and the row pins.
Since you intend to use an I2C LCD display, use PCF8574/PCF8574A I/0 expanders to interface the keypad (see the I2CKeyPad library ) and the LEDs. That would allow you to run everything off the NodeMCU.
The interface between an Arduino and NodeMCU is usually a serial connection, using the NodeMCU as a simple wifi connection and doing all the processing on the Arduino. Since the Arduino is 5 volt and the NodeMCU is 3.3 volt, there should be a level shifter on the Tx line from the Arduino, a simple resistor voltage divider will work. No need for a level shifter on the NodeMCU Tx to Arduino Rx.
Hello,
Thank you for your suggestions. Still, why is everyone pushing to a single nodeMCU instead of it being used as an adapter?
I mean, how is people using ESP8266 with all the above I mentioned, for example? What do you do if you don’t have enough pins on the esp (nodemcu or other) and need to use an arduino mega / uno?
I have connected the TX of the Arduino to D1 and the RX of the Arduino to the D2, using a software serial on the ESP. No voltage divider. It’s working for the last 3 - 4 hours. Do you think that long term will cause some damage? Is there any ESP8266 dev board that uses 5V?
Thank you.
“Still, why is everyone pushing to a single NodeMCU. . .”
You didn’t mention all of the other stuff till later (Reply_4).
silviub:
Because it gives you vastly more WiFi capability, is easier to code, avoids many interfacing problems, is cheaper and more compact.
silviub:
There should never be any need to use something as clumsy as an Arduino Mega or UNO. :astonished:
You use I2C “port expanders” as explained by David, to interface other things such as keyboards or LCD displays. I2C requires only two pins, so you can build a whole system around an ESP-01(S) which has only four I/O available, :sunglasses:
silviub:
This abuse of the ESP is a longstanding point of heated discussion. Some suggest that the ESP can tolerate it, others not.
silviub:
No, apart from the input to the regulator, since the ESP is a 3.3 V device. :roll_eyes:
