NodeMCU ESP8266 ESP-12F Wifi compiling issues
I have a problem with my NodeMCU Lolin V3 Module ESP8266 ESP-12F.
I want to connect it to my Wifi, but I can't even compile the code.
I have selected the board (Tools->Board: "NodeMCU 1.0 (ESP-12E Module)" ).
Here is my code:
#include <ESP8266WiFi.h>        // Include the Wi-Fi library
const char* ssid     = "SSID";         // The SSID (name) of the Wi-Fi network you want to connect to
const char* password = "PASSWORD";     // The password of the Wi-Fi network
  Serial.begin(115200);         // Start the Serial communication to send messages to the computer
  delay(10);
  Serial.println('\n');
  WiFi.begin(ssid, password);             // Connect to the network
  Serial.print("Connecting to ");
  Serial.print(ssid); Serial.println(" ...");
  int i = 0;
  while (WiFi.status() != WL_CONNECTED) { // Wait for the Wi-Fi to connect
    Serial.print(++i); Serial.print(' ');
  Serial.println("Connection established!");
  Serial.print("IP address:\t");
  Serial.println(WiFi.localIP());         // Send the IP address of the ESP8266 to the computer
void loop() { }
and here my error-message:
Arduino: 1.8.19 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, All Flash Contents, 115200"
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp: In member function 'bool ESP8266WiFiGenericClass::mode(WiFiMode_t)':
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp:442:9: error: 'esp_delay' was not declared in this scope
  442 |         esp_delay(timeoutValue, [m]() { return wifi_get_opmode() != m; }, 5);
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp: In member function 'int ESP8266WiFiGenericClass::hostByName(const char*, IPAddress&, uint32_t)':
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp:626:9: error: 'esp_delay' was not declared in this scope
  626 |         esp_delay(timeout_ms, []() { return _dns_lookup_pending; }, 1);
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp: In function 'wl_status_t waitWiFiConnect(uint32_t)':
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp:89:5: error: 'esp_delay' was not declared in this scope
   89 |     esp_delay(connectTimeoutMs,
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp: In member function 'int8_t ESP8266WiFiMulti::startScan()':
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp:241:5: error: 'esp_delay' was not declared in this scope
  241 |     esp_delay(WIFI_SCAN_TIMEOUT_MS,
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiSTA-WPS.cpp: In member function 'bool ESP8266WiFiSTAClass::beginWPSConfig()':
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiSTA-WPS.cpp:77:5: error: 'esp_suspend' was not declared in this scope
   77 |     esp_suspend([]() { return _wps_config_pending; });
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp: In member function 'int8_t ESP8266WiFiScanClass::scanNetworks(bool, bool, uint8, uint8*)':
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp:100:9: error: 'esp_suspend' was not declared in this scope
  100 |         esp_suspend([]() { return !ESP8266WiFiScanClass::_scanComplete && ESP8266WiFiScanClass::_scanStarted; });
Multiple libraries were found for "ESP8266WiFi.h"
 Used: C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi
 Not used: C:\Users\LP3\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
Invalid library found in C:\Users\LP3\Documents\Arduino\libraries\ESP8266SdFat: no headers files (.h) found in C:\Users\LP3\Documents\Arduino\libraries\ESP8266SdFat
Invalid library found in C:\Users\LP3\Documents\Arduino\libraries\Ethernet: no headers files (.h) found in C:\Users\LP3\Documents\Arduino\libraries\Ethernet
Invalid library found in C:\Users\LP3\Documents\Arduino\libraries\SoftwareSerial: no headers files (.h) found in C:\Users\LP3\Documents\Arduino\libraries\SoftwareSerial
Do you have any ideas to make it work?
LG
Der_Mueller
You could try
#include"C:\Users\LP3\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFi.h"
(with a space after #include)
instead of
I tried it and now I get another error message:
Arduino: 1.8.19 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 160 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiClientSecure.h:23,
                 from C:\Users\LP3\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiServerSecure.h:20,
                 from C:\Users\LP3\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFi.h:41,
                 from C:\Users\LP3\Documents\Arduino\ESP8266_WiFi-connect\ESP8266_WiFi-connect.ino:1:
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:45:33: error: 'std::unique_ptr<WiFiClient> BearSSL::WiFiClientSecureCtx::clone() const' marked 'override', but does not override
   45 |     std::unique_ptr<WiFiClient> clone() const override {
C:\Users\LP3\Documents\Arduino\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:257:33: error: 'std::unique_ptr<WiFiClient> BearSSL::WiFiClientSecure::clone() const' marked 'override', but does not override
  257 |     std::unique_ptr<WiFiClient> clone() const override { return std::unique_ptr<WiFiClient>(new WiFiClientSecure(*this)); }
Multiple libraries were found for "WiFiClientSecure.h"
exit status 1
I was hoping for better results ...
Next step would be to move the ESP8266WiFi folder ( from C:\Users\LP3\Documents\Arduino\libraries) somewhere the Arduino IDE will not find it.
(like a flash drive)
Just in case the move breaks something ...
I'm having the same problem with these same files, Esp8266wifi and its included, is there anyone who can't fix them. I've been looking for a solution on the internet for 2 months and I can't find it. Please help us, we some many. Thanks.
The OP's sketch Compiled for me --
Maybe you need to do a Boards Update ?
the code of post #1 compiled OK for me as well
can you try a different PC?
reinstall the IDE and all the librarries?
