I am trying to Interface DHT11 temperature and humidity sensor with NodeMCU module, but i am facing the problem.
Initially i had successfully interfaced the Arduino UNO with DHT11.
Here is the program which i used and the library i used is as follow:
#include <dht11.h>
dht11 DHT11;
DHT11.attach(5);
Serial.println("DHT11 TEST PROGRAM ");
Serial.print("LIBRARY VERSION: ");
Serial.println(DHT11LIB_VERSION);
Serial.println("\n");
int chk = DHT11.read();
switch (chk)
case 0:
Serial.print("Humidity (%): ");
Serial.println(DHT11.humidity, DEC);
Serial.print("Temperature (C): ");
Serial.println(DHT11.temperature, DEC);
case -1: Serial.println("Checksum error"); break;
case -2: Serial.println("Time out error"); break;
default: Serial.println("Unknown error"); break;
delay(2000);
While running this program, i am getting Time Out Error, but the strange thing is that the same program is working on Arduino UNO.
I even tried this library from Adafruit
But even this library doesn’t work.
The strange thing is that, this library doesn’t work for Arduino UNO also, i found a post on this forum and found that, there is some problem in Adafruit library for DHT11 sensor, that’s why i used the above library.
Connect the data line from the sensor to D4 on the Nodemcu and switch your code to look like this:
#include <dht11.h>
#define D4 2 //define pin mapping as printed on the board
dht11 DHT11;
DHT11.attach(D4); //now you can just type the printed pin number
Serial.begin(115200); //if you change make sure you change it in the serial monitor to match
switch (chk)
case 0:
delay(2000);
I used DHT11 which works properly with arduino uno but giving no wrong response with nodeMCU.
I used different libraries for each considering the architecture.
For uno DHTLib library and for nodeMCU DHT11 as guided in the previous answers of this thread. But I always get "timeout error" with nodeMCU. please help
