Hi I am having a problem with my code It is a code for a gps tracker without using a gps module and using the google maps geolocation api key as a subtitute.In this code When I run the code everything works fine except the latitude and longitude continue showing 0.0000.Thus I am not able to get the current location.Can anyone please help me? The code has been attached below and the serial monitor output has also been attached below the code
#include <ESP8266HTTPClient.h>
#include <ArduinoJson.h>
#include "ESP8266WiFi.h"
char myssid[] = "OnePlus n"; // your network SSID (name)
char mypass[] = "xxx"; // your network password
//Credentials for Google GeoLocation API...
const char* Host = "www.googleapis.com";
String thisPage = "/geolocation/v1/geolocate?key=";
String key = "xxxxxx-OU21Es";
int status = WL_IDLE_STATUS;
String jsonString = "{\n";
double latitude = 0.0;
double longitude = 0.0;
double accuracy = 0.0;
int more_text = 1; // set to 1 for more debug output
Serial.println("Start");
// Set WiFi to station mode and disconnect from an AP if it was previously connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.println("Setup done");
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(myssid);
WiFi.begin(myssid, mypass);
Serial.print(".");
Serial.println(".");
char bssid[6];
DynamicJsonBuffer jsonBuffer;
Serial.println("scan start");
// WiFi.scanNetworks will return the number of networks found
int n = WiFi.scanNetworks();
Serial.println("scan done");
if (n == 0)
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found...");
if (more_text) {
// Print out the formatted json...
Serial.println("{");
Serial.println("\"homeMobileCountryCode\": 234,"); // this is a real UK MCC
Serial.println("\"homeMobileNetworkCode\": 27,"); // and a real UK MNC
Serial.println("\"radioType\": \"gsm\","); // for gsm
Serial.println("\"carrier\": \"Vodafone\","); // associated with Vodafone
//Serial.println("\"cellTowers\": ["); // I'm not reporting any cell towers
//Serial.println("],");
Serial.println("\"wifiAccessPoints\": [");
for (int i = 0; i < n; ++i)
Serial.print("\"macAddress\" : \"");
Serial.print(WiFi.BSSIDstr(i));
Serial.println("\",");
Serial.print("\"signalStrength\": ");
Serial.println(WiFi.RSSI(i));
if (i < n - 1)
Serial.println("},");
Serial.println("}");
Serial.println("]");
Serial.println(" ");
// now build the jsonString...
jsonString = "{\n";
jsonString += "\"homeMobileCountryCode\": 234,\n"; // this is a real UK MCC
jsonString += "\"homeMobileNetworkCode\": 27,\n"; // and a real UK MNC
jsonString += "\"radioType\": \"gsm\",\n"; // for gsm
jsonString += "\"carrier\": \"Vodafone\",\n"; // associated with Vodafone
jsonString += "\"wifiAccessPoints\": [\n";
for (int j = 0; j < n; ++j)
jsonString += "{\n";
jsonString += "\"macAddress\" : \"";
jsonString += (WiFi.BSSIDstr(j));
jsonString += "\",\n";
jsonString += "\"signalStrength\": ";
jsonString += WiFi.RSSI(j);
jsonString += "\n";
if (j < n - 1)
jsonString += "},\n";
jsonString += "}\n";
jsonString += ("]\n");
jsonString += ("}\n");
Serial.println("");
WiFiClientSecure client;
//Connect to the client and make the api call
Serial.print("Requesting URL: ");
Serial.println("https://" + (String)Host + thisPage + "AIzaSyCYNXIYINPmTNIdusMjJloS4_BXSOff1_g");
if (client.connect(Host, 443)) {
Serial.println("Connected");
client.println("POST " + thisPage + key + " HTTP/1.1");
client.println("Host: " + (String)Host);
client.println("Connection: close");
client.println("Content-Type: application/json");
client.println("User-Agent: Arduino/1.0");
client.print("Content-Length: ");
client.println(jsonString.length());
client.println();
client.print(jsonString);
//Read and parse all the lines of the reply from server
while (client.available()) {
String line = client.readStringUntil('\r');
if (more_text) {
Serial.print(line);
JsonObject& root = jsonBuffer.parseObject(line);
if (root.success()) {
latitude = root["location"]["lat"];
longitude = root["location"]["lng"];
accuracy = root["accuracy"];
Serial.println("closing connection");
client.stop();
Serial.print("Latitude = ");
Serial.println(latitude, 6);
Serial.print("Longitude = ");
Serial.println(longitude, 6);
Serial.print("Accuracy = ");
Serial.println(accuracy);
and this is the serial monitor output:
"macAddress" : "8E:83:C7:CD:50:08",
"signalStrength": -12
Requesting URL: https://www.googleapis.com/geolocation/v1/geolocate?key=AIzaSyA3KpvCIcdeRF6G_ClZUuXO6DlV-OU21Es
closing connection
Latitude = 0.000000
Longitude = 0.000000
Accuracy = 0.00
Ln 16, Col 1
NodeMCU 1.0 (ESP-12E Module)
on COM6 [not connected]
