Nodemcu Home Automation
hello, i an controlling 4-channel relay module with nodemcu via adafruit and ifttt. but the problem is when i power up the setup all the relays turn on and i have to turm them to off state. please have a look at the code below and let me know what i am doing wrong so that the relays stay in the off state on powering up.
#include <ESP8266WiFi.h>
#include “Adafruit_MQTT.h”
#include “Adafruit_MQTT_Client.h”
#define Relay1 D1
#define Relay2 D2
#define Relay3 D3
#define Relay4 D4
#define WLAN_SSID “” // Your SSID
#define WLAN_PASS “” // Your password
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER “io.adafruit.com” //Adafruit Server
#define AIO_SERVERPORT 1883
#define AIO_USERNAME “” // Username
#define AIO_KEY “” // Auth Key
//WIFI CLIENT
WiFiClient client;
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
Adafruit_MQTT_Subscribe Light1 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME"/feeds/Relay1");
Adafruit_MQTT_Subscribe Light2 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME “/feeds/Relay2”);
Adafruit_MQTT_Subscribe Light3 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME “/feeds/Relay3”);
Adafruit_MQTT_Subscribe Light4 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME “/feeds/Relay4”);
void MQTT_connect();
pinMode(Relay1, OUTPUT);
pinMode(Relay2, OUTPUT);
pinMode(Relay3, OUTPUT);
pinMode(Relay4, OUTPUT);
// Connect to WiFi access point.
Serial.println(); Serial.println();
Serial.print("Connecting to ");
Serial.println(WLAN_SSID);
WiFi.begin(WLAN_SSID, WLAN_PASS);
Serial.print(".");
Serial.println(“WiFi connected”);
Serial.println("IP address: ");
mqtt.subscribe(&Light1);
mqtt.subscribe(&Light3);
mqtt.subscribe(&Light2);
mqtt.subscribe(&Light4);
MQTT_connect();
Adafruit_MQTT_Subscribe *subscription;
while ((subscription = mqtt.readSubscription(20000))) {
if (subscription == &Light1) {
Serial.print(F("Got: "));
Serial.println((char *)Light1.lastread);
int Light1_State = atoi((char *)Light1.lastread);
digitalWrite(Relay1, Light1_State);
if (subscription == &Light2) {
Serial.println((char *)Light2.lastread);
int Light2_State = atoi((char *)Light2.lastread);
digitalWrite(Relay2, Light2_State);
if (subscription == &Light3) {
Serial.println((char *)Light3.lastread);
int Light3_State = atoi((char *)Light3.lastread);
digitalWrite(Relay3, Light3_State);
if (subscription == &Light4) {
Serial.println((char *)Light4.lastread);
int Light4_State = atoi((char *)Light4.lastread);
digitalWrite(Relay4, Light4_State);
void MQTT_connect() {
int8_t ret;
if (mqtt.connected()) {
return;
Serial.print("Connecting to MQTT… ");
uint8_t retries = 3;
while ((ret = mqtt.connect()) != 0) {
Serial.println(mqtt.connectErrorString(ret));
Serial.println(“Retrying MQTT connection in 5 seconds…”);
mqtt.disconnect();
delay(5000);
retries–;
if (retries == 0) {
while (1);
Serial.println(“MQTT Connected!”);
Hi, Common problem. The relays are "Active Low"...
See this page: http://arduinoinfo.mywikis.net/wiki/ArduinoPower#More_Complex_Systems:
Sample code there...
IMPORTANT NOTE: There is a issue with start-up of Arduino programs that control these relays. All of these 2,4, or 8 relay boards input controls are Active LOW, meaning that setting a pin LOW turns them ON. To assure that no relays activate at Reset or Power-On until you want them to, the initialization sequence in SETUP should be:
digitalWrite(Relay, HIGH); pinMode(Relay, OUTPUT);
terryking228: Hi, Common problem. The relays are "Active Low"...
Thank you for the detailed reply
I tried to implement your code since I have the same setup with a 4relay and adafruit aio.
on my serial monitor I only get the notice: Got: ON / OFF also relays don't switch.. could you give me a hand with that? thank you!
