NodeMCU http get request
I tried building an IoT based device which would connect to a given IP, make HTTP requests and thereby get, post data to the server. I did this using the Arduino wifi shield. But, as documented in many threads on the forum too, the response time from the server due to the deficiencies of the Arduino wifi shield results in a 2-3s delay from the server. I am trying to see if the nodeMCU can address the speed issue.
I shall upload the code I am using. Please advise me as to what I am doing wrong as I am getting a client timeout all the time.
#include <ESP8266WiFi.h>
const char* ssid     = "iPhone";
const char* password = "hibyeokfine";
const char* host = "host ip";
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
int value = 0;
  delay(5000);
  ++value;
  Serial.print("connecting to ");
  Serial.println(host);
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  const int httpPort = 85;
  if (!client.connect(host, httpPort)) {
    Serial.println("connection failed");
    return;
  // We now create a URI for the request
  String url = "/get_burner_mode";
  Serial.print("Requesting URL: ");
  Serial.println(url);
  // This will send the request to the server
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  unsigned long timeout = millis();
  while (client.available() == 0) {
    if (millis() - timeout > 5000) {
      Serial.println(">>> Client Timeout !");
      client.stop();
      return;
  // Read all the lines of the reply from server and print them to Serial
  while(client.available()){
    String line = client.readStringUntil('\r');
    Serial.print(line);
  Serial.println("closing connection");
code here works. Doubt cleared.
