Hi
i have connected my BME280 sensor through I2C comunication but after a long time of running i couln’t receive any data
I uploaded the I2C scanner code
// i2c_scanner
// Version 1
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
// Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26 2013
// V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
// by Arduino.cc user Krodal.
// Changes by louarnold removed.
// Scanning addresses changed from 0...127 to 1...119,
// according to the i2c scanner by Nick Gammon
// https://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
// As version 4, but address scans now to 127.
// A sensor seems to use address 120.
// Version 6, November 27, 2015.
// Added waiting for the Leonardo serial communication.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
Wire.begin();
while (!Serial); // Leonardo: wait for serial monitor
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknown error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
and i after many errors “espcomm_upload_mem failed” I made it…
the monitor prints:
15:09:04.564 → Scanning…
15:09:04.564 → I2C device found at address 0x07 !
15:09:04.598 → Unknown error at address 0x08
15:09:04.631 → Unknown error at address 0x09
15:09:04.667 → Unknown error at address 0x0A
15:09:04.699 → I2C device found at address 0x11 !
15:09:04.734 → I2C device found at address 0x19 !
15:09:04.769 → I2C device found at address 0x21 !
15:09:04.803 → I2C device found at address 0x29 !
15:09:04.871 → Unknown error at address 0x32
15:09:04.905 → I2C device found at address 0x3B !
15:09:04.940 → Unknown error at address 0x44
15:09:04.975 → I2C device found at address 0x4C !
15:09:05.008 → I2C device found at address 0x54 !
15:09:05.043 → I2C device found at address 0x5D !
15:09:05.077 → Unknown error at address 0x66
15:09:05.111 → I2C device found at address 0x70 !
15:09:05.145 → Unknown error at address 0x7A
15:09:05.180 → done
i also have an arduino uno and works great but nodemcu stuck…
i also tried to flash the nodemcu but nithing happend
Any solution???
