Nodemcu mysql connection library error
Hi I'm trying to connect my node mcu board and aws database server.
I'm using
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
these two library for the connection.
My code is as follows.
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <stdio.h>
String ssid = "secret";
String password = "secret";
String inputString = "";         // a string to hold incoming data
boolean stringComplete = false;  // whether the string is complete
//: and % was set from the transmitter node for the eage of data separation
char start_val = ':';
char end_val = '%';
int start_pos = 0;
int end_pos = 0;
int temp = 0;
int humid = 0;
int air = 0;
SoftwareSerial mySerial(D2,D3);
IPAddress server_addr(secret);
char user[] = "secret";
char password_[] = "secret";
WiFiClient client;
MySQL_Connection conn(&client);
MySQL_Cursor* cursor;
char INSERT_SQL[] = "INSERT INTO dht11.smartcity VALUES (7,8,9,10)";
  mySerial.begin(115200);
  WiFi.mode(WIFI_STA);
    WiFi.begin(ssid, password);
         Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.print("Connecting to SQL... ");
if (conn.connect(server_addr, 3306, user, password_))
  Serial.println("OK.");
  else {
    Serial.println("FAILED.");
    delay(5000);
    cursor = new MySQL_Cursor(&conn);
  if (mySerial.available()){
    while (mySerial.available()) {
    // get the new byte:
    char inChar = (char)mySerial.read();
    //Serial.println(inChar);
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inChar == '\n') {
      stringComplete = true;
    // add it to the inputString:
      inputString += inChar;
    if (stringComplete) {
    start_pos = inputString.indexOf(start_val);
    end_pos = inputString.indexOf(end_val);
    String data_string = inputString.substring(start_pos+1, end_pos-1);
    Serial.println(data_string);
    String temperature = data_string.substring(10, 15);
    String humidity = data_string.substring(16, 21);
    String air_auality = data_string.substring(22, 24);
    temp = int(temperature.toFloat());
    humid = int(humidity.toFloat());
    air = int(air_auality.toFloat());
    Serial.println(temp);
    Serial.println(humid);
    Serial.println(air);
    inputString = "";
  sprintf(INSERT_SQL, "INSERT INTO dht11.smartcity VALUES (now(),%d,%d,%d)",temp, humid, air);
  if (conn.connected()) {
    Serial.println("connected to databases");
    cursor->execute(INSERT_SQL);
void Wifi_connect() {
  Serial.println("---------------------------------------");
  Serial.println(ssid);
    Serial.print(".");
  Serial.println("Wifi connected!");
  Serial.println("\nConnected to network");
  Serial.print("My IP address is: ");
And when I run the code, they got uploaded well, and the wifi connection also works,
but there are some strange errors appearing on the serial monitor.
The error is as follows.
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (28):
epc1=0x40203260 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000049 depc=0x00000000
stack>>>
ctx: cont
sp: 3ffffc30 end: 3fffffc0 offset: 0190
3ffffdc0: 00000055 3fffc6fc 00000000 3fff0634
3ffffdd0: 3fff0634 2c9f0300 00000001 402032b3
3ffffde0: 401034fc 00000000 3ffe85f6 402032a0
3ffffdf0: 40205060 00000030 0000001c 4020781c
3ffffe00: fffffffc 3ffeea0c 224a85b7 402288a5
3ffffe10: 00000000 00000000 00000000 3ffee5fc
3ffffe20: 402077e8 3ffe85f6 3ffee718 40203bf0
3ffffe30: 3fff0634 3ffee718 00000000 40203c14
3ffffe40: 3fff0634 3ffee718 3ffee718 40203ca4
3ffffe50: 3ffeed4c 00000000 00000000 40203667
3ffffe60: 00000000 00000000 40100625 4021631e
3ffffe70: 000002c3 000002c3 3ffe8620 40100d4f
3ffffe80: 00000000 4bc6a7f0 051eb851 00000001
3ffffe90: 3fff083c 00000020 3fff083c 40100f2e
3ffffea0: 3ffee190 00000000 00000000 401008fc
3ffffeb0: 000019d1 3ffee8e0 0000012c 40216d84
3ffffec0: 00000282 00000282 3ffe8620 40100d4f
3ffffed0: 3ffe85f6 00000000 3fff0314 3ffe85f6
3ffffee0: 00000000 0000002c 00000020 3ffe85f6
3ffffef0: 00000000 0000002c 3ffee5fc 402037aa
3fffff00: 00000007 3fff0634 3ffee5fc 4020351e
3fffff10: 0000004a 00000020 00000001 00000003
3fffff20: 00000001 3ffee7f0 3ffee5fc 40202f02
3fffff30: 40207d10 d3a52703 3ffee7f0 40203980
3fffff40: 3fffff90 00000cea 3ffe8602 3ffe85f6
3fffff50: 00000000 40202c5c 3ffee7f0 40203c14
3fffff60: 2719a8c0 00ffffff 0119a8c0 3ffee87c
3fffff70: 00000000 3ffee5fc 3ffee7f0 40201129
3fffff80: 00000040 00000000 feefeffe feefeffe
3fffff90: 40207d10 d3a52703 feefeffe feefeffe
3fffffa0: 3fffdad0 00000000 3ffee868 40204ac4
3fffffb0: feefeffe feefeffe 3ffe861c 401011e1
<<<stack<<<
these error appears with same interval(the delay time I set).
Is there anyway to solve this problem?
Or does the Nodemcu 12e boards doesn't fit with Adruino's Mysql connection library??
Help me anybody
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
