Hi everyone and thank you for helping me out. I'm having a problem running code on my nodeMCU v1.0. Basically I'm building a smart greenhouse with for a school project and my professor provided the hardware specs. Basically I have a program that runs on an Arduino UNO where i collect data, print them on a screen, manage irrigation, and last, to send the data to the nodeMCU so that with the second program running on it, i can send the data to Thingspeak. The problem is that the nodeMCU seems like not running, If i upload and example code on it, for instance the blink example, it works perfectly fine, but if I put my own code in, that little bih doesn't even go trought setup.
PS:
Sorry for bad english and the comments on the code but im italian
These are my two separate programs.
this is the nodeMCU one
CODICE PER IL NODEMCU DELLA SERRA
#include <ESP8266WiFi.h>
#include <ThingSpeak.h>
//variabili per la connessione e la trasmissione dati a thingspeak
unsigned long myChannelNumber =;
const char *ssid = "";
const char* password = "";
const char *myWriteAPIKey = "";
//variabili timer
unsigned long lastTime = 0;
unsigned long timerDelay = 30000;
float terreno, temperatura, umidità, co2;
float valori[4];
WiFiClient client;
void setup(){
//inizio la comunicazione seriale con arduino
while(!Serial) {
;//aspetto che la porta seriale si connetta
WiFi.mode(WIFI_STA);
ThingSpeak.begin(client);
void loop(){
if((millis() - lastTime) > timerDelay){
//conneto/riconnetto ad internet
if(WiFi.status() != WL_CONNECTED){
Serial.print("Attempting to connect");
while(WiFi.status() != WL_CONNECTED){
WiFi.begin(ssid, password);
Serial.println("\nConnected");
ricevoValori(); //ricevo i valori da arduino e li invio a thingspeak
for(int i=0; i < 4; i++){
int x = ThingSpeak.writeField(myChannelNumber, (i+1), valori[i], myWriteAPIKey);
//controllo se gli ha inviati fr
if(x == 200){
Serial.println("Canale aggiornato correttamente");
}else {
Serial.println("errore nell' aggiornamento del canale. errore HTTP: " + String(x));
lastTime = millis();
void ricevoValori(){
//funzione che separa la stringa ricevuta nelle variabili che servono
String stringaRicevuta; //leggo la stringa ricevuta dal seriale
if(Serial.available() > 0) {
stringaRicevuta = Serial.read();
terreno = splitString(stringaRicevuta, ',', 0).toFloat();
temperatura = splitString(stringaRicevuta, ',', 1).toFloat();
umidità = splitString(stringaRicevuta, ',', 2).toFloat();
co2 = splitString(stringaRicevuta, ',', 3).toFloat();
//assegno i valori all'array secondo l'ordine che segue thingspeak
valori[0] = temperatura;
valori[1] = umidità;
valori[2] = terreno;
valori[3] = co2;
String splitString(String str, char sep, int index)
int found = 0;
int strIdx[] = { 0, -1 };
int maxIdx = str.length() - 1;
for (int i = 0; i <= maxIdx && found <= index; i++)
if (str.charAt(i) == sep || i == maxIdx)
found++;
strIdx[0] = strIdx[1] + 1;
strIdx[1] = (i == maxIdx) ? i+1 : i;
return found > index ? str.substring(strIdx[0], strIdx[1]) : "";
and this is the one that runs on the UNO:
-----------------------CHIAVI API THINGSPEAK---------------
CHIAVE SCRITTURA ----> 1Z0VG5H3GCZYYHV3
CHIAVE LETTURA ------> ZEXONIXDAWCI7O84
#include <ArduinoJson.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <DHT.h>
#include <SoftwareSerial.h>
//definisco le variabili globali
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET 4 // pin reset lcd
#define SCREEN_ADDRESS 0x3C //dal datasheet
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define NUMFLAKES 10 // Number of snowflakes in the animation example
#define LOGO_HEIGHT 16
#define LOGO_WIDTH 16
static const unsigned char PROGMEM logo_bmp[] =
{ 0b00000000, 0b11000000,
0b00000001, 0b11000000,
0b00000011, 0b11100000,
0b11110011, 0b11100000,
0b11111110, 0b11111000,
0b01111110, 0b11111111,
0b00110011, 0b10011111,
0b00011111, 0b11111100,
0b00001101, 0b01110000,
0b00011011, 0b10100000,
0b00111111, 0b11100000,
0b00111111, 0b11110000,
0b01111100, 0b11110000,
0b01110000, 0b01110000,
0b00000000, 0b00110000 };
int soilSensor1 = A3;
#define dhtpin 7
#define dhttype DHT11
#define co2AnalogPin A2
#define co2DigitalPin 2
#define co2Zero 140 //valore da sistemare poi, calibrazione da fare a scuola
DHT dht(dhtpin, dhttype);
//variabili rele pompe
int pompa1 = 7;
int pompa2 = 6;
int pompa3 = 5;
//bottone lcd
int bottone = 10;
int contatore = 1; //massimo 4
//timer per l'invio dati ogni 30 secondi
unsigned long previousMillis = 0;
unsigned long interval = 500;
SoftwareSerial espSerial(5, 6); //5=TX 6=RX
void setup(){
pinMode(soilSensor1, INPUT); //set up del sensore umidità terreno
// controllo che la corrente venga data correttamente
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
//-------------------------------------------- OLED SETUP -----------------------------
//buffer del display e logo(imposto nella libreria)
display.display();
//pulisco il buffer
display.clearDisplay();
// disegno un singolo pixel per controllare il display
display.drawPixel(10, 10, SSD1306_WHITE);
// uso display.display per far vedere quello disegnato precedentemente
display.display();
//--------------------DHT----------------
dht.begin();
//--------------------CO2----------------
pinMode(co2AnalogPin, INPUT);
//---------------ACQUA-------------
pinMode(pompa1, OUTPUT);
pinMode(pompa2, OUTPUT);
pinMode(pompa3, OUTPUT);
//-----------NODEMCU---------------
espSerial.begin(115200); //mando su questo canale le informazioni al seriale del NODEMCU
void loop(){
scritturaLCD(SoilSensor(), temperaturaAria(), umiditaAria(), qualitaAria(), valoreBottone());
irrigazione();
//con il timer invio i dati al nodeMCU che poi li invierà a thingspeak
if(currentMillis - previousMillis > interval){
inviaDati();
float SoilSensor(){
float percentualeTerreno = ( 100 - ( (analogRead(soilSensor1)/1023.00) * 100 ) ); //calcolo percentuale di umidità
return(percentualeTerreno);
float temperaturaAria(){
float temperatura = dht.readTemperature();
return temperatura;
float umiditaAria(){
float umidita = dht.readHumidity();
return umidita;
float qualitaAria(){
int co2now[10]; //int array for co2 readings
int co2raw = 0; //int for raw value of co2
int co2comp = 0; //int for compensated co2
int co2ppm = 0; //int for calculated ppm
int zzz = 0; //int for averaging
for (int x = 0;x<10;x++){ //samplpe co2 10x over 2 seconds
co2now[x]=analogRead(co2AnalogPin);
delay(200);
for (int x = 0;x<10;x++){ //add samples together
zzz=zzz + co2now[x];
co2raw = zzz/10; //divide samples by 10
co2comp = co2raw - co2Zero; //get compensated value
co2ppm = map(co2comp,0,1023,400,5000);
return co2ppm;
int valoreBottone(){
int valore = 1;
//aumento il valore ogni premuta di tasto
if(digitalRead(bottone) == 1){
//premo il bottone
if(valore == 4) {
valore = 1;
}else {
valore += 1;
return valore;
void scritturaLCD(float soilReading, float temperatura, float umidita, float co2, int selezione){ // selezione valore del bottone
int grafX = 0;
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_WHITE); // Draw white text
display.setCursor(0, 0); // Start at top-left corner
display.cp437(true); // Use full 256 char 'Code Page 437' font
switch(selezione) {
case 1:
//temperatura dell'aria
display.setTextSize(2);
display.setTextColor(WHITE);
display.setTextColor(0,0);
display.println("AIR TEMPERATURE");
display.println("");
display.print(temperatura);
display.print(" C");
grafX = map(temperatura, 0, 40, 0, 127);
display.fillRect(0, 52, grafX, 10, WHITE);
case 2:
//umidità dell aria
display.println("AIR HUMIDITY");
display.print(umidita);
display.print(" %");
grafX = map(umidita, 0, 100, 0, 127);
case 3:
//umidità del terreno
display.println("SOIL HUMIDITY");
display.print(soilReading);
grafX = map(soilReading, 0, 100, 0, 127);
case 4:
//livelli co2
display.println("AIR TEMP");
display.print(co2);
grafX = map(co2, 0, 1000, 0, 127);
display.display();
//---------------FUNZIONE IRRIGAZIONE-----------------
void irrigazione(){
float terreno = SoilSensor(); // percentuale umidità terreno
//se l'umidità è minore del 25 bagno tutto
if(terreno < 25){
digitalWrite(pompa1, HIGH);
digitalWrite(pompa2, HIGH);
digitalWrite(pompa3, HIGH);
delay(2000); //da sistemare poi dopo che abbiamo visto quanta acqua esce
digitalWrite(pompa1, LOW);
digitalWrite(pompa2, LOW);
digitalWrite(pompa3, LOW);
//---------------------INVIO DATI AL NODEMCU-------------------------------
void inviaDati(){
float terreno, temperatura, umidita;
int co2;
//prendo i dati con le funzioni
temperatura = temperaturaAria();
umidita = umiditaAria();
co2 = qualitaAria();
//invio i dati secondo questo ordine
espSerial.println(String(terreno) + "," + String(temperatura) + "," + String(umidita) + "," + String(co2));
