NodeMCU programmable cyclic On/Off Timer
Hello,
I like to modify below given code to achieve following desired features.
  1. I should be able to give it loop setting (cyclic) for both On and Off for relay control.
  2. In place of slider, an input box to give number of seconds or minutes will be good.
My hardware:
Lolin NodeMCU V3 and 2Ch Relay Module, powering externally and currently only using 1 Channel
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-esp8266-web-server-timer-pulse/
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
// Import required libraries
#ifdef ESP32
  #include <WiFi.h>
  #include <AsyncTCP.h>
#else
  #include <ESP8266WiFi.h>
  #include <ESPAsyncTCP.h>
#endif
#include <ESPAsyncWebServer.h>
// Replace with your network credentials
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
const char* PARAM_INPUT_1 = "state";
const char* PARAM_INPUT_2 = "value";
const int output = 2;
String timerSliderValue = "10";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <title>ESP Web Server</title>
  <style>
    html {font-family: Arial; display: inline-block; text-align: center;}
    h2 {font-size: 2.4rem;}
    p {font-size: 2.2rem;}
    body {max-width: 600px; margin:0px auto; padding-bottom: 25px;}
    .switch {position: relative; display: inline-block; width: 120px; height: 68px}
    .switch input {display: none}
    .slider {position: absolute; top: 0; left: 0; right: 0; bottom: 0; background-color: #ccc; border-radius: 34px}
    .slider:before {position: absolute; content: ""; height: 52px; width: 52px; left: 8px; bottom: 8px; background-color: #fff; -webkit-transition: .4s; transition: .4s; border-radius: 68px}
    input:checked+.slider {background-color: #2196F3}
    input:checked+.slider:before {-webkit-transform: translateX(52px); -ms-transform: translateX(52px); transform: translateX(52px)}
    .slider2 { -webkit-appearance: none; margin: 14px; width: 300px; height: 20px; background: #ccc;
      outline: none; -webkit-transition: .2s; transition: opacity .2s;}
    .slider2::-webkit-slider-thumb {-webkit-appearance: none; appearance: none; width: 30px; height: 30px; background: #2f4468; cursor: pointer;}
    .slider2::-moz-range-thumb { width: 30px; height: 30px; background: #2f4468; cursor: pointer; }
  </style>
</head>
<body>
  <h2>ESP Web Server</h2>
  <p><span id="timerValue">%TIMERVALUE%</span> s</p>
  <p><input type="range" onchange="updateSliderTimer(this)" id="timerSlider" min="1" max="20" value="%TIMERVALUE%" step="1" class="slider2"></p>
  %BUTTONPLACEHOLDER%
<script>
function toggleCheckbox(element) {
  var sliderValue = document.getElementById("timerSlider").value;
  var xhr = new XMLHttpRequest();
  if(element.checked){ xhr.open("GET", "/update?state=1", true); xhr.send();
    var count = sliderValue, timer = setInterval(function() {
      count--; document.getElementById("timerValue").innerHTML = count;
      if(count == 0){ clearInterval(timer); document.getElementById("timerValue").innerHTML = document.getElementById("timerSlider").value; }
    }, 1000);
    sliderValue = sliderValue*1000;
    setTimeout(function(){ xhr.open("GET", "/update?state=0", true);
    document.getElementById(element.id).checked = false; xhr.send(); }, sliderValue);
function updateSliderTimer(element) {
  document.getElementById("timerValue").innerHTML = sliderValue;
  xhr.open("GET", "/slider?value="+sliderValue, true);
  xhr.send();
</script>
</body>
</html>
)rawliteral";
// Replaces placeholder with button section in your web page
String processor(const String& var){
  //Serial.println(var);
  if(var == "BUTTONPLACEHOLDER"){
    String buttons = "";
    String outputStateValue = outputState();
    buttons+= "<p><label class=\"switch\"><input type=\"checkbox\" onchange=\"toggleCheckbox(this)\" id=\"output\" " + outputStateValue + "><span class=\"slider\"></span></label></p>";
    return buttons;
  else if(var == "TIMERVALUE"){
    return timerSliderValue;
  return String();
String outputState(){
  if(digitalRead(output)){
    return "checked";
  else {
    return "";
  return "";
void setup(){
  // Serial port for debugging purposes
  pinMode(output, OUTPUT);
  digitalWrite(output, LOW);
  // Connect to Wi-Fi
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi..");
  // Print ESP Local IP Address
  // Route for root / web page
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html, processor);
  // Send a GET request to <ESP_IP>/update?state=<inputMessage>
  server.on("/update", HTTP_GET, [] (AsyncWebServerRequest *request) {
    String inputMessage;
    // GET input1 value on <ESP_IP>/update?state=<inputMessage>
    if (request->hasParam(PARAM_INPUT_1)) {
      inputMessage = request->getParam(PARAM_INPUT_1)->value();
      digitalWrite(output, inputMessage.toInt());
    else {
      inputMessage = "No message sent";
    Serial.println(inputMessage);
    request->send(200, "text/plain", "OK");
  // Send a GET request to <ESP_IP>/slider?value=<inputMessage>
  server.on("/slider", HTTP_GET, [] (AsyncWebServerRequest *request) {
    // GET input1 value on <ESP_IP>/slider?value=<inputMessage>
    if (request->hasParam(PARAM_INPUT_2)) {
      inputMessage = request->getParam(PARAM_INPUT_2)->value();
      timerSliderValue = inputMessage;
    else {
  // Start server
  server.begin();
What have you tried?
Try writing your code then when it doesn't work, ask here for help.
If you want someone to write the code for you, then click on "Report to Moderator" and ask for the post to be moved to "Gigs and Collaborations" where you can offer to pay someone to write your code.
SteveMann:
You are Electrical Engineer, Commercial Pilot and Tinker Wow...... still have lot of time just to reply with no meaningful or useful information and just to criticize newbies and increasing self number of posts like this...... keep it up.
