NodeMCU + pushingbox (pushbullet) + smartphone // works but doesn´t work :D
Hey everybody,
I´m trying to develop with my tinxi® NodeMCU Lua WIFI Internet Development Board Based on ESP8266 ESP-12E CP2102 a system, that reacts that will react on two sensors or in my first case a pushbutton and will send me a notification over wifi using pushingbox on my smartphone.
I tested the scenario on pushingox notification works perfectly fine. (Not even more than a couple seconds)
Also, the pushbutton, when I press the blue LED is on, but first it seems no notification.
Double checked SSID, password, and DeviceID all should be ok.
But I receive it feels somehow out of nowhere the correct pushingbox message. How can this be ? :smiley:
Also the serial port doesn´t connect
closing connection
Waiting…
Connecting
closing connection
Waiting…
Connecting
Using Arduino 1.8.5
Baudrate and so on 115000 checked it already as well again should be fine :confused:
#include <ESP8266WiFi.h>
String apiKey = “v2B”; //DevID changed it
const char* ssid = “WLAN-Name”; //SSID of your router changed it but in real it´s correct
const char* password = “7456555665666”; //WEP/WPA/WPA2 code for router changed it as well
const char* server = “api.pushingbox.com”;
int buttonPush = 0;
int button = D0;
WiFiClient client;
delay(10);
WiFi.begin(ssid, password);
Serial.print("Connecting to ");
Serial.println(ssid);
Serial.print(".");
Serial.println("");
Serial.println(“WiFi connected”);
Serial.println("IP address: ");
if (digitalRead(button) == HIGH) {
if (client.connect(server,80)) {
Serial.println(“Connecting”);
client.print(“GET /pushingbox?devid=”);
client.print(apiKey);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(server);
client.println(“User-Agent: Arduino”);
client.println();
// Read all the lines of the reply from server and print them to Serial
while(client.available()){
String line = client.readStringUntil(’\r’);
Serial.print(line);
buttonPush = 1;
Serial.println(“closing connection”);
client.stop();
Serial.println(“Waiting…”);
// thingspeak needs minimum 15 sec delay between updates
buttonPush = 0;
I just checked it with my other Devide ID option.
As soon as the sketch is uploaded it will send two messages.
I pressed my button a couple times nothing new happens. :confused:
Every comparable source code would also highly be appreciated :slight_smile:
Thanks for any support.
Cheers from Upper Bavaria
Patrick
So, 1 is good enough. Hmmm...
Serial.println("Connecting");
It is stupid to print "Connecting" only after you are "Connected".
    String line = client.readStringUntil('\r');
    Serial.print(line);
  buttonPush = 1;
After you made the GET request, EXACTLY how long did you wait for the server to generate a response? Is it even remotely likely that the server generated, AND returned, a response in that time?
What you are SUPPOSED to do after making a GET request is to use TWO while loops:
   while(client.connected())
      while(client.available() > 0)
         // Read the response WITHOUT pissing away resources on the stupid String class
The outer while loop will spin until the server has closed the connection, which it does NOT do until the complete response has been sent.
