Hi, I'm working on my personal UV exposer box for PCB. I want to automate the time count to start and stop UV tubes. I'm using the relay to turn ON/OFF the power source to tubes. Everything works fine except as it starts counting from time defined using potentiometer, the nodemcu resets.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
//----------PIN ASSIGNEMENTS-----------//
#define LEDs D7 //LED Transistor Trigger Pin
#define buzzer D6 //Buzzer Pin
#define button D5 //Select Button Pin
#define durationPot A0 //Duration Knob Pin
//#define brightnessPot D8 //Brightness Knob Pin
//-------CONFIGURABLE PARAMETERS-------//
int
maxTime = 1200, //Maximum countdown timer time (in secs)
buzzerFreq = 1000; //Buzzer frequency (Hz, Change to customize tone)
//glowDelay = 10; //Change this to increase LED glow rate (0-200)
//---SYSTEM VARIABLES (DO NOT TOUCH)---//
float
timeLeftBarPercent = 0.00,
durationSecFloat = 0.00,
durationSecSelect = 0.00;
int
//whitePWM = 0,
duration = 0,
durationSec = 0,
//brightness = 0,
//brightnessPercent = 0,
//brightnessPWM = 0,
seconds = 0,
minutes = 0,
exposureLoop = 0,
startupLoop = 0;
unsigned long previousMillis = 0;
const long interval = 1000;
char timeMinSec[16];
//-VOID SETUP (Runs codes before entering loop)-//
void setup(){
lcd.begin();
lcd.backlight();
pinMode(LEDs, OUTPUT);
pinMode(buzzer, OUTPUT);
// initialize the LCD
lcd.clear();
while(digitalRead(button)==LOW){
lcd.setCursor(0,0);
lcd.print(" PCB UV ");
lcd.setCursor(0,1);
lcd.print(" Exposure Box ");
delay(2000);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Firmware Version");
lcd.setCursor(0, 1);
lcd.print("TechBuilder v3.1");
lcd.clear();
//-VOID LOOP (Code that runs on repeat)-//
void loop(){
//--Gather Duration Knob Readings--//
duration = analogRead(durationPot);
durationSec = map(duration,0,1023,0, maxTime);
//--Gather Brightness Knob Readings--//
brightness = analogRead(brightnessPot);
brightnessPercent = map(brightness,0,1023,0,100);
brightnessPWM = map(brightness,0,1023,0,255);
//--Control LED brightness in real time--//
analogWrite(LEDs,brightnessPWM);
minutes = durationSec/60;
seconds = durationSec%60;
lcd.setCursor(0,0);lcd.print("Duration: ");
sprintf(timeMinSec,"%0.2d:%0.2d",minutes,seconds);
lcd.setCursor(11,0);lcd.print(timeMinSec);
if(brightnessPercent<100){ //Used this instead of "lcd.clear();" function. Done to reduce LCD flicker.
lcd.setCursor(14, 1);
lcd.print(" ");
lcd.print("Brightness: ");
lcd.setCursor(12, 1);
lcd.print(brightnessPercent);
lcd.setCursor(15, 1);
lcd.print("%");
if (digitalRead(button)==HIGH){
durationSecSelect = durationSec;
durationSecFloat = durationSec;
lcd.clear();
lcd.setCursor(0, 0);lcd.print(" Initializing ");delay(300);
lcd.setCursor(0, 0);lcd.print(" Initializing. ");tone(buzzer, buzzerFreq*3, 100);delay(300);
lcd.setCursor(0, 0);lcd.print(" Initializing.. ");tone(buzzer, buzzerFreq*3, 100);delay(300);
lcd.setCursor(0, 0);lcd.print(" Initializing...");tone(buzzer, buzzerFreq*3, 100);delay(500);
lcd.setCursor(0,0);lcd.print(" STARTING ");
for (int i=0; i <= 15; i++){
lcd.print((char) 255);delay(35);
tone(buzzer, buzzerFreq*2, 50);
delay(300);
// analogWrite(LEDs,brightnessPWM);
lcd.clear();
lcd.print("Time Left: ");
while(exposureLoop==0){
timeLeftBarPercent = 100*(durationSecFloat/durationSecSelect);
if (currentMillis - previousMillis >= interval){
sprintf(timeMinSec,"%0.2d:%0.2d", minutes, seconds);
lcd.setCursor(11, 0);
if(timeLeftBarPercent<2) {for (int v=0; v <= 15; v++){lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<6.25){for(int v=0; v <= 14; v++){lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<12.5){for(int v=0; v <= 13; v++){lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<18.75){for(int v=0; v <= 12; v++){lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<25) {for (int v=0; v <= 11; v++){lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<31.25){for(int v=0; v <= 10; v++){lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<37.5) {for(int v=0; v <= 9; v++){lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<43.75){for(int v=0; v <= 8; v++){ lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<50) {for(int v=0; v <= 7; v++){ lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<56.25){for(int v=0; v <= 6; v++){ lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<62.5) {for(int v=0; v <= 5; v++){ lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<68.75){for (int v=0; v <= 4; v++){lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<75) {for (int v=0; v <= 3; v++){lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<81.25){for (int v=0; v <= 2; v++){lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<87.5) {for (int v=0; v <= 1; v++){lcd.setCursor(v, 1);lcd.print((char) 255);}}
else if(timeLeftBarPercent<93.75){lcd.setCursor(0, 1);lcd.print((char) 255);}
durationSec--;
durationSecFloat--;
if(durationSec<=0){
digitalWrite(LEDs,LOW); //Turn off LEDs when countdown hits 0
tone(buzzer,3000,500);
lcd.setCursor(0,0);lcd.print(" Exposure ");
lcd.setCursor(0,1);lcd.print(" Finished ");
delay(500);lcd.clear();
lcd.setCursor(0,0);lcd.print(" Press Button ");
lcd.setCursor(0,1);lcd.print(" To Start ");
while(digitalRead(button)==LOW){} //Press button to proceed with system restart
for (int i=0; i <= 255; i++){ //Glow-up Illumination LED
analogWrite(LEDs,i);
delay(glowDelay);
lcd.clear();
exposureLoop=1;
else if(digitalRead(button)==HIGH){
lcd.setCursor(0,0);lcd.print(" Cancelling ");
lcd.setCursor(0,1);lcd.print(" Process! ");
delay(750);
/* while(digitalRead(button)==LOW){}
for (int i=0;i<=brightnessPWM;i++){
delay(glowDelay);
lcd.clear();
exposureLoop=1;
} //End of While
exposureLoop=0;
} //End Of Startup Button
delay(20);
}//End of loop
Video Link: https://drive.google.com/file/d/13sFhu4S1CPtQmAqnGYUHBiW9hJq4cn04/view?usp=sharing
