I have been working with my NodeMCU and firebase for a few weeks now, and up to a few days ago, it was working. The code below is for demo firebase provides and even that won't connect to my real-time database.
Copyright 2015 Google Inc.
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
// FirebaseDemo_ESP8266 is a sample that demo the different functions
// of the FirebaseArduino API.
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
// Set these to run example.
#define FIREBASE_HOST "ext***1d.firebaseio.com"
#define FIREBASE_AUTH "onAOXu1E2q***r1Ap2iW"
#define WIFI_SSID "VM***595"
#define WIFI_PASSWORD "vys3***nqy"
// connect to wifi.
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("connecting");
Serial.print(".");
Serial.print("connected: ");
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
int n = 0;
// set value
Firebase.setFloat("number", 42.0);
// handle error
if (Firebase.failed()) {
Serial.print("setting /number failed:");
Serial.println(Firebase.error());
return;
// update value
Firebase.setFloat("number", 43.0);
// handle error
return;
// get value
Serial.print("number: ");
Serial.println(Firebase.getFloat("number"));
// remove value
Firebase.remove("number");
// set string value
Firebase.setString("message", "hello world");
// handle error
Serial.print("setting /message failed:");
return;
// set bool value
Firebase.setBool("truth", false);
// handle error
Serial.print("setting /truth failed:");
return;
// append a new value to /logs
String name = Firebase.pushInt("logs", n++);
// handle error
Serial.print("pushing /logs failed:");
return;
Serial.print("pushed: /logs/");
Serial.println(name);
To my knowledge, the firebase library is up to date, so I'm not sure what the issue is. My internet is ok as the code for that works and prints my IP address. The sketch compiles fine, and uploads fine, just no connection to firebase.
Also, I apologise, I know there are a few of these types of topics, but I wasn't able to find anything that worked.
