NodeMCU v0.9 Unreadable Output
Good day, I am trying to connect my NodeMCU v0.9 with the code I found on instructables.
I don't know if the code is working because the resulting text is unreadable.
I included the screenshot of the output, and here's the code I used.
I already changed the ssid and password in accordance to my wifi's information.
#include "ESP8266WiFi.h"
// WiFi parameters to be configured
const char* ssid = "mySSID";
const char* password = "myPassword";
void setup(void)
  Serial.begin(11520);
  // Connect to WiFi
  WiFi.begin(ssid, password);
  // while wifi not connected yet, print '.'
  // then after it connected, get out of the loop
     Serial.print(".");
  //print a new line, then print WiFi connected and the IP address
  Serial.println("");
  Serial.println("WiFi connected");
  // Print the IP address
  // Nothing
The problem is your baud rate. You have to set the same baud rate in the Serial Monitor as in your code.
11520 is not a standard rate, you probably mean 115200.
omegatron20:
... with the code I found on instructables.
Just be aware that even though there are some good projects on there, a lot of it is just garbage, and just copying the code isn't a very good idea.
You might be interested in this Beginner's Guide to the ESP8266.
Pieter
