NodeMCU v3 + CC1101 433MHz v2: Unable to make it work
Hi all, a complete newbie here.
My idea was to replicate a 433MHz remote control (on/off). For that, I got a NodeMCU v3 and a CC1101 v2 433MHz module. The connection diagram used is
CC1101 v2 Pin Number CC1101 Pin Name NodeMCU Pin Description
1 GND GND Ground
2 VCC 3V3 Power supply (3.3V)
3 GDO0 D2 (GPIO4) General-purpose output (status/interrupts)
4 CSN (CS) D8 (GPIO15) Chip Select (SPI)
5 SCK D5 (GPIO14) SPI Clock
6 MOSI D7 (GPIO13) SPI Master Out, Slave In
7 MISO/GDO1 D6 (GPIO12) SPI Master In, Slave Out
8 GDO2 Not Connected General-purpose output (optional)
And this is my code:
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
unsigned long lastAliveMessage=0;
  delay(10);
  Serial.println("Starting, let's wait 10 seconds");
  delay(10000);
  Serial.println("Enabling receiving");
  mySwitch.enableReceive(4); // Use GPIO4 (D2) for receiving
  Serial.println("Listening for 433MHz signals...");
  if (millis() - lastAliveMessage>5000){
    Serial.println("I'm alive");
    lastAliveMessage = millis();
  if (mySwitch.available()) {
    unsigned long value = mySwitch.getReceivedValue();
    if (value == 0) {
      Serial.println("Unknown encoding");
      Serial.print("Received: ");
      Serial.println(value);
    mySwitch.resetAvailable();
After uploading this skect to the NodeMCU, the serial output show that the board was continuesly restarting, plus a bunch of unreadable chars. If I commented out all the lines related to the mySwitch variable OR I disconected pin 3 (D2 in NodeMCU), the output was as expected. I've tried other libraries (SmartRC, CC1101...), but I haven't even been able to compile the sketch.
Any idea of what am I doing wrong?
Thanks!
Gosh, I feel so incompetent, I don't even know how to edit my original post. When I say that the "output is as expected", I meant that the regular output ("I'm alive") was printed
I haven't used cc1101, but I expect you need to use cc1101 specific library together with rcswitch or at least pre configure cc1101 to output rf-signal on interrupt pin gd0.
