Nodemcu v3 with bme680 sensor
Hi Everyone
I'm trying to realize this project nodemcu v3 with bme680 sensor but at the end when I need to connect ESP web server.I get error like down below.
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include <ESP8266WiFi.h>
#include "ESPAsyncWebServer.h"
// Replace with your network credentials
const char* ssid = "xxxxx";
const char* password = "yyyyy";
//Uncomment if using SPI
/*#define BME_SCK 14
#define BME_MISO 12
#define BME_MOSI 13
#define BME_CS 15*/
Adafruit_BME680 bme; // I2C
//Adafruit_BME680 bme(BME_CS); // hardware SPI
//Adafruit_BME680 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK);
float temperature;
float humidity;
float pressure;
float gasResistance;
AsyncWebServer server(80);
AsyncEventSource events("/events");
unsigned long lastTime = 0;
unsigned long timerDelay = 30000;  // send readings timer
void getBME680Readings(){
  // Tell BME680 to begin measurement.
  unsigned long endTime = bme.beginReading();
  if (endTime == 0) {
    Serial.println(F("Failed to begin reading :("));
    return;
  if (!bme.endReading()) {
    Serial.println(F("Failed to complete reading :("));
    return;
  temperature = bme.temperature;
  pressure = bme.pressure / 100.0;
  humidity = bme.humidity;
  gasResistance = bme.gas_resistance / 1000.0;
String processor(const String& var){
  getBME680Readings();
  //Serial.println(var);
  if(var == "TEMPERATURE"){
    return String(temperature);
  else if(var == "HUMIDITY"){
    return String(humidity);
  else if(var == "PRESSURE"){
    return String(pressure);
  else if(var == "GAS"){
    return String(gasResistance);
  return String();
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
  <title>BME680 Web Server</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
  <link rel="icon" href="data:,">
  <style>
    html {font-family: Arial; display: inline-block; text-align: center;}
    p {  font-size: 1.2rem;}
    body {  margin: 0;}
    .topnav { overflow: hidden; background-color: #4B1D3F; color: white; font-size: 1.7rem; }
    .content { padding: 20px; }
    .card { background-color: white; box-shadow: 2px 2px 12px 1px rgba(140,140,140,.5); }
    .cards { max-width: 700px; margin: 0 auto; display: grid; grid-gap: 2rem; grid-template-columns: repeat(auto-fit, minmax(300px, 1fr)); }
    .reading { font-size: 2.8rem; }
    .card.temperature { color: #0e7c7b; }
    .card.humidity { color: #17bebb; }
    .card.pressure { color: #3fca6b; }
    .card.gas { color: #d62246; }
  </style>
</head>
<body>
  <div class="topnav">
    <h3>BME680 WEB SERVER</h3>
  </div>
  <div class="content">
    <div class="cards">
      <div class="card temperature">
        <h4><i class="fas fa-thermometer-half"></i> TEMPERATURE</h4><p><span class="reading"><span id="temp">%TEMPERATURE%</span> &deg;C</span></p>
      </div>
      <div class="card humidity">
        <h4><i class="fas fa-tint"></i> HUMIDITY</h4><p><span class="reading"><span id="hum">%HUMIDITY%</span> &percnt;</span></p>
      </div>
      <div class="card pressure">
        <h4><i class="fas fa-angle-double-down"></i> PRESSURE</h4><p><span class="reading"><span id="pres">%PRESSURE%</span> hPa</span></p>
      </div>
      <div class="card gas">
        <h4><i class="fas fa-wind"></i> GAS</h4><p><span class="reading"><span id="gas">%GAS%</span> K&ohm;</span></p>
      </div>
    </div>
  </div>
<script>
if (!!window.EventSource) {
 var source = new EventSource('/events');
 source.addEventListener('open', function(e) {
  console.log("Events Connected");
 }, false);
 source.addEventListener('error', function(e) {
  if (e.target.readyState != EventSource.OPEN) {
    console.log("Events Disconnected");
 }, false);
 source.addEventListener('message', function(e) {
  console.log("message", e.data);
 }, false);
 source.addEventListener('temperature', function(e) {
  console.log("temperature", e.data);
  document.getElementById("temp").innerHTML = e.data;
 }, false);
 source.addEventListener('humidity', function(e) {
  console.log("humidity", e.data);
  document.getElementById("hum").innerHTML = e.data;
 }, false);
 source.addEventListener('pressure', function(e) {
  console.log("pressure", e.data);
  document.getElementById("pres").innerHTML = e.data;
 }, false);
 source.addEventListener('gas', function(e) {
  console.log("gas", e.data);
  document.getElementById("gas").innerHTML = e.data;
 }, false);
</script>
</body>
</html>)rawliteral";
  // Set the device as a Station and Soft Access Point simultaneously
  WiFi.mode(WIFI_AP_STA);
  // Set device as a Wi-Fi Station
  WiFi.begin(ssid, password);
    Serial.println("Setting as a Wi-Fi Station..");
  Serial.print("Station IP Address: ");
  // Init BME680 sensor
  if (!bme.begin()) {
    Serial.println(F("Could not find a valid BME680 sensor, check wiring!"));
    while (1);
  // Set up oversampling and filter initialization
  bme.setTemperatureOversampling(BME680_OS_8X);
  bme.setHumidityOversampling(BME680_OS_2X);
  bme.setPressureOversampling(BME680_OS_4X);
  bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
  bme.setGasHeater(320, 150); // 320*C for 150 ms
  // Handle Web Server
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html, processor);
  // Handle Web Server Events
  events.onConnect([](AsyncEventSourceClient *client){
    if(client->lastId()){
      Serial.printf("Client reconnected! Last message ID that it got is: %u\n", client->lastId());
    // send event with message "hello!", id current millis
    // and set reconnect delay to 1 second
    client->send("hello!", NULL, millis(), 10000);
  server.addHandler(&events);
  server.begin();
  if ((millis() - lastTime) > timerDelay) {
    Serial.printf("Temperature = %.2f ºC \n", temperature);
    Serial.printf("Humidity = %.2f % \n", humidity);
    Serial.printf("Pressure = %.2f hPa \n", pressure);
    Serial.printf("Gas Resistance = %.2f KOhm \n", gasResistance);
    // Send Events to the Web Server with the Sensor Readings
    events.send("ping",NULL,millis());
    events.send(String(temperature).c_str(),"temperature",millis());
    events.send(String(humidity).c_str(),"humidity",millis());
    events.send(String(pressure).c_str(),"pressure",millis());
    events.send(String(gasResistance).c_str(),"gas",millis());
    lastTime = millis();
Station IP Address: 192.168.xxxx
User exception (panic/abort/assert)
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Panic core_esp8266_main.cpp:137 __yield
>>>stack>>>
ctx: sys
sp: 3fffec30 end: 3fffffb0 offset: 0000
3fffec30:  3fffecc1 00000001 00000001 3ffeee74
3fffec40:  000000fe 00000000 00000000 00000000
3fffec50:  00000000 00000000 00000000 3ffef130
3fffec60:  00000001 00000001 00000000 00000001
3fffec70:  3ffeee74 00000000 00000001 4020ab22
3fffec80:  00000000 7f929f00 00000020 4020ab8f
3fffec90:  40100574 00000001 00000000 4020a3d1
3fffeca0:  00000009 00000005 3fffed64 40202f12
3fffecb0:  3ffeee74 00000000 00000001 40201c31
<<<stack<<<
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v0004f910
~ld
I'd start by putting a Serial.flush after every Serial print.
no difference
#include <Wire.h>
#include <SPI.h>
const char* ssid = "xxx";
const char* password = "yyyy";
#define BME_MISO 12
#define BME_MOSI 13
#define BME_CS 15*/
float temperature;
float humidity;
float pressure;
  if (endTime == 0) {
    Serial.flush();
    return;
    Serial.flush();
    return;
  return String();
<head>
  <style>
    body {  margin: 0;}
  </style>
</head>
<body>
  </div>
    <div class="cards">
      </div>
      </div>
      </div>
      </div>
    </div>
  </div>
<script>
 }, false);
 }, false);
 }, false);
 }, false);
 }, false);
 }, false);
 }, false);
</script>
</body>
  Serial.flush();
  Serial.flush();
  Serial.flush();
  if (!bme.begin()) {
    Serial.flush();
    while (1);
      Serial.flush();
  server.begin();
    Serial.flush();
    Serial.flush();
    Serial.flush();
    Serial.flush();
    Serial.flush();
OK, it's always worth a try.
Time to start debugging.
try adding some print statements, e.g.
if (!bme.begin()) {
    Serial.flush();
    while (1);
 Serial.println(("BME680 OK");
  Serial.println((" setTemperatureOversampling OK");
to give you some idea of where it fails
Actually I'm getting all temp values.But some thing happens when I try to run Ip address on my smart phone.
 setHumidityOversampling OK
 setPressureOversampling OK
 setIIRFilterSize OK
 setGasHeater OK
What does that mean, please?
this error occurs when I call on my smart phone browser 192.168.x.x (esp web server) . If I don't there is no error.
Station IP Address: 192.168.x.y
 setIIRFilterSize OK
 setGasHeater OK
>>>stack>>>
this error
you are calling
doubt if printf() will work - try changing it to
 Serial.print("Client reconnected! Last message ID that it got is: ");
Serial.println(client->lastId());
if you wish to use printf() type output try
char text[100]={0};
 sprintf(text,"Client reconnected! Last message ID that it got is: %u\n", client->lastId());
Serial.print(text);
same with it
>>>stack>>>
error in original code - try
char text[100]={0};
Serial.print(text);
I removed all unnecessary serial outputs. But same nothing has changed.
#include <Wire.h>
#include <SPI.h>
const char* ssid = "xxxx";
const char* password = "yyyyyy";
#define BME_MISO 12
#define BME_MOSI 13
#define BME_CS 15*/
float temperature;
float humidity;
float pressure;
  if (endTime == 0) {
    return;
    return;
  return String();
<head>
  <style>
    body {  margin: 0;}
  </style>
</head>
<body>
  </div>
    <div class="cards">
      </div>
      </div>
      </div>
      </div>
    </div>
  </div>
<script>
 }, false);
 }, false);
 }, false);
 }, false);
 }, false);
 }, false);
 }, false);
</script>
</body>
  if (!bme.begin()) {
    while (1);
      //Serial.printf("Client reconnected! Last message ID that it got is: %u\n", client->lastId());
      //Serial.print("Client reconnected! Last message ID that it got is: ");
      //Serial.println(client->lastId());
      char text[100]={0};
      sprintf(text, printf("Client reconnected! Last message ID that it got is: %u\n", client->lastId()));
      Serial.print(text);
  server.begin();
Temperature = 21.66 ºC
Humidity = 62.07
Pressure = 1003.59 hPa
Gas Resistance = 30.38 KOhm
Temperature = 21.77 ºC
Humidity = 60.12
Pressure = 1003.57 hPa
Gas Resistance = 30.29 KOhm
Temperature = 21.86 ºC
Humidity = 59.05
Gas Resistance = 30.25 KOhm
Temperature = 21.93 ºC
Humidity = 58.98
Pressure = 1003.56 hPa
Gas Resistance = 30.16 KOhm
>>>stack>>>
ctx: sys
sp: 3fffeb30 end: 3fffffb0 offset: 0000
3fffeb30:  3fffec08 00000001 00000001 00000000
3fffeb40:  000000fe 00000000 00000000 00000000
3fffeb50:  00000000 00000000 00000000 3ffef1f8
3fffeb60:  00000000 000000b8 00000000 00000001
3fffeb70:  00000001 3fffece0 3ffeee74 4020c3e6
3fffeb80:  3ffef1fc 00000000 0000008c 4020c453
3fffeb90:  40100610 3ffeee74 3fffece0 4020bc41
3fffeba0:  60000314 3ffef1fc 00000001 402035ea
3fffebb0:  00000001 3fffece0 3ffeee74 402020e5
3fffebc0:  00000000 00000000 00000000 00000000
3fffebd0:  00000000 00000000 00000000 00000000
3fffebe0:  00000000 00000000 00000000 00000000
3fffebf0:  00000000 00000000 00000000 00000000
3fffec00:  00000000 00000000 a6520020 90107790
3fffec10:  0080715a 00b88c00 3fff0404 40203b24
<<<stack<<<
tail 4
chksum 0xcc
tail 4
chksum 0xc9
csum 0xc9
v0004f8e0
~ld
I found this project better. It works without any issues.
https://iotprojectsideas.com/indoor-air-quality-monitoring-with-bme680-esp8266-webserver/
