Hello, I need some help with nodemcu webserver code. I want to submit data from web page form to arduino sketch and the response from sketch to html page. I adopted code from some library example and trying to modifying according to my need. (In code i have changed variables, code is not ok just posting you people to understand the flow. sorry
HTML File:
<head>
<meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=no" />
<title>esp</title>
<h6>
Command:
<span id="cmd"></span>
</h6>
<body>
<div style='text-align:left;display:inline-block;width:150px;padding:1px'>
<form id="yform" onsubmit="return transmit(this)">
<button name="led1" value="on">Relay 1 On</button>
<button name="led1" value="off">Relay 1 Off</button>
<button name="led2" value="on">Relay 2 On</button>
<button name="led2" value="off">Relay 2 Off</button>
<button name="led3" value="on">Relay 3 On</button>
<button name="led3" value="off">Relay 3 Off</button>
<button name="led4" value="on">Relay 4 On</button>
<button name="led4" value="off">Relay 4 Off</button>
<button name="led5" value="on">Relay 5 On</button>
<button name="led5" value="off">Relay 5 Off</button>
<button name="led6" value="on">Relay 6 On</button>
<button name="led6" value="off">Relay 6 Off</button>
<button name="led7" value="on">Relay 7 On</button>
<button name="led7" value="off">Relay 7 Off</button>
<button name="led8" value="on">Relay 8 On</button>
<button name="led8" value="off">Relay 8 Off</button>
</form>
<script>
function g(i) { return document.getElementById(i) };
function transmit(f) {
if (!xhttp) { //prevent simultaneous requests
xhttp = new XMLHttpRequest();
xhttp.open("POST", "/api");
xhttp.send(f ? (new FormData(f)) : "");
xhttp.onreadystatechange = function () {
if (xhttp.readyState === XMLHttpRequest.DONE && xhttp.status === 200) {
var data = JSON.parse(xhttp.responseText);
g("cmd").innerHTML = data.cmd;
xhttp = null;
return false; //prevent form redirect
</script>
Arduino Sketch:
 //handles commands from webpage, sends live data in JSON format
 server.on("/api", []() {
  DEBUG_PRINT("server.on /api");
 Â
  if (server.hasArg("led")) {
   y = server.arg("led");
   DEBUG_PRINT("cmd: " + cmd);
  } //if
  //build json object of program data
  StaticJsonBuffer<200> jsonBuffer;
  JsonObject &json = jsonBuffer.createObject();
Â
  json["cmd"] = cmd;
  char jsonchar[200];
  json.printTo(jsonchar); //print to char array, takes more memory but sends in one piece
  server.send(200, "application/json", jsonchar);
 }); //server.on api
