Here is simple code written to Auto Connect library. In below code i would like to add the local webpage that could able to display data like this
I am using nodemcu unit.
#if defined(ARDUINO_ARCH_ESP8266)
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#elif defined(ARDUINO_ARCH_ESP32)
#include <WiFi.h>
#include <WebServer.h>
#endif
#include <time.h>
#include <AutoConnect.h>
ESP8266WebServer Server;
WebServer Server;
#endif
AutoConnect Portal(Server);
AutoConnectConfig Config; // Enable autoReconnect supported on v0.9.4
#define TIMEZONE (3600 * 9) // Tokyo
#define NTPServer1 "ntp.nict.jp" // NICT japan.
#define NTPServer2 "time1.google.com"
void rootPage() {
String content =
"<html>"
"<head>"
"<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">"
"</head>"
"<body>"
"<h2 align=\"center\" style=\"color:blue;margin:20px;\">Hello, world</h2>"
"<h3 align=\"center\" style=\"color:gray;margin:10px;\">{{DateTime}}</h3>"
"<p style=\"padding-top:10px;text-align:center\">" AUTOCONNECT_LINK(COG_32) "</p>"
"</body>"
"</html>";
static const char *wd[7] = { "Sun","Mon","Tue","Wed","Thr","Fri","Sat" };
struct tm *tm;
time_t t;
char dateTime[26];
t = time(NULL);
tm = localtime(&t);
sprintf(dateTime, "%04d/%02d/%02d(%s) %02d:%02d:%02d.",
tm->tm_year + 1900, tm->tm_mon + 1, tm->tm_mday,
wd[tm->tm_wday],
tm->tm_hour, tm->tm_min, tm->tm_sec);
content.replace("{{DateTime}}", String(dateTime));
Server.send(200, "text/html", content);
// Behavior a root path of ESP8266WebServer.
Server.on("/", rootPage);
// Enable saved past credential by autoReconnect option,
// even once it is disconnected.
Config.autoReconnect = true;
Portal.config(Config);
// Establish a connection with an autoReconnect option.
if (Portal.begin()) {
Serial.println("WiFi connected: " + WiFi.localIP().toString());
configTime(TIMEZONE, 0, NTPServer1, NTPServer2);
Portal.handleClient();
