NODEMCU WiFi DNS(?) problem
Hi
I set up a project based on NODEMCU. Basically it's an automated school bell system based on the TimeLib and TimeAlarms libraries. NODEMCU connects to an NTP server via WiFi, updates the time and runs the schedule.
I have two identical systems running the same code but each system is connected to the internet in a different way: one of then is going through the school network infrastructure of my country. That is the one i have problem with. It seems that something blocks the request to the NTP server. As a result the system time is set to 00:00:00 1/1/1970 and the whole thing fails. I got it working a few days ago but a power shortage for a few seconds restarted the MCU and everything has been lost. The other system works flawlessly.
I know that the school network has a restriction on the DNS server that can be used. We cannot use is Google's DNS. We can either set it to auto or use specific IP addresses. I tried both methods but no result.
Here is a part of my code (i removed irrelevant parts):
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <TimeLib.h>
#include <WiFiUdp.h>
#include <TimeAlarms.h>
ESP8266WebServer server;
static const char ntpServerName[] = "ntp.sch.gr";
const int timeZone = 3;
WiFiUDP Udp;
unsigned int localPort = 8888;  // local port to listen for UDP packets
time_t getNtpTime();
void sendNTPpacket(IPAddress &address);
// =================== Static IP setup ===================
// Set your Static IP address
IPAddress local_IP(192, 168, 1, 249);
// Set your Gateway IP address
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 0, 0);
IPAddress primaryDNS(194, 63, 237, 4);   //optional - School Network DNS
IPAddress secondaryDNS(194, 63, 238, 4); //optional
// =================== Alarm ID's ========================
AlarmId id1h;
///.... irrelevant code - removed!
AlarmId idRestart_2;
// =================== END Alarm ID's ========================
char wPagePM[] PROGMEM = R"foo(
      <!DOCTYPE html>
        <meta http-equiv="content-type" content="text/html; charset=utf-8" />
        <html>
          <body id="myBody">
            <div id="resHolder">
// irrelevant code - web user interface - REMOVED
         </html>
      )foo";
  char* ssid = "blahblah";
  char* pass = "123123";
  WiFi.setAutoReconnect(true);
  WiFi.persistent(true);
 // Configures static IP address
  if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
    Serial.println("STA Failed to configure");
  WiFi.begin(ssid, pass);
  Serial.print("Connecting");
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.print("Σύνδεση επιτυχής, IP address: ");
  Serial.println("Εκκίνηση UDP");
  Udp.begin(localPort);
  Serial.print("Τοπική θύρα: ");
  Serial.println(Udp.localPort());
  Serial.println("αναμονή συγχρονισμού");
  setSyncProvider(getNtpTime);
  setSyncInterval(8 * 3600);
  server.on("/", handleRoot);
  server.on("/dlrm", handleDisableLrm);
  server.on("/elrm", handleEnableLrm);
  server.on("/ring", handleRing);
  server.begin();
  pinMode(D2, OUTPUT);
  //pinMode(D5, OUTPUT);
  digitalWrite(D2, LOW);
  //digitalWrite(D4, LOW);
  // ============ Alarm declarations ================
  id1h = Alarm.alarmRepeat(8, 15, 0, BellRing);
 //  ... removed
  //idRestart_2 = Alarm.alarmRepeat(dowMonday, 8, 14, 0, RestartAlarms);
  Serial.print("Count: ");
  Serial.println(Alarm.count());
  // ============ END Alarm declarations ================
 /*-------- Alarm functions ----------*/
  server.handleClient();
  Alarm.delay(50);
 /*-------- NTP code ----------*/
const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packets
time_t getNtpTime()
  IPAddress ntpServerIP; // NTP server's ip address
  while (Udp.parsePacket() > 0) ; // discard any previously received packets
  Serial.println("Transmit NTP Request");
  // get a random server from the pool
  WiFi.hostByName(ntpServerName, ntpServerIP); // THAT"S WHERE IT'S FAILS
  Serial.print(ntpServerName);
  Serial.print(": ");
  Serial.println(ntpServerIP);           // NO SERVER SET
  sendNTPpacket(ntpServerIP);
  uint32_t beginWait = millis();
  while (millis() - beginWait < 1500) {
    int size = Udp.parsePacket();
    if (size >= NTP_PACKET_SIZE) {
      Serial.println("Receive NTP Response");
      Udp.read(packetBuffer, NTP_PACKET_SIZE);  // read packet into the buffer
      unsigned long secsSince1900;
      // convert four bytes starting at location 40 to a long integer
      secsSince1900 =  (unsigned long)packetBuffer[40] << 24;
      secsSince1900 |= (unsigned long)packetBuffer[41] << 16;
      secsSince1900 |= (unsigned long)packetBuffer[42] << 8;
      secsSince1900 |= (unsigned long)packetBuffer[43];
      return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
  Serial.println("No NTP Response :-(");
  return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12] = 49;
  packetBuffer[13] = 0x4E;
  packetBuffer[14] = 49;
  packetBuffer[15] = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  Udp.write(packetBuffer, NTP_PACKET_SIZE);
  Udp.endPacket();
This method WiFi.hostByName(ntpServerName, ntpServerIP); is supposed to return the IP address of the NTP server, but it fails. A tech of the school network support team did some tests today via Anydesk and he successfully reached various NTP servers from the CMD. My router can get the time and date from the NPT stored in it's settings. Everything works OK except this little thing!
Any ideas please?
Thanks in advance
Minas
Are you sure this network mask is correct? All data would let me assume a network mask of 255.255.255.0.
Thanks for the reply...
I had no problem connecting to the wifi with this mask setting. Changing it to 255.255.255.0 had no result. It still connects to the wifi but there's no access to the NTP server.
Anyway, I got the system running but connecting to the wifi with a dynamic IP. The fixed IP was a preferable option but it was impossible to find out what's wrong...
try
static const char ntpServerName[] = "europe.pool.ntp.org)";
It won't connect no matter what host I give. I seems that hostByName() doesn't work properly at all situations. I found similar reports ie hostname resolved with DHCP but failed with fixed IP.
Anyway... my issue is semi-closed! DHCP is not the best option but yet it's a fix.
Thanks for the input!
Maybe you could try Google's dns servers ?
8.8.8.8 was my initial setting... it doesn't work! As i mentioned we are not allowed to use DNS other than the servers provided by the school network.
Anyway i'll stick with the DHCP semi-solution for now.
Thanks for you help!
