Nodemcu with 5 neopixels issues
Hi all...
I had a working project on an Arduino Nano Every. Unfortunately the Every somehow was fried after more then a year of running.
My spare Every which I wanted to use then, fried uppon connecting to my pc... Nothing else connected yet.
So, after that, I wanted to move my project to an ESP8266
My goal:
Have 5 neopixels connected to a ESP8266 (NodeMCU) and a button to cycle through a few light patterns. I want to have all pixels off when starting the NodeMCU
I have connected the pixels via a breaboard to the nodemcu.
I have uploaded the code.
When starting or powering the board, pixel 1 goes on with full brightness white.
When using the button, it follows the program as designed. And pixel 1 is working according design as well..
But whatever I try, the board always starts up with pixel 1 on full brightness white.
Can someone please guide me in the right direction?
Thanks!
#define BUTTON_PIN   4    // Digital IO pin connected to the button.  This will be
                          // driven with a pull-up resistor so the switch should
                          // pull the pin to ground momentarily.  On a high -> low
                          // transition the button press logic will execute.
#define PIXEL_PIN    2   // Digital IO pin connected to the NeoPixels.
#define PIXEL_COUNT  5   // number of neopixel (change this accordingly)
// Parameter 1 = number of pixels in strip,  neopixel stick has 8
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_RGB     Pixels are wired for RGB bitstream
//   NEO_GRB     Pixels are wired for GRB bitstream, correct for neopixel stick
//   NEO_KHZ400  400 KHz bitstream (e.g. FLORA pixels)
//   NEO_KHZ800  800 KHz bitstream (e.g. High Density LED strip), correct for neopixel stick
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
bool oldState = HIGH;
int showType = 0;
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  // Get current button state.
  bool newState = digitalRead(BUTTON_PIN);
  // Check if state changed from high to low (button press).
  if (newState == LOW && oldState == HIGH) {
    // Short delay to debounce button.
    delay(20);
    // Check if button is still low after debounce.
    if (newState == LOW) {
      showType++;
      if (showType > 7)
        showType=0;
      startShow(showType);
  // Set the last button state to the old state.
  oldState = newState;
void startShow(int i) {
  switch(i){
    case 0: strip.clear();    // Black/off
    case 1: colorWipe(strip.Color(255, 0, 0), 50);  // Red
    case 2: colorWipe(strip.Color(0, 255, 0), 50);  // Green
    case 3: colorWipe(strip.Color(0, 0, 255), 50);  // Blue
    case 4: theaterChase(strip.Color(127, 127, 127), 50); // White
    case 5: theaterChase(strip.Color(127,   0,   0), 50); // Red
    case 6: theaterChase(strip.Color(  0,   0, 127), 50); // Blue
    case 7: strip.clear();
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (int i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
        strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      strip.show();
      delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
Maybe put
startShow(0);
in setup()?
That was a usefull answer! Thank you.
It did not work at first, but then i changed "case 0" to
    case 0: colorWipe(strip.Color(0, 0, 0), 50);  // all off
After that it worked perfectly.
I did test with the new case 0 and without the startShow(0); after that, and pixel 1 went on again... After adding, pixel 1 went off. So this was indeed the solution.
Thanks for your help! I can continue knitting now :blush:
Maybe you put it after strip.show() in setup() ?
