NodeMCUv3 ESP8266 WebServer from SD-Card
Dear community,
i havnt got a Solution from Web, but i coded one by myself.
My Question is:
Is there another method I can use to do the same the code now does?
I want to read the index.html file from ym sdacrd using my esp8266 and use this file as my index-file for webserver.
The Code i currently using is:
 Serial.print("Initializing SD card...");
  if (!SD.begin(15)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  myFile = SD.open("index.html", FILE_READ);
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
        request->send(200, "text/html", myFile.readString());
Which works great. But my question is: is this more work for the microcontroller or is this the best solution to read the idnex.html from sd-card?
If not, please let me know a better solution!
If this is the only SOlution, Ill make a tutorial how to use a SD-Card for WebServer content, cuz i coded the solution bymyself.
Greetz BlackLeakz,
and sorry for my bad english
see the FSBrowser example of the ESP8266WebServer library
