Noice Z shifting
Hello sir,
We are facing a problem of noise in the z axis.
We are a manufacturer of higher production machines,s
Machine is working with G CODE
SERVO MOTOR IS ELD MODEL OF LEADSHINE MAKE.
Problem is machine running few cycle,s good,but after 50,150 cycle,s it has problem of shifting equally lo ke 0.6mm in every cycle,if we home then it came back on the same ok position again.
And it,s happened 4/5time in a day at any time.
We found the pulse coming from controller to motor is low when it,s happened shift.
1)We have changed stepdown transform as our machine is single phase.
2)We added filters on XYZ separately
3)We use ferrite core in all axis also inain supply of 5v cnc controller.
But you come to a hobbyist forum for free advice?
I moved your topic to an appropriate forum category @lockmaster.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
