noInterrupts() function resets ESP32-S2
Hi, I'm new to using ESP32-S2, I've always worked with Atmega328p and now I'm using ESP.
I created a PCB with an ESP32-S2 on it, I didn't use any module, but the chip soldered directly to the board. Everything has been working fine, PWM, ADC, I2C, UART, etc. But when I use the noInterrupts() function, the ESP32-S2 simply restarts, I've done several tests, used the cli(), portDISABLE_INTERRUPTS() functions and it keeps restarting when it arrives at these functions.
I'm using a 40Mhz crystal with 18pF capacitors.
Has anyone been through a similar situation?
Could you show your test code?
  gpio_set_direction(GPIO_NUM_17, GPIO_MODE_OUTPUT);
  gpio_set_level(GPIO_NUM_17, LOW);
  gpio_set_direction(GPIO_NUM_18, GPIO_MODE_OUTPUT);
  gpio_set_level(GPIO_NUM_18, LOW);
  gpio_set_level(GPIO_NUM_17, HIGH);
  noInterrupts();
  gpio_set_level(GPIO_NUM_18, HIGH);
This is just an example code, but in any kind of algorithm I try the noInterrupts() will reset the ESP. In this case of the code, it doesn't even enter the void loop, it restarts and is in an infinite loop of restarting when it arrives at the noInterrupts() function;
It is wrong to disable interrupts and not enable them. No one controller will work like this.
This function is used to turn off interrupts for the duration of some short operation, after which interrupts(); should immediately follow.
try this:
 noInterrupts();
 interrupts();
on an ESP32 you should use semaphores rather than disabling interrupts. I'm not even sure cli() does the right thing
It also keeps restarting even activating Interrupts() after executing the function I want.
Do you have any example about this? I've never seen this application with semaphores.
may be your function use interrupts itself? - this scenario lead to reset
This is a strange way of setting up the gpio pins using the ESP32 API.
  noInterrupts();
I do this thing like this
voided setup()
  gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
  io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
  io_cfg.pull_down_en = GPIO_PULLDOWN_ENABLE; // enable pull down
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_0) | (1ULL << GPIO_NUM_18) ); //bit mask of the pins to set, assign gpio number to be configured
  gpio_config(&io_cfg); // configure the gpio based upon the parameters as set in the configuration structure
  io_cfg = {}; //set configuration structure back to default values
  io_cfg.mode = GPIO_MODE_OUTPUT;
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_4) | (1ULL << GPIO_NUM_5) | (1ULL << GPIO_NUM_19)  ); //bit mask of the pins to set, assign gpio number to be configured
  gpio_set_level( GPIO_NUM_4, LOW); // deenergize relay module
  gpio_set_level( GPIO_NUM_5, LOW); // deenergize valve
  gpio_set_level( GPIO_NUM_19, LOW); // deenergize valve
Also, why use the serial pins for this thingy?
Why use no interrupts?
You know you set no interrupts and then use delay() when nointerrupts shuts off the delaytimer. No wonder the ESP32 is kicking a WDT or Guru error.
This situation happens with any kind of code, so it can't be my specific function.
an application using semaphonres
#include <ESP32Time.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection info for WiFi and MQTT
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include <driver/adc.h>
#include <SimpleKalmanFilter.h>
WiFiClient      wifiClient; // do the WiFi instantiation thing
PubSubClient    MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32Time       rtc;
#define evtWaterCactus      ( 1 << 0 ) // declare an event
#define evtADCreading0      ( 1 << 3 )
EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
SemaphoreHandle_t sema_WaterCactus;
QueueHandle_t xQ_RemainingMoistureMQTT;
QueueHandle_t xQ_RM;
QueueHandle_t xQ_Message;
esp_timer_handle_t oneshot_timer; //veriable to store the hardware timer handle
const int payloadSize = 150;
struct stu_message
  char payload [payloadSize] = {'\0'};
  String topic ;
} x_message;////
int    mqttOK = 0;
bool   TimeSet = false;
//bool   manualPumpOn = false;
void IRAM_ATTR oneshot_timer_callback( void* arg )
  BaseType_t xHigherPriorityTaskWoken;
  xEventGroupSetBitsFromISR( eg, evtWaterCactus, &xHigherPriorityTaskWoken );
} //void IRAM_ATTR oneshot_timer_callback( void* arg )
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  // clear locations
  memset( x_message.payload, '\0', payloadSize ); // clear payload char buffer
  x_message.topic = ""; //clear topic string buffer
  x_message.topic = topic; //store new topic
  memcpy( x_message.payload, payload, length );
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  x_message.topic.reserve( payloadSize );
  xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
  xQ_RemainingMoistureMQTT = xQueueCreate( 1, sizeof(float) ); // sends a queue copy
  xQ_RM = xQueueCreate( 1, sizeof(float) );
  eg = xEventGroupCreate(); // get an event group handle
  sema_mqttOK =  xSemaphoreCreateBinary();
  sema_WaterCactus = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  xSemaphoreGive( sema_WaterCactus );
  // set up A:D channels  https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
  adc1_config_width(ADC_WIDTH_12Bit);
  adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11);// using GPIO 39
  // https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/esp_timer.html?highlight=hardware%20timer High Resoultion Timer API
  esp_timer_create_args_t oneshot_timer_args = {}; // initialize High Resoulition Timer (HRT) configuration structure
  oneshot_timer_args.callback = &oneshot_timer_callback; // configure for callback, name of callback function
  esp_timer_create( &oneshot_timer_args, &oneshot_timer ); // assign configuration to the HRT, receive timer handle
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 10000, NULL, 6, NULL, 1 );
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 10000, NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( fPublish, "fPublish", 9000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fReadAD, "fReadAD", 9000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fDoMoistureDetector, "fDoMoistureDetector", 70000, NULL, 4, NULL, 1 );
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 2, NULL, 1 );
} //void setup()
// check gpiopin for cactus is present
// water cactus upon detection
// wait 30 days to water the cactus again
// to water
// let fDoMoistureDetector know of motor use.
// open valve
// run motor for 10 times each time for 10 seconds 5 minutes apart
// after sequence is done release fDoMoistureDetector
// start counting 30 days
void fWaterCactus( void * parameter )
  uint32_t microSecondsInADay = 86400000000;
  uint32_t DayCount           = 29;
  uint64_t pastTime           = esp_timer_get_time();
  uint32_t WaterTimeCount     = 0;
  //GPIO_NUM_18 is cactus detect pin.
  for (;;)
    if ( gpio_get_level( GPIO_NUM_18 ) )
      if ( (esp_timer_get_time() - pastTime) >= microSecondsInADay )
        DayCount++;
      if (DayCount == 30 )
        xSemaphoreTake( sema_WaterCactus, portMAX_DELAY );// stops the other task from running the pump.
        //water cactus
        while ( WaterTimeCount < 10 )
          gpio_set_level( GPIO_NUM_19, HIGH); // energize/open valve
          WaterPump0_on();
          // one minute of uS = 60000000
          esp_timer_start_once( oneshot_timer, 60000000 );
          xEventGroupWaitBits (eg, evtWaterCactus, pdTRUE, pdTRUE, portMAX_DELAY ); // event will be triggered by the timer expiring, wait here for the 280uS
          WaterPump0_off();
          gpio_set_level( GPIO_NUM_19, LOW); // deenergize/close valve
          WaterTimeCount++;
        WaterTimeCount = 0;
        DayCount = 0; // reset day couunt
      DayCount = 0;
  } // for(;;)
  vTaskDelete( NULL );
void fReadAD( void * parameter )
  float    ADbits = 4096.0f;
  float    uPvolts = 3.3f;
  float    adcValue_b = 0.0f; //plant in yellow pot
  uint64_t TimePastKalman  = esp_timer_get_time(); // used by the Kalman filter UpdateProcessNoise, time since last kalman calculation
  float    WetValue = 1.07f; // value found by putting sensor in water
  float    DryValue = 2.732f; // value of probe when held in air
  float    Range = DryValue - WetValue;
  float    RemainingMoisture = 100.0f;
  SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
  for (;;)
    xEventGroupWaitBits (eg, evtADCreading0, pdTRUE, pdTRUE, portMAX_DELAY ); //
    adcValue_b = float( adc1_get_raw(ADC1_CHANNEL_3) ); //take a raw ADC reading
    adcValue_b = ( adcValue_b * uPvolts ) / ADbits; //calculate voltage
    KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
    adcValue_b = KF_ADC_b.updateEstimate( adcValue_b ); // apply simple Kalman filter
    TimePastKalman = esp_timer_get_time(); // time of update complete
    RemainingMoisture = 100.0f * (1 - ((adcValue_b - WetValue) / (DryValue - WetValue))); //remaining moisture =  1-(xTarget - xMin) / (xMax - xMin) as a percentage of the sensor wet dry volatges
    xQueueOverwrite( xQ_RM, (void *) &RemainingMoisture );
    //log_i( "adcValue_b = %f remaining moisture %f%", adcValue_b, RemainingMoisture );
void fPublish( void * parameter )
  for (;;)
    if ( xQueueReceive(xQ_RemainingMoistureMQTT, &RemainingMoisture, portMAX_DELAY) == pdTRUE )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.publish( topicRemainingMoisture_0, String(RemainingMoisture).c_str() );
      xSemaphoreGive( sema_MQTT_KeepAlive );
  } // for (;;)
} //void fPublish( void * parameter )
void WaterPump0_off()
  gpio_set_level( GPIO_NUM_4, LOW); //denergize relay module
void WaterPump0_on()
  gpio_set_level( GPIO_NUM_4, HIGH); //energize relay module
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
  int maxNonMQTTresponse = 12;
  TickType_t xLastWakeTime = xTaskGetTickCount();
  const TickType_t xFrequency = 5000; //delay for mS
  for (;;)
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
    mqttOK++;
    if ( mqttOK >= maxNonMQTTresponse )
      ESP.restart();
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
} //void fmqttWatchDog( void * paramater )
void fDoMoistureDetector1( void * parameter )
  //wait for a mqtt connection
  while ( !MQTTclient.connected() )
    vTaskDelay( 250 );
  int      TimeToPublish = 5000000; //5000000uS
  int      TimeForADreading = 100 * 1000; // 100mS
  uint64_t TimePastPublish = esp_timer_get_time(); // used by publish
  uint64_t TimeADreading   = esp_timer_get_time();
  const TickType_t xFrequency = 10; //delay for 10mS
  float    RemainingMoisture = 100.0f; //prevents pump turn on during start up
  bool     pumpOn = false;
  uint64_t PumpOnTime = esp_timer_get_time();
  int      PumpRunTime = 11000000;
  uint64_t PumpOffWait = esp_timer_get_time();
  uint64_t PumpOffWaitFor = 60000000; //one minute
  float    lowMoisture = 23.0f;
  float    highMoisture = 40.0f;
  for (;;)
    //read AD values every 100mS.
    if ( (esp_timer_get_time() - TimeADreading) >= TimeForADreading )
      xEventGroupSetBits( eg, evtADCreading0 );
    xQueueReceive(xQ_RM, &RemainingMoisture, 0 ); //receive queue stuff no waiting
    //read gpio 0 is water level good. Yes: OK to run pump : no pump off.   remaining moisture good, denergize water pump otherwise energize water pump.
    if ( RemainingMoisture >= highMoisture )
      WaterPump0_off();
    if ( !pumpOn )
      log_i( "not pump on ");
      if ( gpio_get_level( GPIO_NUM_0 ) )
        if ( RemainingMoisture <= lowMoisture )
          //has one minute passed since last pump energize, if so then allow motor to run
          if ( (esp_timer_get_time() - PumpOffWait) >= PumpOffWaitFor )
            gpio_set_level( GPIO_NUM_5, HIGH); //open valve
            WaterPump0_on();
            log_i( "pump on " );
            pumpOn = !pumpOn;
        //xSemaphoreGive( sema_RemainingMoisture );
        log_i( "water level bad " );
        WaterPump0_off();
        gpio_set_level( GPIO_NUM_5, LOW); //denergize/close valve
         pump goes on runs for X seconds then turn off, then wait PumpOffWaitTime before being allowed to energize again
      if ( (esp_timer_get_time() - PumpOnTime) >= PumpRunTime )
        log_i( "pump off " );
        WaterPump0_off(); // after 5 seconds turn pump off
        pumpOn = !pumpOn;
    // publish to MQTT every 5000000uS
    if ( (esp_timer_get_time() - TimePastPublish) >= TimeToPublish )
      xQueueOverwrite( xQ_RemainingMoistureMQTT, (void *) &RemainingMoisture );// data for mqtt publish
      TimePastPublish = esp_timer_get_time(); // get next publish time
}// end fDoMoistureDetector1()
void fDoMoistureDetector( void * parameter )
    vTaskDelay( 250 );
  for (;;)
      WaterPump0_off();
    if ( !pumpOn )
            WaterPump0_on();
            pumpOn = !pumpOn;
        WaterPump0_off();
        pumpOn = !pumpOn;
}// end fDoMoistureDetector()
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  const TickType_t xFrequency = 250; // 250mS
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
  vTaskDelete ( NULL );
void connectToMQTT()
  // create client ID from mac address
  byte mac[5];
  int count = 0;
  WiFi.macAddress(mac); // get mac address
  String clientID = String(mac[0]) + String(mac[4]);
  log_i( "connect to mqtt as client %s", clientID );
    MQTTclient.disconnect();
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    vTaskDelay( 250 );
    count++;
    if ( count == 5 )
      ESP.restart();
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topicOK );
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
} // void connectToWiFi()
void fparseMQTT( void *pvParameters )
  struct stu_message px_message;
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      if ( px_message.topic == topicOK )
        mqttOK = 0; // clear mqtt ok count
      if ( !TimeSet )
        String temp = "";
        temp = px_message.payload[0];
        temp += px_message.payload[1];
        temp += px_message.payload[2];
        temp += px_message.payload[3];
        int year =  temp.toInt();
        temp = "";
        temp = px_message.payload[5];
        temp += px_message.payload[6];
        int month =  temp.toInt();
        temp = "";
        temp = px_message.payload[8];
        temp += px_message.payload[9];
        int day =  temp.toInt();
        temp = "";
        temp = px_message.payload[11];
        temp += px_message.payload[12];
        int hour =  temp.toInt();
        temp = "";
        temp = px_message.payload[14];
        temp += px_message.payload[15];
        int min =  temp.toInt();
        rtc.setTime( 0, min, hour, day, month, year );
        log_i( "%s  ", rtc.getTime() );
        TimeSet = true;
      // manual pump control
      //      if ( str_eTopic == topicPumpState )
      //        if ( String(strPayload) == "off" )
      //          WaterPump0_off();
      //          manualPumpOn = false;
      //        if ( String(strPayload) == "on" )
      //          WaterPump0_on();
      //          manualPumpOn = true;
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
Hi Guy, very cool to see how you configure the GPIO through the API, I was just trying to understand how to configure it this way.
I am leaving my main code below, it is an attempt to migrate an eeprom simulation made for atmega328p to ESP32-S2. Could you help me to correctly configure the GPIO for this code?
 gpio_set_direction(GPIO_NUM_10, GPIO_MODE_INPUT_OUTPUT);
 gpio_set_direction(GPIO_NUM_13, GPIO_MODE_OUTPUT_OD);
 gpio_set_direction(GPIO_NUM_14, GPIO_MODE_INPUT);
 send_algo();
void send_algo()
  uint8_t prev_clk = 1;
  gpio_set_direction(GPIO_NUM_14, GPIO_MODE_INPUT);//DDRD &= ~(clk_mask);   // clk pin as input
  gpio_set_direction(GPIO_NUM_13, GPIO_MODE_OUTPUT_OD);//DDRD &= ~(sda_mask);   // sda pin as input
                         // -> we need to set pin low only once.
                         //    Toggling is done by setting pin to
                         //    input (let float high) or output (pull low).
                         //    FV-1 internal pullups are ok (tested).
  uint16_t pos = 0;                       //uint16_t
  uint8_t curr_byte = algo_buffer[pos];  //uint8_t
  uint8_t bit_mask = 0b10000000;         //uint8_t
  uint8_t clk_count = 0;                //uint8_t
  // Undivided attention for FV-1 requests
  noInterrupts();
  //// Notify FV-1 of patch change by toggling the notify pin
  gpio_set_level(GPIO_NUM_10,!gpio_get_level(GPIO_NUM_10));
  while(clk_count < 37)              // Handle the header
    int clk = gpio_get_level(GPIO_NUM_14);//PIND & clk_mask;
    if(clk && prev_clk) {           // scl went down
      switch(clk_count)
        case 8:
        case 17:
        case 26:
        case 36:
            //DDRD  |= sda_mask;         // send ACK - pull sda pin low
            gpio_set_direction(GPIO_NUM_13, GPIO_MODE_OUTPUT);
        default:
            //DDRD &= ~(sda_mask);       // Release
            gpio_set_direction(GPIO_NUM_13, GPIO_MODE_INPUT);
      clk_count++;
    prev_clk = clk;
  clk_count = 0;
  while(pos < 512)                   // Send the data
    if(!clk && prev_clk) {           // scl went down
      if(clk_count != 8) {           // Sending byte
        if (curr_byte & bit_mask) {
          //DDRD &= ~(sda_mask);       // Send 1 = Let High
          //DDRD  |= sda_mask;         // Send 0 = Pull Low
          bit_mask >>= 1;
          clk_count++;
      } else {                       // Let reciever ACK
        clk_count = 0;
        pos++;
    prev_clk = clk;
  interrupts();
My algo_buffer array is not in the code as it is a very large hex matrix and makes no difference for code analysis.
Are you try to disable interrupts during transferring whole buffer? - it won't work
ESP32 has EEPROM emulation on the flash, why do you need your own code?
Yes, I'm disabling interrupts to send the data, that's the way the project works on Atmega328p.
This code is making the ESP32-S2 simulate an EEPROM for an i2c master device, I am not trying to simulate an EEPROM for use by the ESP itself.
Well, sure I can try to help. First you can look at post#11 to see how I did the thing then you try to adapt the code to your thing. When you run into trouble just ask for help but don't expect me to just write it for you.
Oh, here is the docs, GPIO & RTC GPIO - ESP32 - — ESP-IDF Programming Guide latest documentation.
Even for atmega328 it was a bad idea.
And on ESP32, the watchdog constantly monitors the activity of the user code, and if it seems that the code is frozen, watchdog will immediately reset the board
Why do you not use standard I2C library? I don't think you have much experience to write I2c exchange yourself
Find out that it really is the watchdog that is restarting ESP32.
As I said before, this code was made for an Atmega328p and there is also the same code for esp8266. This master device that I'm trying to simulate the EEPROM has very little documentation, so that's why I'm trying to migrate this code that already works on these other devices to my ESP32-S2, as I have little information about how its i2c should work.
