Dear All,
I have a very annoying problem. I made a circuit of several subcomponents.
I have an Arduino UNO, which is the main board in my setup. It has an Arduino NANO connected to it (A4,A5, +5V and GND), and there is a 2-channel level shifter with a small DC-DC converter to convert the +5V of the UNO to +1.6V. The level shifter is used to shift the logical level of a digital caliper so I can read it with the UNO. Then, the NANO has a TB6600 connected to it (D8, D9, +5V), so I control the stepper motor with a separate board which receives the commands from the UNO. Also, there is a HX711 connected to the UNO for reading a load cell. Interestingly, this board is not affected by the noise, however it also uses the shared +5V and GND rails.
When I connect the USB to the main board, everything works nicely, the digital caliper gives signal, I can read the position with it...etc. However, when I connect the TB6600 to a power supply (I tried 4 different types), the readings of the digital caliper go crazy. I checked the signal of the digital caliper with an oscilloscope and I could see that the square waves change when I connect the PSU to the TB6600. It is like some extra edges are added to the square waves. I guess, that's the noise. So all of a sudden, the reading becomes 400 mm instead of 1.2 mm or something like that.
I removed the three pins of the TB6600 from the NANO, but I kept it powered. The caliper was still showing crazy numbers. Is it possible that the caliper picks up some sort of radio noise? How can I troubleshoot this issue? I tried different stepper motor controller, but I experienced the same issue.
Thank you for your ideas and help!
