Noise in IMU interfacing with arduino and Java RXTX Library at 115200 baud rate
Problem:
I am transmitting Quaternion IMU data and other 3 10-bit ADC data from arduino to my Windows 7 laptop via USB.
The baudrate is 115200 (as suggested in IMU 6050 firmware sample codes).
I am getting noise (or as per some guys back here buffer overflow, i dont know if its valid term for this scenario!!!) for 20 byte frame which i am transmitting from arduino to java code using rxtx lib.
Description
I am passing following frame constructed in arduino:
// packet structure .
uint8_t customPacket[20] = { '
where byte 3 to byte 8 is IMU data and byte 9 to byte 16 is 10 bit adc data.
I modified this code(https://github.com/jrowberg/i2cdevlib/blob/master/Arduino/MPU6050/Examples/MPU6050_DMP6/MPU6050_DMP6.ino) from i2cdev mpu6050 firmware example codes for my application with my custom packet.
the modified code fragment is written below:
        #ifdef OUTPUT_CUSTOM
            customPacket[2] = fifoBuffer[0];
            customPacket[3] = fifoBuffer[1];
            customPacket[4] = fifoBuffer[4];
            customPacket[5] = fifoBuffer[5];
            customPacket[6] = fifoBuffer[8];
            customPacket[7] = fifoBuffer[9];
            customPacket[8] = fifoBuffer[12];
            customPacket[9] = fifoBuffer[13];
            // setting the analog reads and seperating lower and higher bits in order to transmit serial
            int sensorValue = analogRead(xpin);
            customPacket[10] = (sensorValue & 0x300) >> 8;
            customPacket[11] = sensorValue & 0xFF;
            int sensorValue1 = analogRead(ypin);
            customPacket[12] = (sensorValue1 & 0x300) >> 8;
            customPacket[13] = sensorValue1 & 0xFF;
            int sensorValue2 = analogRead(zpin);
            customPacket[14] = (sensorValue2 & 0x300) >> 8;
            customPacket[15] = sensorValue2 & 0xFF;
            Serial.write(customPacket, 20);
        #endif
My java code is derived from Arduino Playground. Arduino Playground - Java
Modifications are are follows:
public synchronized void serialEvent(SerialPortEvent oEvent) {
        if (oEvent.getEventType() == SerialPortEvent.DATA_AVAILABLE) {
            try {
                if (aligned == false) {
                    if (input.read() == '
the logic is to have 20 bytes in read buffer starting from first marker $.
below are the first 11 frames(varies from trials to trials) of the code which can be considered as "clean" data as the marker is at the first position of the frame. (its byte data hence must be showing junk in ur utf conversion. my concern is alignment of marker at this point of time rather then parsing values of these bytes)
[$, , !, ?, 4, ?, , &, ?, ?, , ?, , ?, , ?, ]
but then the marker position get disaligned or lost (yikes!!) at all:
[,,, 4, ?, , , ?, ?, , ?, , ?, , ?, ]    (wheres the marker gone???)
[, 4, ?, , ?, ?, d, , ?, , ?, , ?, $, , "] (whats $ dollar doing there? he should be the first (pun intended))
earlier I tried to read the frame byte-by-byte but in vain partitioning the data with $ start points and frame size by if-else logic. But the data received were too slow than the actual baud rate of 115200. I used to get only 50-60 samples of frame per second approx. the earlier version of java rxtx code is:
            try {
                int c = input.read();
                if (c == '
So basically first method (my new method) brings noise or disalignment of markers and second one is too slow.
Either something is wrong in the above codes or there is some basic fundamental of serial communication I am missing.
Please guide me with this. Its quite crucial for me at this point of time.
Thanks and regards,
Parth J Joshi
, 0x02, 0,0, 0,0,0, 0,0, 0,0, 0,0, 0,0, 0,0x00, 0x00, '\r', '\n' };
§DISCOURSE_HOISTED_CODE_1§
My java code is derived from Arduino Playground. http://playground.arduino.cc/Interfacing/Java
§DISCOURSE_HOISTED_CODE_2§
§DISCOURSE_HOISTED_CODE_3§
§DISCOURSE_HOISTED_CODE_4§
§DISCOURSE_HOISTED_CODE_5§
Thanks and regards,
Parth J Joshi
                        input.skip(19); // seems to be aligned with $, skip this frame and start from another...
                        aligned = true;
                    return;
                input.read(bufferPacket);
                System.out.println((count) + ":" + Arrays.toString(bufferPacket));
                count++;
            } catch (Exception e) {
                System.err.println(e.toString());
§_DISCOURSE_HOISTED_CODE_3_§
§_DISCOURSE_HOISTED_CODE_4_§
§_DISCOURSE_HOISTED_CODE_5_§
Thanks and regards,
Parth J Joshi
Thanks and regards,
Parth J Joshi
                    if (counter != FRAME_LEN) {
                        counter++;
                    } else if (counter == FRAME_LEN) {
                        counter = 0; //useless;
                    if (counter == 1 && c == 0x02) {
                        counter++;
                    } else if (counter == (FRAME_LEN - 1)) {
                        currentFrame[counter] = c;
                        frameCalculations(currentFrame); // calculations to convert quaternion data to ypr once a single frame is received. the same functions also logs the data in a file.
                        System.out.println(scounter++);
                        counter = 0;
                    } else if (counter >= 2 && counter < 19) {
                        counter++;
                //    System.out.println(counter);
                System.out.println("error:" + e);
Thanks and regards,
Parth J Joshi
Thanks and regards,
Parth J Joshi
                        aligned = true;
                    return;
                count++;
Thanks and regards,
Parth J Joshi
Thanks and regards,
Parth J Joshi
I can't immediately grasp the details of your code (probably because I am lazy, and while I like the JVM I don't like the Java language).
I have been using JRuby and Rxtx to transfer data to and from an Uno and I am pretty sure it worked fine at 115200. I am working on a demo program to pass data between a PC and an Arduino and I will try it later today at 115200 baud and report back. I'm also experimenting with JSSC as an alternative to Rxtx so I can try that also.
I was a bit confused by your title because I thought you meant that the IMU was causing interference, but I don't think you mean that?
...R
There is nothing wrong with the imu. Teapot example in Processing is running just fine.
The problem is about serial communication via usb between ardruino and java.
Also I found that Number of bytes i received in USB interface through rxtx lib in java is just around 400-500 in a sec at 115200 baudrate. Is is really quite slow in java? or am I missing something. The code I used is same as one in Arduino Playground for Java Interfacing.
I have now tried my JRuby program with Rxtx and with JSSC at 115200 baud and, as expected it works fine.
I have another application where communication speed is important and Rxtx performs perfectly well. I'm not sure how much data you send with every "write". USB performs poorly with small quantities of data.
Can you describe how you are managing the data transfer to save me having to wade through your code?
What Arduino are you using?
...R
You are passing binary data terminated by ASCII CRLF which seems unusual since the binary data may contain a CR or LF byte.
