Hi everyone,
I use an arduino pro mini and i read A0 for values from a sct-013 30A/1V Non-invasive AC Current Sensor Clamp.
When i have the ethershield disconnected i read 0 values as i should (no ac power connected).
However when i connect the ethernetshield i immediately get values like 34-37 instead of 0 (possible analog values 0-1024).
I tried to place various capacitors between V5+ and ground and between A0 and ground without significant change.
I powered the arduino from USB/PC and USB/power adapter without change.
I also tried another ethernet shield but i didn't noticed anything different.
Can anyone suggest something to reduce the noise?
Thanks
Can you give link to the current clamp and to a schematic that you use ?
This is the current transformer : Buy Cheap SCT 013-030 3.5mm Output Split-core Current Transformer
It is noise ? Perhaps the current from the Ethernet shield causes a change of a ground level.
The ground currents are very important. Can you make a photo of your wiring ? Did you somehow use AREF or analogReference(), or is everything with the 5V reference ? What are the values of the resistors to get 2.5V ?
Show us the sketch please.
Hi Koepel,
Thank you for your responce.
The clamp is identical to the one on your link. 30 A correspond to 1V read via A0.
Connections:
- clamp
arduino A0 to clamp signal
arduino GROUND to clamp signal
- ethershield
arduino D10 to SS
arduino D11 to MOSI
arduino D12 to MISO
arduino D13 to SCK
arduino V5+ to V5+
arduino GROUND to GROUND
- powered via USB
About ref:
No i use analogReference(INTERNAL); //initialize referance to 1.1 V in the schetch
I haven't connected any resistors, the clap has internal resistors and brings 0-1Volts corresponding to 0-30Amps.
oops! small correction..arduino GROUND to clamp GROUND!
As i said before I tried to power the arduino from different sources than the USB.
I tried once more with a more reliable power adapter and not through the USB of the arduino.
It worked this way. Now I get 0 volts in analog port when i am connected to the ethernet!
Solved!
