I've been playing with a piezo element, my arduino, and an oscilloscope, and it seems like when I use Arduino gnd, the noise is way higher than when I use the oscilloscope gnd? Thoughts? I can be more specific if needed, but right now I've got the piezo (+) connected to the oscilloscope and to gnd through a 10mohm resistor. piezo (-) goes to gnd
I'm just wondering about noisy Arduino gnd, and whether the analog port should be noisy too, and what people do about that.
fyi I am also a super newbie. Have posted to this forum before about this project - I'm really bad at this / kind of lost.
Because http://www.arduino.cc/en/Tutorial/KnockSensor says to put a parallel resistor. I actually don't know why. Is it just to control the voltage and protect the analog port? Beats me. I've gotten rid of it before.
how are you measuring noise levels?
A good question, too. I'm just eyeballing it on the oscilloscope.
I'm kind of shooting in all directions here. If you look at my other postings, I'm doing a project with a piezo disk to measure raindrops. The voltage from the drops is usually not high enough for the signal to be noticed by the A/D converter. It's usually in the mV range, but low mV; when I tried to use a number of op-amps, I got results that really only amplified my 'big' signals - basically, signals that I could already see got bigger, but signals that I couldn't see didn't move.
That page doesn't say what the resistor is actually doing. I assume it's to discharge the piezo capacitance
between knocks. I don't see how a 1Mohm R in parallel could possibly protect the port. You would need
a clamping diode or zener for that.
A piezo sensor probably acts as a fairly pure current noise source, so the load resistor is what determines the noise voltage - hence the need to measure with identical load resistances.
Also noise amplititude depends on bandwidth, and we are probably talking about two setups with wildly different bandwidths...
