#include "arduinoFFT.h"
#define SAMPLES 128 //Must be a power of 2
#define SAMPLING_FREQUENCY 40000 //Hz, must be less than 10000 due to ADC
arduinoFFT FFT = arduinoFFT();
unsigned int sampling_period_us;
unsigned long microseconds;
double vReal[SAMPLES];
double vImag[SAMPLES];
sampling_period_us = round(1000000*(1.0/SAMPLING_FREQUENCY));
/*SAMPLING*/
for(int i=0; i<SAMPLES; i++)
microseconds = micros(); //Overflows after around 70 minutes!
vReal[i] = analogRead(PA2);
vImag[i] = 0;
while(micros() < (microseconds + sampling_period_us)){
/*FFT*/
FFT.Windowing(vReal, SAMPLES, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
FFT.Compute(vReal, vImag, SAMPLES, FFT_FORWARD);
FFT.ComplexToMagnitude(vReal, vImag, SAMPLES);
double peak = FFT.MajorPeak(vReal, SAMPLES, SAMPLING_FREQUENCY);
/*PRINT RESULTS*/
//Serial.println(peak); //Print out what frequency is the most dominant.
for(int i=0; i<(SAMPLES/2); i++)
/*View all these three lines in serial terminal to see which frequencies has which amplitudes*/
//Serial.print((i * 1.0 * SAMPLING_FREQUENCY) / SAMPLES, 1);
Serial.print(2000);
Serial.print(" ");
Serial.println(vReal[49], 1); //View only this line in serial plotter to visualize the bins
delay(100); //Repeat the process every second OR:
//while(1); //Run code once
Hurrah. Are you sure the library supports that sampling rate? Please post the captured waveform. It would give us all a warm fuzzy feeling to see the sine wave. Did you read this:
