Hi all, I'm having trouble with the following code, trying to write on a Nokia 5110 old LCD:
#include <Nokia_LCD.h>
#include <BH1750.h>
const unsigned char splash[504] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x1C, 0x18, 0x00, 0x80, 0x80,
0xC0, 0xC0, 0xC7, 0xC7, 0xC7, 0xC0, 0xC0, 0x80, 0x80, 0x00, 0x18, 0x1C, 0x18, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x07, 0x07, 0x00, 0xE0, 0xF8, 0xFC, 0xFE,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE,
0xFC, 0xF8, 0xE0, 0x00, 0x07, 0x07, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xF0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xF0, 0x00, 0x00, 0x80, 0xE0, 0x60, 0x30, 0x30, 0x30, 0x30,
0x10, 0x00, 0x00, 0x00, 0xF0, 0xF0, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xF0, 0x00, 0x30, 0x30, 0x30,
0xF0, 0xF0, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x07, 0x07, 0x07, 0x07, 0x00, 0x00, 0x00,
0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x00, 0x00, 0x00, 0x07, 0x07, 0x07, 0x07, 0x00, 0x00,
0x00, 0x7F, 0x7F, 0x60, 0x60, 0x60, 0x60, 0x00, 0x00, 0x7F, 0x7F, 0x00, 0x00, 0x0F, 0x3F, 0x70,
0x60, 0x60, 0x66, 0x7E, 0x7E, 0x00, 0x00, 0x00, 0x7F, 0x7F, 0x06, 0x06, 0x06, 0x06, 0x7F, 0x7F,
0x00, 0x00, 0x00, 0x00, 0x7F, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x06, 0x07, 0x06, 0x00, 0x00, 0x00, 0x03, 0x0F, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x0F, 0x03, 0x00, 0x00, 0x00, 0x06, 0x07, 0x06, 0x00,
0xC0, 0xF8, 0x18, 0xF8, 0xC0, 0x00, 0xC0, 0xF8, 0x18, 0xF8, 0xE0, 0x00, 0xF8, 0xF8, 0x18, 0x18,
0x18, 0x18, 0x00, 0x18, 0x18, 0x18, 0xF8, 0xF8, 0x18, 0x18, 0x18, 0x00, 0xF8, 0xF8, 0x18, 0x18,
0x18, 0x18, 0x00, 0x00, 0xF8, 0xF8, 0x18, 0x18, 0x18, 0xF8, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x67, 0xE7,
0xE7, 0xE7, 0xE7, 0xE7, 0xE7, 0xE7, 0xE7, 0xE7, 0x67, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3F, 0x3F, 0x00, 0x03, 0x3F, 0x3C, 0x1F, 0x01, 0x00, 0x3F, 0x3F, 0x00,
0x3F, 0x3F, 0x33, 0x33, 0x33, 0x33, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x3F, 0x00, 0x00, 0x00, 0x00,
0x3F, 0x3F, 0x33, 0x33, 0x33, 0x33, 0x00, 0x00, 0x3F, 0x3F, 0x03, 0x03, 0x07, 0x3F, 0x38, 0x00,
0x00, 0x00, 0x0E, 0x0E, 0x3E, 0x7E, 0x7E, 0x7E, 0x7E, 0x7E, 0x3E, 0x0E, 0x0E, 0x00, 0x00, 0x00,
const unsigned char ui[504] PROGMEM = {
0xFF, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0xFD, 0xFD, 0xFD, 0x01, 0x01, 0x01, 0x01, 0x01,
0x01, 0x01, 0x01, 0xFD, 0xFD, 0xFD, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0xFD, 0xFD, 0xFD, 0x01,
0x05, 0x0D, 0x3D, 0xFD, 0xF9, 0xE1, 0x01, 0xE1, 0xF9, 0xFD, 0x3D, 0x0D, 0x05, 0x01, 0x01, 0x01,
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
0x01, 0x01, 0x01, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x80,
0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x3F, 0xFF, 0xFF, 0xC0, 0x80, 0x80, 0x80, 0x80, 0xC0,
0xFF, 0xFF, 0x3F, 0x00, 0x00, 0x80, 0xE0, 0xF0, 0xFF, 0x3F, 0x1F, 0x7F, 0xFF, 0xF0, 0xE0, 0x80,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18,
0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18,
0x1B, 0x1B, 0x1B, 0x1B, 0x1B, 0x1B, 0x1B, 0x1B, 0x1B, 0x18, 0x18, 0x18, 0x18, 0x19, 0x1B, 0x1B,
0x1B, 0x1B, 0x1B, 0x1B, 0x19, 0x18, 0x18, 0x18, 0x1A, 0x1B, 0x1B, 0x1B, 0x19, 0x18, 0x18, 0x18,
0x19, 0x1B, 0x1B, 0x1B, 0x1A, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18,
0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0xFF, 0xFF, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF,
0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0xFF, 0xFF, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80,
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80,
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0xFF,
Nokia_LCD lcd(8,9,10,11,12,7);
BH1750 lightSensor;
String light;
// lightSensor.begin();
lcd.begin();
lcd.setBacklight(false);
lcd.setContrast(60);
lcd.clear();
delay(2000);
lcd.draw(splash, sizeof(splash) / sizeof(splash[0]), true);
delay(3000);
lcd.setBacklight(true);
int stringLength=0;
uint16_t lux = lightSensor.readLightLevel();
light = String(lux);
stringLength = light.length();
// lcd.clear();
// lcd.draw(ui, sizeof(ui) / sizeof(ui[0]), true);
// printLight(stringLength);
delay(150);
void printLight(int length)
switch(length)
case 1: lcd.print(light,68,22); break;
case 2: lcd.print(light,54,22); break;
case 3: lcd.print(light,40,22); break;
case 4: lcd.print(light,26,22); break;
case 5: lcd.print(light,12,22); break;
default: lcd.print(light,0,22); break;
The compiler give me:
Compilation error: no matching function for call to 'Nokia_LCD::print(String&, int, int)'
Using this 5110 library: GitHub - platisd/nokia-5110-lcd-library: Arduino library for driving the Nokia 5110 LCD
