nokia 5110
Hi
I trying to change LCD 16x2 to nokia 5110,
The program displays i and j on serial monitor and on LCD 16x2.
How to make the numbers to be displayed on nokia 5110 ?
//#include <LiquidCrystal.h>
#include <EEPROM.h>
//LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
//LiquidCrystal lcd(PB15, PB5, PA2, PB6, PB8, PB9);
#include <LCD5110_Graph.h> // THE LIBRARY I AM USING IS THIS:  http://www.rinkydinkelectronics.com/library.php?id=47
LCD5110 lcd(PA0, PA1, PA2, PA4, PA3);
extern unsigned char BigNumbers[];
extern uint8_t ui[];
extern uint8_t startScreen[];
int i;
int j;
  lcd.InitLCD();
  lcd.update();
  lcd.setFont(BigNumbers);
  pinMode(PB14, INPUT_PULLDOWN);//
  pinMode(PB12, INPUT_PULLDOWN);//
  pinMode(PB13, INPUT_PULLDOWN);
  pinMode(PB15, INPUT_PULLDOWN);
  //lcd.begin(16, 2);
  //EEPROM.read(500, (uint16*)&i);
  if (digitalRead(PB13) == HIGH)
    if (i < 2000) //limit
      i++;
  if (digitalRead(PB15) == HIGH)
    if (i > 0)
      i--;
  if (digitalRead(PB14) == HIGH)
    if (j < 3000) //limit
      // if (i < 25)
      j++;
  if (digitalRead(PB12) == HIGH)
    if (j > 0)
      j--;
  Serial.print(i);
  Serial.print(" ");
  Serial.println(j);
  lcd.print(i, 0, 10);
  lcd.print(i, 0, 30);
    lcd.setCursor(0, 0);
    lcd.print("i=");
    lcd.print(i);
    lcd.setCursor(0, 1);
    lcd.print("j=");
    lcd.print(j);
The 5110 displays are totally different from a hd44780 character display (1602, 2004).
Install the Adafruit_PCD8544-Nokia-5110-LCD library. The library is available through the IDE library manager. The library comes with example code to test the display.
To do graphics install the Adafruit_GFX library.
The 5110 displays are not 5V. They need 3.3V power and the inputs need 3.3V. So with a 5V Arduino you will need levels shifters on all the 5110 inputs.
Here is a good tutorial from Adafruit.
I downloaded it and this testing program is working, so display is connected correctly
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
boolean backlight = true;
int contrast=50;
int menuitem = 1;
int page = 1;
volatile boolean up = false;
volatile boolean down = false;
volatile boolean middle = false;
int downButtonState = 0;
int upButtonState = 0;
int selectButtonState = 0;
int lastDownButtonState = 0;
int lastSelectButtonState = 0;
int lastUpButtonState = 0;
//Adafruit_PCD8544 display = Adafruit_PCD8544( 5, 4, 3);
Adafruit_PCD8544 display = Adafruit_PCD8544(PA0, PA1, PA2, PA3, PA4);
//#include <LCD5110_Graph.h> // THE LIBRARY I AM USING IS THIS:  http://www.rinkydinkelectronics.com/library.php?id=47
//CD5110 display(PA0, PA1, PA2, PA4, PA3);
  pinMode(2, INPUT_PULLUP);
  pinMode(1, INPUT_PULLUP);
  pinMode(0, INPUT_PULLUP);
  pinMode(7,OUTPUT);
  digitalWrite(7,LOW); //Turn Backlight ON
  display.begin();
  display.setContrast(contrast); //Set contrast to 50
  display.clearDisplay();
  display.display();
  drawMenu();
  downButtonState = digitalRead(2);
  selectButtonState = digitalRead(1);
  upButtonState =   digitalRead(0);
  checkIfDownButtonIsPressed();
  checkIfUpButtonIsPressed();
  checkIfSelectButtonIsPressed();
  if (up && page == 1 ) {
    up = false;
    menuitem--;
    if (menuitem==0)
      menuitem=3;
  }else if (up && page == 2 ) {
    up = false;
    contrast--;
    setContrast();
  if (down && page == 1) {
    down = false;
    menuitem++;
    if (menuitem==4)
      menuitem=1;
  }else if (down && page == 2 ) {
    down = false;
    contrast++;
    setContrast();
  if (middle) {
    middle = false;
    if (page == 1 && menuitem==2)
      if (backlight)
        backlight = false;
        turnBacklightOff();
        backlight = true;
        turnBacklightOn();
    if(page == 1 && menuitem ==3)
      resetDefaults();
else if (page == 1 && menuitem==1) {
      page=2;
else if (page == 2) {
      page=1;
  void checkIfDownButtonIsPressed()
    if (downButtonState != lastDownButtonState)
    if (downButtonState == 0)
      down=true;
    delay(50);
   lastDownButtonState = downButtonState;
void checkIfUpButtonIsPressed()
  if (upButtonState != lastUpButtonState)
    if (upButtonState == 0) {
      up=true;
    delay(50);
   lastUpButtonState = upButtonState;
void checkIfSelectButtonIsPressed()
   if (selectButtonState != lastSelectButtonState)
    if (selectButtonState == 0) {
      middle=true;
    delay(50);
   lastSelectButtonState = selectButtonState;
  void drawMenu()
  if (page==1)
    display.setTextSize(1);
    display.setTextColor(BLACK, WHITE);
    display.setCursor(15, 0);
    display.print("MAIN MENU");
    display.drawFastHLine(0,10,83,BLACK);
    display.setCursor(0, 15);
    if (menuitem==1)
      display.setTextColor(WHITE, BLACK);
    display.print(">Contrast");
    display.setCursor(0, 25);
    if (menuitem==2)
    display.print(">Light: ");
    if (backlight)
      display.print("ON");
      display.print("OFF");
    display.display();
    if (menuitem==3)
    display.setCursor(0, 35);
    display.print(">Reset");
    display.display();
  else if (page==2)
    display.print("CONTRAST");
    display.setCursor(5, 15);
    display.print("Value");
    display.setTextSize(2);
    display.setCursor(5, 25);
    display.print(contrast);
    display.display();
  void resetDefaults()
    contrast = 50;
    setContrast();
    backlight = true;
    turnBacklightOn();
  void setContrast()
    display.display();
  void turnBacklightOn()
    void turnBacklightOff()
    digitalWrite(7,HIGH);
but program LCD 16x2 converted to nokia is not = blank screen
//#include <EEPROM.h>
int contrast=50;
int i;
int j;
 display.begin();
  display.display();
  //lcd.begin(16, 2);
      i++;
    if (i > 0)
      i--;
      // if (i < 25)
      j++;
    if (j > 0)
      j--;
  Serial.print(i);
  Serial.print(" ");
  Serial.println(j);
  // lcd.print(i, 0, 10);
  //lcd.print(i, 0, 10);
  display.print(i);
    lcd.print("i=");
    lcd.print(i);
    lcd.print("j=");
    lcd.print(j);
  display.print(i);
That code sets up the display buffer.
display.display();
Sends the buffer to the display. You must call display.display(); for anything to show on the screen or after you call display.clearDisplay(); to clear the screen.
after uploading the 0 appears = display.print(i); for i = 0, then if i is higher then 0 I have a small black rectangle.
I was trying to use display.clearDisplay(); , but didn't work
int contrast = 60;
int i;
int j;
  display.begin();
  // display.display();
  //lcd.begin(16, 2);
      i++;
    if (i > 0)
      i--;
      // if (i < 25)
      j++;
    if (j > 0)
      j--;
  Serial.print(i);
  Serial.print(" ");
  Serial.println(j);
  // display.clearDisplay();
  display.display();
  display.print(i);
I did it,
Thank You
